Thread: CNC Routing Nylon 6 Material
I am very interested in this thread. I too broke 2 x 3mm cutters at only 1mm DOC - More than likley my feed & speed was wrong as the cutters was BRAND NEW.
My Speed and feed(off the top of my head) was approximately 640 and 800mm/m and speed was around 200hz and also tried 250-280hz on 1.5kw spindle(not sure what that relates to in RPM but i guess about 12k - 15k)
Craig
20-10-2012 #2
I tried using an airline with the feed/speed I quoted and it did improve the finish a little, but the finish was good enough without and I couldn't have gone any faster without the tool deflecting too much, hence I didn't bother with it. My machine isn't especially rigid, otherwise it may have been more worthwhile.
The risk here is if you start will too low a feedrate (without also using a very low spindle speed, but there's a limit to how slow you can go with the VFD driven spindles) you can risk the material melting on to the cutter which can break the cutter just as fast as going too fast. This is probably what's happening to Craig as with a 4mm cutter at 200hz (12000rpm) the feedrate should be around 950mm/min for single flute or 1900mm/min for two flute.
When trying a new material or tool I always start with 'normal' or recommended feedrates and a shallow cut, then gradually increase the depth of cut.
Either way it will help a lot to see a picture of the machine this is being cut on to give an idea of how rigid it is.
You can press the >> key on the VFD to scroll through the readings until you find RPM if you're not sure. An easy way to remember it is that you know the spindle must do 24000rpm at 400Hz, since that's the maximum, so just work it out proportionately from that. Hence 250Hz is 250/400*24000=14400rpm and 280Hz is 16800rpm.
20-10-2012 #3
Delrin & Nylon S & F please
By craigrobbo in forum Machine DiscussionReplies: 2Last Post: 21-07-2012, 12:19 PM -
RFQ: Bracket parts from Nylon
By egimson in forum Projects, Jobs & RequestsReplies: 4Last Post: 18-04-2012, 12:20 AM -
RFQ: Parts CNC machined from Nylon
By egimson in forum Projects, Jobs & RequestsReplies: 3Last Post: 02-04-2012, 08:40 PM -
WANTED: Roller end caps from pvc or nylon Help!
By stevedunn in forum Items WantedReplies: 10Last Post: 19-09-2011, 10:09 PM -
sourcing material for a DIY build
By mmcp42 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-01-2011, 10:23 PM
