Thread: operation cnc
Page 18 of 18 FirstFirst ... 8161718
  1. #171
    so, its all now going. Im working out bits as I go along slowly but surely.
    So Im milling my mdf spoil board flat so, the machine is going
    Y0,
    Y800
    X2
    Y0
    X4
    Y800
    etc etc
    side to side stepping back 2 on every pass
    now.. if I press STOP in mach3... the machine abruptly comes to a stop. I press goto Z and I suspect the Y has slipped a little? Its more noticeable if I start the program again... the pocket its milling out of my spoilboard seems to have moved over slightly?
    does this make sense to anybody?
    matt
  2. #172
    are you pressing the stop button you numpty instead of the pause?
  3. #173
    yes. what a sausage
  4. #174
    Always press FEED HOLD other wise your 99% sure to lose position if travelling at any reasonable feed rate.
    Just be aware that FEED HOLD doesn't always stop instantly and will depend on the code and the LOOK AHEAD setting in Mach to how long it takes.
  5. Creaky - i'm researching gantry's at the moment while trying to design mine...could you possibly post a picture showing how you mounted the Y-axis motor to the back of your gantry?
  2. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  3. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  4. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
  5. BUILD LOG: Operation Clueless, CNCRP 4848 Build Log Eventually.
    By BedlamRik in forum DIY Router Build Logs
    Last Post: 28-12-2012, 12:39 AM
