    So how many other people got a big cheesy grin on their face when their machine move freely for the first time?
    I could have quite literally smashed it to bits last night! It was binding up all over the place and when it did move couldn't lift my weight! Oh yeah its gone vertical now to save space.
    So stripped it all down last night noticed the ballnuts weren't square with the rotating ballnut mount so that didnt help.
    It's now all nicely realigned, tacked and clamped (ran out of mig wire) and moves freely under the control of mach. It lifts me and 2 kids together without breaking a sweat. The pendant has been ditched for now.
    Next on the cards is the X axis......or is in now Y.......oh I dunno......beer time
    Nice feeling isn't it.!! . . . Just wait until you try cutting.??. . . You'll be chasing stuff like this for weeks, maybe months before your happy. It's all par the course but worth it.
    About time we got some update pics.!
    That means I'd have to tidy up. I know where everything is at the mo'.
    Quote Originally Posted by r0bsk1 View Post
    You will spoil the photo if you tidy up!
    Tidy is for hospitals
    Ok here's a few pics....
    Main 70v PSU with 24v safety system and 5V for BOB mounted on a temporary board.
    Frame layout. 60mmx60mmx5mm frame for rails with 100mmx100mmx4mm for the upright frame. One side fell over while i was realigning the other side and flattened me!
    X rotating ball nut
    X ball nut and stepper
    X screw clamp. For some reason i asked for 10mm to be added to the mounting face of the stepper mounts. Cant remember exactly why but that's put the 2 screws out of line with the rails. No biggy.
    The camp is made of 60mm box section with 2 aluminum wedges inside that clamp of to the screw when bolted together. They also wedge thigh inside the box section. 50mm box section is welded underneath and slide in to the main frame.
    This is causing me a few headaches. My plan is to join the Y 2 bearing mounts with a 20mm plate and mount the ballnut mount to that. Im also going to increase the with to 200mm
    Alternatively, and this is going to mean major surgery, move the plate joining to 2 X screws together to the back of the black box section and sink them 20mm further in to X uprights. The ballnut mount can be mounted directly to the Z backplate.
    I'd take the major surgery because this way will cause you a bigger problem than you realise.? Because your vertical that back void will fill with chips in no time at all. . . . Some of the chips fly up before they fall down.!!
    Having the front open will mean they will bounce off back plate and escape.!
    Surgery is complete but there's been complications.
    The 1610 screw in the pic was originally sized at 1190mm to fit between the 2 beams joining the uprights and mount on the backplate with the stepper on the back.
    The screw is long enough to go through one side of the upright plates. However the ballnut on the 2510 screw is in the way of the ballscrew support and pulley.
    Without getting a another screw with an extended pulley area my only option i can see is to mount the screw between the 2 beams on the other side of the back plate and create a access hole for the belt to pass through from the screw to the stepper.
  1. NEW MEMBER: Hello & Happy New Year
    By surpher in forum New Member Introductions
    Last Post: 01-01-2012, 06:29 PM
  2. Happy Scrounger, Mini mill to Mach 3
    By PatK in forum Gantry/Router Machines & Building
    Last Post: 05-10-2011, 11:06 AM
  3. Wiring Project
    By Karl in forum Electronic Project Building
    Last Post: 07-07-2011, 02:11 PM
  4. Happy birthday Lee...!!!
    By HiltonSteve in forum General Discussion
    Last Post: 19-09-2010, 01:38 AM
