    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Hi all,
    I am relatively new to DIY CNC machines. I have been looking for one pre-essembled so I can load my PC with software and start learning how to use it all. I want to mill and engrave aluminum as well as carbon fiber sheet, plastics and hard wood. Just as a hobby and to make things for my workshop at home.
    I do not want to spend a fortune. I have found one for sale, here in France. Please could you take a look at it and advise me what it might or might not me capable of ?.
    I have used Google translate to get the description into English the best I could.
    - Course X: 470mm (560mm with less possibility of rigidity)
    - Travel Y: 300mm
    - Travel Z: 150mm
    Engine Transmission Thread: toothed belt on 3 axes
    Transmission ballscrew on 3 axes:
    - Y: Steinmeyer 20mm (High Quality)
    - Z: Trolley mounted on THK rail, screws 16mm (High Quality)
    - X: ball screw 16mm (Brand unknown)
    runners:
    - X and Y: Rails cylindrical hardened steel and chrome plated 25mm
    - Z: prismatic Rail
    Spindle :
    - Proxxon BFW 40 / E control module with 250W
    - 900 to 6000 rev / min
    - Bearing robust planned for machining aluminum
    Electronics:
    - Map mechatronics 4 axes ( 1/8 1/4 1/2 and 1) with many inputs and outputs for accessories.
    - 4 probotix Motors NEMA 23 400 oz / in
    (1 additional engine for a 4th axis)
    Milling with sensors limit of Y and Z
    Maximum forward speed: 1400mm/min
    Accuracy: 0.005 mm
    aluminum vacuum table (can be changed)
    Comes with:
    - Lots of strawberries
    - Case control
    - Connectors
    - 1 Motor NEMA 23 additional
    - House of protection
    Machine ready
    Milling machine operated under Mach3 but can very well with other software.
    Hours of Operation:
    I give up to 5 hours of operation
    The machining was the longest 50 minutes
    The total price of the machine parts came easily to 2000 Euros (Borderless or labor).
ID:	7142   Click image for larger version.
ID:	7143   Click image for larger version.
