Thread: Help with settings!
29-09-2012 #11
Tenson I have just gone through this same senario for three weeks. I replaced the ballnut because it did not have enough bearings in it, Read my build log for why. Turns out that after chatting with dean it was all down to resonance and tuning the steps correctly. Try changing your steps to a lower figure, eg from 1/8 to 1/4. It may be a mechanical problem but this is worth checking. I went from 1/8 to 1/4 and it got worse. Then went to 1/5 and the machine is sweet!!
bruceThe more I know, I know, I know the less. (John Owen)
Saving machine settings between sessions
By Neale in forum Machine Control SoftwareReplies: 19Last Post: 07-05-2014, 08:17 PM -
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
Calculating torque settings for bolts.
By swarf-boy in forum Machine DiscussionReplies: 2Last Post: 22-12-2010, 12:18 AM
