Thread: Gantry design question
09-10-2012 #13
Sorry but that's not true at all, I could quite easily manufacture a complex shape without the use of a vacuum just by using the right weight cloth and simply laying the cloth around a mould or covering the part if I was just skinning it. The carbon fibre part that I made would look just the same as a part made using a resin infusion system but that's where the similarities end. The part produced by resin infusion would be far lighter & stronger than the part I made, what the vacuum actually does is remove all the excess resin which cant be removed from a traditional type wet lay up. The strength comes from the layers of cloth being closely bonded together, the less resin that is present the stronger the bond.
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Alu 40x40 frame - strength/design question
By Rogue in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-11-2011, 05:02 PM
