Thread: Hold down solution
11-10-2012 #1
I was looking around for a way to secure my work pieces and stumbled across this pic:
Does anyone know what the rail is called between the mdf? That would be perfect for my machine. The only thing I can find is a unistrut variant but is a bit thick for what I want. Thankingyoo
11-10-2012 #2
Its probably t-slot bar like this:http://uk.sotmau.com/Incra-MITERCHAN...nel-p18731804/
11-10-2012 #3
Think its called t-slot track SHOP FOX 24" ALUMINUM T-SLOT T-TRACK WOOD & METAL WORK | eBay must be a UK supplier tho...
edit: Here you go:
http://www.axminster.co.uk/axminster...ack-prod840636
http://www.rutlands.co.uk/cgi-bin/ps...:1,0,0,1::::16
11-10-2012 #4
Exactly what I need. Thanks
11-10-2012 #5
Thats what i use on my machine and it is what they use for making hangers for cable trays. I got mine from an electrical factor, look for the nuts/ bolts that go with it as well which i use for hold downs as they twist into position
Work hold down
By gorbo in forum Woodwork DiscussionReplies: 16Last Post: 27-03-2020, 09:15 AM -
mini hold down clamps
By Daedelus in forum Tool & Tooling TechnologyReplies: 4Last Post: 05-03-2014, 09:42 PM -
Hold down clamps, what do you use?
By Web Goblin in forum Machine DiscussionReplies: 16Last Post: 14-04-2012, 11:45 PM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Workpiece hold down by glue
By Robin Hewitt in forum Machine DiscussionReplies: 2Last Post: 30-09-2010, 08:22 PM
