09-10-2012 #18
The rails are bolted to the box section, even in post #15. Earlier designs for a 1000mm gantry had them mounted on 90x45 ali extrusion which was bolted to a back plate.
I was hoping that tacking the sections together first and then do gradual passes would eliminate any heat distortion but if it's out of spec for the bearing before i even start, well that puts the mockers on that idea. Any idea how 90x45 ali extrusion would cope over 2m?
I would have liked to have the ballscrew mount on the Z axis upright so I would have to remove the middle box section and bolt to a 20mm back plate but then then is no room for the ballscrew mount unless the width of Y is 200mm+ to accomodate the mount as i feel it best to surround the Y bearings. Y ballscrew is currently 100mm off centre from the Y bearings.
NEW MEMBER: Hello & Happy New Year
By surpher in forum New Member IntroductionsReplies: 0Last Post: 01-01-2012, 06:29 PM -
Happy Scrounger, Mini mill to Mach 3
By PatK in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 05-10-2011, 11:06 AM -
Wiring Project
By Karl in forum Electronic Project BuildingReplies: 2Last Post: 07-07-2011, 02:11 PM -
Happy birthday Lee...!!!
By HiltonSteve in forum General DiscussionReplies: 10Last Post: 19-09-2010, 01:38 AM
