You'll be able to build a CNC router capable of machining aluminium for about (ballpark) the same cost as CNCing a reasonable size mill. the X1 size of machine sounds too small for your needs, sounds more X3 sort of size so you're looking at £1200 or so before you start. You'll still need to add ballscrews/motors/drives and like all things retrofitting to an existing table involves some machining operations that are hard if you dont have somehting to do them on to start with (or £2000+ for the commercial kit). Bootstrapping a new build is much easier IMHO. By all means consider an X1 to help build the bigger machine and keep it as a manual unit for those small/quick jobs where setting up the CNC is overkill.
What may be the best way to convert my Denford compact router to mach 3?
By suesi34e in forum Denford RoutersReplies: 34Last Post: 28-03-2017, 08:24 AM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
Starting point for a pick and place - cheapy CNC and convert or build my own?
By 8086 in forum Pick & Place MachinesReplies: 18Last Post: 30-11-2012, 03:20 PM -
BUILD LOG: A3 Router Build
NEW MEMBER: Hi Help to build a CNC router/milling machine
By peterashuk in forum New Member IntroductionsReplies: 1Last Post: 28-08-2010, 12:22 AM
