    I need to drill 4 x 28mm holes through aluminium to make ballscrew nut mounts.... from 1-3/4" 44mm square bar.
    Does anybody have any tips for doing this?
    I'm thinking of using a good quality bi-metal holesaw.... Irwin/Bosch... at 545 rpm in the bench drill press... Drilling a 6mm pilot hole first... and possibly drilling two 6mm holes at opposing ends of the diameter to help with clearing chips.
    Sure I would have to tackle the bar from both sides, but have no idea whether I would be fighting a losing battle, or whether cutting fluid would help keep the tool cool or have the opposite effect by making the chips gum up?
Name:	$BallNut 1605-1610 Housing.png
  2. A hole saw will do it. but accuracy wont be great. A straight shanked boring head would be better if you can get a small one with a 12mm arbor to fit in the chuck. Theres no need to drill any holes other than the pilot hole..
    Cutting fluid will help in either case... compressed air also works
    Or ask someone nicely... hobnobs and/or beer often work ;)
    A straight shanked boring head would be better if you can get a small one with a 12mm arbor to fit in the chuck. ... Or ask someone nicely... hobnobs and/or beer often work ;)
    Thanks Irving... Haven't seen hobnobs on here since that little spat a couple of weeks ago, which is sad as I really enjoyed his sense of humour... and benefitted from his contributions.
    I will make use of a machining service that has access to a lathe and CNC, as that tooling looks expensive for now... Is a boring head and a fly-cutter one and the same thing?
  4. Quote Originally Posted by WandrinAndy View Post
    Essentially, tho a boring head is arguably more accurate as it holds a cutter at a known distance from the axis and is adjusted with a micrometer screw whereas a flycutter generally holds a bit of tool steel out at an angle. Boring heads generally allow you to bore deep holes; flycutters are usually used to cut circular holes in sheet of relatively low thickness..
    If I could get at my mill or lathe I'd offer to do it for you, but at the moment I can't physically get at them .... :(
    This would be a nice little lathe job for anyone with a 4 jaw chuck and boring bar.
    I used an annular cutter with an adapter for it to fit the pillar chuck. Worked great. Or, you can buy a morse taper one for them.
    Quote Originally Posted by jonbabbz View Post
    Didn't know those existed and it looks like they will clear the swarf quite well. What does the adapter you used look like/where can they be bought?
    They go through ali like butter. Ive seen the adapters on ebay before, or you can make one like mine on a lathe for nothing.
    Last edited by irving2008; 30-09-2012 at 01:42 AM. Reason: fixed broken image link
  9. The Following User Says Thank You to jonbabbz For This Useful Post:
  10. #9
  11. #10
    Quote Originally Posted by boldford View Post
    I wouldn't bid on that since if an item has 'Myford' in the title you might as well multiply the price by ten!
  1. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  2. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 08:31 PM
  3. RFQ: small cutout panel 66mm x 44mm - stainless steel 1mm thick
    By dsc in forum Projects, Jobs & Requests
    Last Post: 18-06-2012, 09:47 AM
  4. Now if only someone invented a drill that drilled square holes.....
    Last Post: 20-10-2011, 10:07 PM
