03-10-2012 #4
If you have the equipment and knowledge to do this then It's a no brainer to DIY IMO. If you want a very strong machine that doesn't take up much space then have a look at Sean's in link below.
Build this style machine in steel and you wont get cheaper for the same strength (use supported rails thou.!!). It will match any cheap mini mill. Problem with Mini mills and aluminium is the spindle speed.? Far too low to give decent feed rates. Higher spindle speeds are much better in alu and mixed with flood coolant then you can shift some serious material and still have a very nice finish.
http://www.mycncuk.com/forums/router...t-machine.html
What may be the best way to convert my Denford compact router to mach 3?
By suesi34e in forum Denford RoutersReplies: 34Last Post: 28-03-2017, 08:24 AM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
Starting point for a pick and place - cheapy CNC and convert or build my own?
By 8086 in forum Pick & Place MachinesReplies: 18Last Post: 30-11-2012, 03:20 PM -
BUILD LOG: A3 Router Build
NEW MEMBER: Hi Help to build a CNC router/milling machine
By peterashuk in forum New Member IntroductionsReplies: 1Last Post: 28-08-2010, 12:22 AM
