I hope the tank battery is NiMh/NiCd not LiPo? If it's the latter then you need to be careful as they require a low voltage cutoff to stop them being damaged from over discharge. If it will tolerate up to 12.6V then a 11.1v (3 cells in series) lithium battery would be ideal since when fully discharged it would still be around 10V. Plenty on HobbyKing RC Plane, Car, Heli, Boat and MultiRotor Hobby Store ... if it's the first time you've seen that site you'll no doubt be up all night buying better batteries and all sorts for the tank!
What voltage for stepper drive?
By Davek0974 in forum Plasma Table MachinesReplies: 1Last Post: 22-01-2014, 10:49 PM -
parralell port voltage.
By crossleymarko in forum Computer HardwareReplies: 71Last Post: 15-04-2012, 09:55 PM -
voltage on motor wires
By phill05 in forum General ElectronicsReplies: 9Last Post: 11-02-2012, 03:43 PM -
Alternator low voltage
By M250cnc in forum General ElectronicsReplies: 12Last Post: 24-02-2011, 11:23 AM -
Boxford VMC 260 steppers voltage?
By evildrome in forum Boxford Vertical MillsReplies: 3Last Post: 20-10-2010, 03:03 PM
