Thread: Gantry design question
09-10-2012 #18
I like the ingenuity but I think it's kind of a waste of expensive material. CF is very stiff for its weight, but steel is equally stiff. Since the weight isn't much issue, use steel. Want damping, then use steel box section with foam or sand inside. For sheets of aluminium or steel use constrained layers (I mentioned green glu before, bitumen and butyl rubber sheet is also good).
I design loudspeakers and in this area we pay a lot of attention to damping sheet materials for the speaker boxes. The BBC did a great amount research on this and concluded that constrained layer damping was most effective, although making it stiff was not the goal. So IMO use stiff materials and constrained layers, but don't worry much about weight.
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Alu 40x40 frame - strength/design question
By Rogue in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-11-2011, 05:02 PM
