    It depends how fast you need the machine to go. If you're happy with 6m/min, then as irving has said 1500mm is OK. If you need more you either have to use more bearings, use a higher pitch screw, increase the diameter of the screw, or rotate the nut. Which you choose depends on how much faster you need the axis to travel.
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  1. maximum deflection - sanity check
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 11-02-2013, 09:33 AM
  2. Replies: 38
    Last Post: 31-12-2012, 02:42 PM
  3. WANTED: 2 x 20/16mm supported round rail
    By D-man in forum Items Wanted
    Last Post: 30-10-2011, 11:08 PM
  4. maximum amps
    By petejw in forum General Electronics
    Last Post: 11-08-2009, 11:40 PM
