I tired back to front and upside down.. it still doesn't do as expected.
I guess I just need to try lots of configurations until I find one that works right. What I thought should be 1/5th was actually 1/2 stepping.
What is the point of imperial and metric microstepping? Surely it doesn't really make any difference since the ballnut can position at any point on the ballscrew?
09-10-2012 #2
Interestingly page 8 of this document says that the last 4 switches should be OFF,OFF,ON,ON to get 1/10, but the opposite is written on the driver (ON,ON,OFF,OFF). That would imply that you read '1' on the driver as meaning 'ON', so to get 1/5 try setting the last 4 switches to ON,OFF,OFF,OFF.
Just to give you more options I suppose. If you're using the driver in some other system where software doesn't work out the number of steps for you it may be convenient to, for instance, have 1/5 as 1000 step/rev is an easy number to work with.
Use of microstepping, external motion control boards, and related issues
By Neale in forum General ElectronicsReplies: 0Last Post: 11-06-2014, 12:17 PM -
mach3, steps & microstepping
By martin54 in forum Artsoft Mach (3 & 4)Replies: 10Last Post: 10-04-2013, 08:00 PM -
eBay: 3 x PM752 Microstepping Drivers
By Iwant1 in forum Items On eBay UKReplies: 18Last Post: 24-08-2012, 11:47 PM -
The worth of microstepping?
By stuart576 in forum Stepper & Servo MotorsReplies: 4Last Post: 18-01-2012, 09:27 PM
