Thread: operation cnc
    Hi All.
    Quiteness is due to a lot of thinking, and sketching.
    Towards the end of last week, I was put in touch with a guy who was selling a used "branded" machine, capable of cutting 8x4 sheets, with vaccum bed etc. It was going cheap due to all the electrics being shot. However, cutting a long story short I dont think its still a viable option, he was initially talking about a lot less money than he is now, then there is the logistics of moving it etc, and I dont think its going to be exactly what im after.
    Im thinking 1400mm x 800mm x 300mm. with the conventional setup (having x being the widest axis) and having a shorter y. Unlike what I previously suggested earlier in this thread.
    Being Realistic, I simply do not have the skills to be able to pull off a spun- ball screw nut. Manufacturing all the housing etc is just out of my depth. (as previously suggested), so my first question is
    1,)What is the maximum length I can have, with a conventional 'spun-ballscrew' setup (keeping the nut static)?
    I intend to have two screws for the x axis, (one on either side)
    The ballscrews descibed in the ebay auctions (linearmotionbearings2008) detail as being 'end machined'
    4 pcs of anti backlash ballscrews RM1605-350/800/1450/1450mm-C7(4screws+4ballnuts+4endmachined)
    4PCS NUT HOUSINGS/BRACKETS FOR THESE 3 BALLNUTS
    4 sets of BK/BF12 with locknuts and circlips+ 4pcs 6.35mm*10mm flexible couplers
    Linear slide rails SBR20-600mm(2 supported rails+4 SBR20UU bearing blocks)
    Linear slide rails SBR20-300/1400mm(4 supported rails+8 SBR20UU bearing blocks)
    so with the 'flexible couplers' also supplied in the kit, I assume will fit my steppers ?
    Nema23 Stepper Motor 3.1Nm x 3
  2. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  3. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  4. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
  5. BUILD LOG: Operation Clueless, CNCRP 4848 Build Log Eventually.
    By BedlamRik in forum DIY Router Build Logs
    Last Post: 28-12-2012, 12:39 AM
