Thread: Aluminium box section
Problem with steel though DC is that people have said it is not flat enough for rails to be mounted on so you are then looking at some way to get it flat for the rails, if you don't have access to grinding/machining equipment how do you get it flat enough without having it machined by someone else which is another expense.
25-10-2012 #2
I was looking at using west system 209 super slow low viscoscity epoxy (much cheaper than the specialist stuff) and stumbled across this thread on cnczone:
New Machine Build 5.5' x 10' steel router - CNCzone.com-The Largest Machinist Community on the net!
25-10-2012 #3
The Following User Says Thank You to WandrinAndy For This Useful Post:
Box section tube straightness
By jimbojones1000 in forum Metalwork DiscussionReplies: 7Last Post: 18-02-2014, 04:11 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Help with name of aluminium section plz
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 02-12-2012, 10:01 PM -
spindle cross section view
By routercnc in forum Tool & Tooling TechnologyReplies: 20Last Post: 05-08-2011, 12:55 AM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM
