    Hi Guys,
    Can anyone recommend a company or individual that might be able to machine some parts out of aluminium at a competitive rate? I've tried a few companies near to me, but they either aren't interested in doing one offs or quote a silly price. I basically want some angular contact bearings set into a block of aluminium with a few mounting holes.
    Thanks,
    Adam.
    You're probably best off posting in the RFQ section, detailing what you need with a drawing. It sounds like something I could make, but I can't be sure or give a price without first seeing a drawing.
    Thanks Jonathon, its basically the bearing side of the revolving ballnut design. I'm working on a drawing, but I'm not very good with the 3d stuff at the moment... Its really just an aluminium block approx 110 x 110 x 60 with an 80mm bore either side to take 2 angular contact bearings. Oh, and I need 2 of them please...
    I've just put some dimensions on some drawings I started, Hope you can understand them ok:
Name:	bearing block front elevation.png
ID:	8454Click image for larger version.
Name:	bearing block side elevation.png
    Not surprised your getting high quotes. It looks like a simple part on face value but start to think of how to machine it and your looking at working on up to 3 different orientations, 2 of which would require a a double sided jig to ensure the bearing recesses are aligned to a high tolerance.
    My advice would be to redesign the part otherwise you'll either pay a lot or I can't imagine anyone on here taking it on for peanuts.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    For two off, CNC isn't really worth it.
    A lathe with four jaw chuck would get the boring done. Bore center bore and one bearing recess, flip, dial in, bore other recess.
    Mill would soon sort out the flanges (either horizontal with a slab mill, or vertical with flycutter or large facemill). Then holes can be drilled in a pillar drill.
    If they're getting made from sawn stock, you'd have to mill at least 4 faces flat first (you could face the other two in the lathe), and to save set-up time you could machine the flanges at the same time before doing the boring.
    A couple notes about the drawings-
    1) what tolerance do you need on the bearing bores (i.e. interference, sliding)?
    2) if you're putting a 8mm bolt through the flange holes, you need them drilled larger than 8mm for clearance
    I could do them, but I just don't have the time.
    Nothing difficult about that - there are various ways to get the bearing bores concentric and machine the bottom face parallel to their axis. It looks like you've chosen 7208 bearings, which are bigger than you need for a 25mm ballscrew - I'd use 7207 instead to reduce the moment of inertia and cost. Have you drawn the rest of it?
    Edit: On the rotating ballnut mounts I have made I've tended to make the bearings a light interference fit, but I expect either would be fine. They need to be a sliding fit on the shaft to allow pre-loading.
    Thanks for the replies and advice guys!
    I wasn't really sure the best way to machine this piece, I do actually have a lathe, but I wouldn't really know where to start with getting the piece center....
    Thanks for that advice Jonathan, I was just allowing a little more clearance for the screw, but I think the 7207 would be better like you say.
  1. machining aluminium with 1.5kW spindle
    By routercnc in forum Spindles & Drive Motors
    Last Post: 15-02-2014, 02:55 AM
  2. RFQ: Aluminium frame Machining
    By mZeles in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 08:17 PM
  3. Machining Aluminium
    By Steff in forum Metalwork Discussion
    Last Post: 14-11-2012, 12:48 PM
  4. Breaking cutters machining aluminium
    By ukpete in forum Tool & Tooling Technology
    Last Post: 16-08-2011, 07:23 AM
  5. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 09:18 PM
