Thread: Help with settings!
How much tension is it under when tight.?
How are you aligning the screw with nut.?
Have you checked there's no play or slop in the rotating ballnut.?
When leaving the one end lose does it work ok without holding it and if so does the screws lose end move up or down when Z axis travels along it length.?
I see in the video with you holding the end that the screw is a sloppy fit where pass's thru the gantry sides. Is this correct or have you removed a bush or anything.?
Really would think that if you nipped the screw up at each end just enough so the screw can slide slightly then move the Z axis to each end a few times it will align it's self then tighten the ends.
Saving machine settings between sessions
By Neale in forum Machine Control SoftwareReplies: 19Last Post: 07-05-2014, 08:17 PM -
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
Calculating torque settings for bolts.
By swarf-boy in forum Machine DiscussionReplies: 2Last Post: 22-12-2010, 12:18 AM
