Thread: operation cnc
04-10-2012 #7that's a good sign :)spent most of last night laying awake. I get a bit like this when im 'on one' with something like this.
its interesting and quite easy at the outset of any new design... in my experience though it gets harder the further you get into the nuts and bolts of the job... one small amendment can have a bitch of a knock on effect :(
its frustrating when you want to get building but try to design the knickers out of it before you commit because those amendments and knock on effects can be heart breaking if your half way through a build
having a Y axis that is longer than your X is pretty unconventional for obvious reasons... i can see your logic in expandability, if you will definitely expand if all works well i would keep the faith and go for glory at the outset on the proviso that the consensus was that your design would do what you required
iv not built a machine of that size but there are a few people on here that will give you a good idea if its doable 3m x 3m is quite a large machine... i'm not sure anyone has built one of that size on this forum ?
good luck getting to sleep lol
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
clunks / missing steps - DM856 and single pulse operation
By dsc in forum Motor Drivers & ControllersReplies: 37Last Post: 09-12-2013, 02:22 PM -
screening / glitchy operation - sanity check
By dsc in forum General ElectronicsReplies: 21Last Post: 01-12-2013, 11:35 PM -
CNC3040 erratic stepper motor operation (fixed)
By DanielF in forum Motor Drivers & ControllersReplies: 0Last Post: 30-12-2012, 07:52 AM -
BUILD LOG: Operation Clueless, CNCRP 4848 Build Log Eventually.
By BedlamRik in forum DIY Router Build LogsReplies: 12Last Post: 28-12-2012, 12:39 AM
