25-10-2012 #1
Hi, I have finally got my machine up and running and now I'm trying to trouble shoot another problem. When machining it seems like the first pass is OK, then the second goes off to the left a little, then the third almost seems like it has gone back to the correct place. After that the Profile toolpath runs also in the correct place, its kind of confusing.
I have ran it twice with the same effect, so I'm not sure if its my machine or the code, made with Vectric Aspire, the toolpath looks ok in the software.
Here is the image
And the G code:
Code:( shield ) ( File created: Thursday, October 25, 2012 - 02:36 PM) ( for Mach2/3 from Vectric ) ( Material Size) ( X= 150.000, Y= 150.000, Z= 6.000) () (Toolpaths used in this file:) (Pocket 1) (Profile 1) (Tools used in this file: ) (1 = End Mill {2 mm}) N110G00G21G17G90G40G49G80 N120G71G91.1 N130T1M06 N140 (End Mill {2 mm}) N150G00G43Z20.000H1 N160S9000M03 N170(Toolpath:- Pocket 1) N180() N190G94 N200X0.000Y0.000F1800.0 N210G00X10.084Y1.490Z6.000 N220G1Z-0.833F1200.0 N230G2X10.610Y1.640I0.526J-0.850F1800.0 N240G1X10.919 N250G2X11.815Y1.085I0.000J-1.000 N260G1X33.655Y-42.857 N270G1X34.084Y-43.963 N280G1X34.389Y-44.828 N290G1X34.500Y-45.215 N300G1X34.559Y-45.527 N310G1X34.571Y-45.881 N320G2X34.127Y-46.746I-0.999J-0.034 N330G1X32.131Y-48.080 N340G1X31.153Y-48.713 N350G1X30.080Y-49.371 N360G1X28.944Y-50.036 N370G1X27.772Y-50.693 N380G1X26.592Y-51.327 N390G1X25.430Y-51.924 N400G1X24.312Y-52.468 N410G1X23.274Y-52.942 N420G1X21.306Y-53.804 N430G1X17.047Y-55.216 N440G1X15.842Y-55.579 N450G1X14.645Y-55.910 N460G1X13.442Y-56.212 N470G1X12.218Y-56.490 N480G1X10.959Y-56.747 N490G1X9.651Y-56.985 N500G1X5.796Y-57.595 N510G1X-4.160Y-57.711 N520G1X-5.332Y-57.551 N530G1X-8.879Y-57.154 N540G1X-12.499Y-56.425 N550G1X-14.306Y-55.996 N560G1X-15.227Y-55.752 N570G1X-17.068Y-55.217 N580G1X-18.911Y-54.619 N590G1X-20.731Y-53.968 N600G1X-22.501Y-53.271 N610G1X-24.213Y-52.531 N620G1X-25.828Y-51.762 N630G1X-27.533Y-50.908 N640G1X-29.848Y-49.515 N650G1X-31.736Y-48.347 N660G1X-33.086Y-47.457 N670G1X-34.007Y-46.795 N680G2X-34.320Y-45.538I0.583J0.812 N690G1X-29.513Y-35.844 N700G1X-11.200Y0.901 N710G2X-10.305Y1.455I0.895J-0.446 N720G1X-10.085 N730G2X-9.559Y1.305I0.000J-1.000 N740G1X0.099Y-4.680 N750G1X10.084Y1.490 N760G1X9.663Y2.170 N770G2X10.610Y2.440I0.947J-1.531 N780G1X10.919 N790G2X12.531Y1.441I0.000J-1.800 N800G1X34.387Y-42.533 N810G1X34.834Y-43.685 N820G1X35.151Y-44.584 N830G1X35.280Y-45.030 N840G1X35.356Y-45.439 N850G1X35.371Y-45.853 N860G2X34.572Y-47.412I-1.799J-0.061 N870G1X32.571Y-48.748 N880G1X31.580Y-49.390 N890G1X30.491Y-50.058 N900G1X29.341Y-50.730 N910G1X28.157Y-51.394 N920G1X26.964Y-52.035 N930G1X25.788Y-52.639 N940G1X24.654Y-53.192 N950G1X23.600Y-53.673 