09-10-2012 #9
As an actress once said... its not how big it is, its what you do with it....
The vast majority of machines built by the members here are using 3Nm steppers or smaller; very few have needed to go bigger. When considering a 2.5m axis you have to think long and hard about how you're going to drive it. Spinning two long heavy screws is one option and that needs powerful motors but for machining wood 3Nm is usually OK. But a better option is spinning ballnuts and that needs a much less force and is far more efficient. An alternative is a static belt drive or rack and pinion... all need relatively small motors though there are tradeoffs to be made. If you were talking about a large steel mill, a Bridgeport or similar with a heavy table on dovetail ways then 4Nm might be the only thing that'll work...
Vibration, mass and massive arguments
By Rogue in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 03-11-2014, 11:24 PM -
RFQ: Daft Punk Build
By FIREWIRE in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-04-2013, 02:34 AM -
Damping Machine Frame
By Tenson in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 28-01-2013, 01:44 PM -
I promise I will stop asking daft question soon. Ish.
By D.C. in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 15-10-2012, 11:37 PM -
NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
By m0nk3hjam in forum New Member IntroductionsReplies: 6Last Post: 17-08-2010, 02:32 AM
