Thread: It's begun....
25-01-2014 #25
Hi All,
A couple of vids, as the machine is cutting again. They're not very long as the one was just a facing pass to get the material block to the right thickness and the second one I had to start clearing chips with the air gun (more to be safe now I have decent air).
Sharp eyed amongst you may notice I abandoned the mixing block effort from before and just ran two lines - one brass tube for air and the other PVC for cutting fluid, which just drips into the air flow.
The second one was a 2mm DoC using F&S from GWizard, which I was quite happy with and I think I could go deeper. A good sign was scorching hot chips, which I noticed when one fell down the front of my t-shirt, but no discernible heat on the part (I wasn't going to touch the cutter, but trust in my coolant) ;-)
I'll try and get some more video once I work out a way of mounting my phone, so I can fuss over the machine whilst recording.
Later
Chris
BUILD LOG: Web Goblin cnc has begun
By Web Goblin in forum DIY Router Build LogsReplies: 147Last Post: 12-02-2012, 08:49 PM