N960G1X21.594Y-54.551 N970G1X17.286Y-55.980 N980G1X16.064Y-56.347 N990G1X14.849Y-56.683 N1000G1X13.628Y-56.990 N1010G1X12.386Y-57.272 N1020G1X11.111Y-57.532 N1030G1X9.787Y-57.773 N1040G1X5.862Y-58.394 N1050G1X-4.210Y-58.512 N1060G1X-5.430Y-58.345 N1070G1X-9.001Y-57.945 N1080G1X-12.670Y-57.207 N1090G1X-14.505Y-56.771 N1100G1X-15.441Y-56.523 N1110G1X-17.303Y-55.982 N1120G1X-19.169Y-55.377 N1130G1X-21.012Y-54.717 N1140G1X-22.803Y-54.012 N1150G1X-24.543Y-53.260 N1160G1X-26.183Y-52.479 N1170G1X-27.919Y-51.610 N1180G1X-30.264Y-50.198 N1190G1X-32.163Y-49.023 N1200G1X-33.544Y-48.112 N1210G1X-34.474Y-47.444 N1220G2X-35.036Y-45.183I1.050J1.462 N1230G1X-30.230Y-35.488 N1240G1X-11.916Y1.257 N1250G2X-10.305Y2.255I1.611J-0.803 N1260G1X-10.085 N1270G2X-9.137Y1.985I0.000J-1.800 N1280G1X0.103Y-3.741 N1290G1X9.663Y2.170 N1300G00Z6.000 N1310G00X11.673Y3.128 N1320G1Z-0.833F1200.0 N1330G1X11.736Y3.108F1800.0 N1340G1X11.740Y3.170 N1350G1X11.673Y3.128 N1360G00Z6.000 N1370G00X13.806Y3.805 N1380G1Z-0.833F1200.0 N1390G1X25.007Y10.712F1800.0 N1400G1X25.467Y10.870 N1410G2X26.688Y10.364I0.323J-0.946 N1420G1X37.387Y-11.413 N1430G1X46.546Y-29.956 N1440G1X47.184Y-31.538 N1450G1X47.313Y-31.895 N1460G1X47.408Y-32.269 N1470G1X47.435Y-32.693 N1480G1X47.349Y-33.118 N1490G1X47.183Y-33.487 N1500G1X46.781Y-34.106 N1510G1X44.741Y-36.711 N1520G1X43.334Y-38.339 N1530G1X41.847Y-39.948 N1540G1X40.371Y-41.444 N1550G1X39.666Y-42.119 N1560G1X37.747Y-43.837 N1570G2X36.188Y-43.534I-0.663J0.748 N1580G1X13.425Y2.220 N1590G2X13.321Y2.702I0.895J0.445 N1600G1X13.332Y2.989 N1610G2X13.806Y3.805I0.999J-0.036 N1620G1X13.386Y4.486 N1630G1X24.491Y11.335 N1640G2X24.854Y11.506I0.945J-1.532 N1650G1X25.208Y11.627 N1660G2X27.406Y10.716I0.582J-1.703 N1670G1X38.105Y-11.059 N1680G1X47.276Y-29.629 N1690G1X47.931Y-31.253 N1700G1X48.078Y-31.659 N1710G1X48.202Y-32.144 N1720G1X48.225Y-32.513 N1730G2X48.193Y-32.979I-1.797J-0.111 N1740G1X48.156Y-33.165 N1750G2X48.032Y-33.550I-1.765J0.354 N1760G1X47.887Y-33.872 N1770G1X47.432Y-34.571 N1780G1X45.361Y-37.217 N1790G1X43.931Y-38.872 N1800G1X42.426Y-40.500 N1810G1X40.929Y-42.017 N1820G1X40.212Y-42.703 N1830G1X38.277Y-44.436 N1840G2X35.472Y-43.891I-1.194J1.347 N1850G1X12.709Y1.864 N1860G2X12.522Y2.730I1.612J0.802 N1870G1X12.532Y3.018 N1880G2X13.386Y4.486I1.799J-0.065 N1890G00Z6.000 N1900G00X-11.216Y2.890 N1910G1Z-0.833F1200.0 N1920G1X-11.152Y2.913F1800.0 N1930G1X-11.230Y2.961 N1940G1X-11.216Y2.890 N1950G00Z6.000 N1960G00X-25.977Y10.311 N1970G1Z-0.833F1200.0 N1980G1X-25.843Y10.450F1800.0 N1990G2X-24.597Y10.606I0.720J-0.694 N2000G1X-15.185Y4.776 N2010G1X-14.121Y4.099 N2020G1X-13.732Y3.831 N2030G1X-13.416Y3.589 N2040G1X-13.140Y3.330 N2050G1X-12.990Y3.121 N2060G2X-12.832Y2.780I-0.813J-0.583 N2070G1X-12.805Y2.671 N2080G2X-12.812Y2.160I-0.970J-0.243 