Thread: It's begun....
Page 16 of 16 FirstFirst ... 6141516
  1. #151
    Hi Washout,
    Good to see some machining and an interesting way to get a fourth axis into the table.
    Noticed that your X axis syncronising belt looked a bit loose by the way . . .
  2. #152
    Hi Washout,
    Thanks - it seemed like a good way of getting the thing mounted without faffing about each time. Especially as the mounting holes in the chuck of course didn't line up with the table slots (sod's law at work as usual). I could have put the additional piece of extrusion on top of the existing bed, but I'd have lost a lot of Z clearance that way.
    Re: the belt - thanks for that as well - it needs a bit of a tighten and its normally a little slack but the tensioning pulley has obviously moved a bit through use - probably the higher speeds I've been using on the acrylic in the other videos.
    I'm also cutting the logo in the acrylic into the other side of the PC case, which is steel and will be the first time I've tried that (deliberately at least anyway ;) ).
  3. #153
    Nice start. There are some posts somewhere on this forum where I motorized mine and others rotary tables. Have to take some care to get low backlash, but it's do-able.
    I made something yesterday, then noticed it looks a bit like a light-saber:
    Can anyone guess what it actually is ...
  4. #154
    Hi Jonathan,
    No idea what that is - are you selling them to a less than desirable government's internal affairs ministry? ;)
  5. #155
    It's a wimwam to wind the sun up
  6. #156
    Not quite! Clue - I made it for free and it will definitely be used next week.
  7. #157
    Bet it's going on a Boat for a blast around some very very scary roads.???
  8. #158
    Something like that ... I just finished working on the 'boat' for tonight, so 2 hours sleep before recommencing tomorrow!
  9. #159
    A first for my machine a few days ago gents.
    Got it to cut steel sheet (very slowly) - props to GWizard for the feeds and speeds:
  1. BUILD LOG: Web Goblin cnc has begun
    By Web Goblin in forum DIY Router Build Logs
    Last Post: 12-02-2012, 08:49 PM
