Thread: It's begun....
06-10-2013 #11
Chris you can set climb as an option in CUT3D. I use Vectric (VCarvePro, CUT3D, PhotoVCarve and also CamBam [Not Vectric]). Why I use the different ones, is a horses for courses item and I could not afford Aspire at that time (the ones I got hurt the budget enough though they are help increase earning a good bit). Drop me a message and will gladly help as able on Vectric. CamBam has some very useful ability if you are doing isolated 2.5/3D type work (I use it to help make chromatic harmonica combs and they are complex planes on the interior). I am very sound sensitive and Dean is correct in that once you get used to it you will know what sounds right.
It is looking really nice. If you are looking for vacuum tables I would look at Sorotec out of Germany as they are selling a really nice model from a US firm and they are well made. I am finishing building a wooden one that will do the job I need and be fit to my work area. If looking for a vacuum set up let me know. -MichealLast edited by m.marino; 06-10-2013 at 04:45 PM.
Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
BUILD LOG: Web Goblin cnc has begun
By Web Goblin in forum DIY Router Build LogsReplies: 147Last Post: 12-02-2012, 08:49 PM
