10-10-2012 #19
I should have been clearer, it might be out too much even before welding, but you can get round that. Instead of welding three pieces together couldn't you start with one or two bigger sections, then bolt them to a back plate? If you have a fastener every 100mm or so you can use them to adjust and remove the bend enough to mount the rails. Two pieces of 90x45 aluminum extrusion to mount the rails on would be fine, or you could use aluminium box section.
Spacing the Y-rails out 200mm+ to accommodate the ballnut mount would be good as in addition to making the axis much more rigid due to the ballnut being in the optimal position, it will also make make it stronger because the bearings are further apart. However you don't want the rails too far apart without increasing the spacing of the bearing blocks since it risks them skewing/racking. The ballnut mount could be made a fair bit shorter by moving the mounting holes and having only one available ratio without changing the belt.
NEW MEMBER: Hello & Happy New Year
By surpher in forum New Member IntroductionsReplies: 0Last Post: 01-01-2012, 06:29 PM -
Happy Scrounger, Mini mill to Mach 3
By PatK in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 05-10-2011, 11:06 AM -
Wiring Project
By Karl in forum Electronic Project BuildingReplies: 2Last Post: 07-07-2011, 02:11 PM -
Happy birthday Lee...!!!
By HiltonSteve in forum General DiscussionReplies: 10Last Post: 19-09-2010, 01:38 AM
