  1. #12
    Looks good, how did you join the side plates to the ends of the big box section ? I can see there are 6 bolts used somehow.
    The big box section (140mm x 60mm x 5mm) has welded 12mm steel plates on the both ends. Then the ends are machined to get 90 degree. I used 6 bolts M8 to bolt the sides.
  2. The Following User Says Thank You to DigiSoft For This Useful Post:
