Thanks Irving... Haven't seen hobnobs on here since that little spat a couple of weeks ago, which is sad as I really enjoyed his sense of humour... and benefitted from his contributions.
I will make use of a machining service that has access to a lathe and CNC, as that tooling looks expensive for now... Is a boring head and a fly-cutter one and the same thing?
28-09-2012 #2
Essentially, tho a boring head is arguably more accurate as it holds a cutter at a known distance from the axis and is adjusted with a micrometer screw whereas a flycutter generally holds a bit of tool steel out at an angle. Boring heads generally allow you to bore deep holes; flycutters are usually used to cut circular holes in sheet of relatively low thickness..
If I could get at my mill or lathe I'd offer to do it for you, but at the moment I can't physically get at them .... :(
What tooling to drill lots of 10mm holes 45mm deep?
By AlanMJackson in forum Tool & Tooling TechnologyReplies: 24Last Post: 13-01-2014, 08:53 PM -
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM -
RFQ: small cutout panel 66mm x 44mm - stainless steel 1mm thick
By dsc in forum Projects, Jobs & RequestsReplies: 2Last Post: 18-06-2012, 09:47 AM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM
