Thread: operation cnc
    Looking really good and the ballless nut was just the ticket.
    evening all... finding it hard to shut you lot up arent I... obviously your just lost for words ;D
    anyway... get this.
    So, I emailed chai, saying il have four of those ball nut housings to suite 1610 rails.
    assuming he would send me the ones on his ebay shop er... these
    but .... he must of read my previous posts.... or something because I actually recieved these
    Im not having a moan, its not his fault. I didnt specify part numbers or whatever... these are actually the ones id prefer!.
    anyway, so you may also notice the brand new ball-nut.....
    how do I put that on the orphan screw? without dropping my balls everywhere?
    Matt
    Quote Originally Posted by kingcreaky View Post
    Just screw the nut on to the screw. Make sure you push the tube that's in the ballnut against the end of the ballscrew (so it's covering the end machining) as that will ensure the balls cannot drop out. Just do it slowly and carefully and you shouldn't have any problems.
    A tip I was given for removing and replacing the nut, but have not yet tried is that standard airline hose not (curly-wurly) is a really good fit (tight but flexible) and the nut can be wound on and off the screw quite safely. G.
  2. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  3. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  4. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
  5. BUILD LOG: Operation Clueless, CNCRP 4848 Build Log Eventually.
    By BedlamRik in forum DIY Router Build Logs
    Last Post: 28-12-2012, 12:39 AM
