	21-10-2012 #1
Hi all,
i'm new in cnc world.
I have a new homebuilt 3 axis cnc with mach3 but have some problems.
I've setup everything and moved all axis with keyboard and all seems fine.
The problem is that when running any gcode ( can be just a square ) the X axis does not move to the left ( only moves to the right ).
Mach3 keeps counting but the axis does not move from right to left. All other axis move fine.
X axis also moves fine in both directions when homming, when moving to a saved fixture positionand when jogging.
I cannot understand why does not move when running a gcode.
Can anyone help me out ?
I thank you in advance
Best regards
Rui
Help! Moving a big lathe...
By Jonathan in forum General DiscussionReplies: 21Last Post: 27-12-2015, 11:54 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
G-Code for camshaft on a 4th axis
By rnr107 in forum Programmers CornerReplies: 5Last Post: 10-11-2012, 12:58 PM -
Running 4 axis from a ps806 or sps705 psu
By jonbabbz in forum General ElectronicsReplies: 21Last Post: 14-07-2012, 09:50 AM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
