Thread: router unknow
  1. you need to zip it to attach it. Unfortunately the file hosting you have chosen requires you to sign up and I for one have more than enough junk mail. You might get more response if you upload it here... or in SketchUp File->Export->2D Graphic and export the drawing in png or jpg format and upload that here
    you shouldn't have to login
    i will zip tomorrow as its bed time now
    4share has obviously changed their sharing policy
    anyway here it is in zip format
    Attached Files Attached Files
  4. Quote Originally Posted by Jed Clampit View Post
    Couple of thoughts...
    That X screw looks heavy... what size is it meant to be? Also with the stepper inside the frame you've limited X travel - Is that what you intended? I also noted the misalignment of the screw on the rear bearing but thats just a drawing issue.
Name:	my cnc v6.png