N2090G1X-12.869Y1.956 N2100G1X-13.079Y1.563 N2110G1X-35.662Y-43.861 N2120G2X-36.558Y-44.416I-0.895J0.445 N2130G1X-36.768 N2140G2X-37.441Y-44.156I0.000J1.000 N2150G1X-39.860Y-41.943 N2160G1X-40.443Y-41.375 N2170G1X-41.676Y-40.116 N2180G1X-42.950Y-38.753 N2190G1X-44.181Y-37.381 N2200G1X-45.289Y-36.090 N2210G1X-46.192Y-34.974 N2220G1X-46.552Y-34.495 N2230G1X-46.839Y-34.078 N2240G1X-47.051Y-33.713 N2250G1X-47.157Y-33.460 N2260G1X-47.210Y-33.194 N2270G1Y-32.918 N2280G2X-47.106Y-32.475I1.000J0.000 N2290G1X-34.013Y-5.953 N2300G1X-26.154Y10.057 N2310G2X-25.977Y10.311I0.898J-0.440 N2320G1X-26.553Y10.866 N2330G1X-26.419Y11.005 N2340G2X-24.176Y11.286I1.296J-1.249 N2350G1X-14.759Y5.453 N2360G1X-13.680Y4.767 N2370G1X-13.261Y4.478 N2380G1X-12.898Y4.199 N2390G1X-12.535Y3.860 N2400G1X-12.340Y3.587 N2410G2X-12.056Y2.975I-1.463J-1.049 N2420G1X-12.029Y2.865 N2430G2X-12.041Y1.945I-1.746J-0.437 N2440G1X-12.069Y1.847 N2450G2X-12.215Y1.481I-1.734J0.484 N2460G1X-34.946Y-44.217 N2470G2X-36.558Y-45.216I-1.612J0.801 N2480G1X-36.768 N2490G2X-37.979Y-44.748I0.000J1.800 N2500G1X-40.412Y-42.522 N2510G1X-41.008Y-41.942 N2520G1X-42.255Y-40.669 N2530G1X-43.540Y-39.294 N2540G1X-44.782Y-37.909 N2550G1X-45.903Y-36.602 N2560G1X-46.823Y-35.466 N2570G1X-47.201Y-34.962 N2580G1X-47.516Y-34.507 N2590G1X-47.770Y-34.069 N2600G1X-47.926Y-33.694 N2610G1X-48.010Y-33.272 N2620G1Y-32.918 N2630G2X-47.823Y-32.120I1.800J0.000 N2640G1X-34.731Y-5.599 N2650G1X-26.873Y10.410 N2660G2X-26.553Y10.866I1.616J-0.792 N2670G00Z6.000 N2680G00X-39.574Y20.484 N2690G1Z-0.833F1200.0 N2700G1X-39.533Y20.500F1800.0 N2710G1X-39.584Y20.532 N2720G1X-39.574Y20.484 N2730G00Z6.000 N2740G00X-41.184Y20.301 N2750G1Z-0.833F1200.0 N2760G2X-41.221Y19.490I-0.931J-0.364F1800.0 N2770G1X-48.285Y5.352 N2780G1X-55.401Y-8.841 N2790G2X-56.693Y-9.310I-0.894J0.448 N2800G1X-56.721Y-9.298 N2810G2X-57.209Y-8.845I0.398J0.917 N2820G1X-57.289Y-8.691 N2830G1X-57.414Y-8.291 N2840G1X-57.541Y-7.774 N2850G1X-58.019Y-3.582 N2860G1X-58.009Y1.705 N2870G1X-57.977Y3.034 N2880G1X-57.920Y4.287 N2890G1X-57.836Y5.494 N2900G1X-57.722Y6.683 N2910G1X-57.576Y7.884 N2920G1X-57.396Y9.125 N2930G1X-57.021Y11.295 N2940G1X-56.843Y12.171 N2950G1X-56.438Y13.943 N2960G1X-55.966Y15.741 N2970G1X-55.438Y17.538 N2980G1X-54.861Y19.310 N2990G1X-54.241Y21.034 N3000G1X-53.587Y22.681 N3010G1X-52.903Y24.236 N3020G1X-52.061Y26.050 N3030G2X-51.154Y26.629I0.907J-0.421 N3040G1X-50.800 N3050G2X-50.274Y26.479I0.000J-1.000 N3060G1X-41.752Y21.204 N3070G2X-41.347Y20.717I-0.526J-0.850 N3080G1X-41.184Y20.301 N3090G1X-40.439Y20.592 N3100G2X-40.505Y19.133I-1.677J-0.655 N3110G1X-47.570Y4.994 N3120G1X-54.686Y-9.200 N3130G2X-57.012Y-10.044I-1.609J0.807 N3140G1X-57.040Y-10.032 N3150G2X-57.917Y-9.216I0.717J1.651 N3160G1X-58.031Y-8.999 N3170G1X-58.185Y-8.506 N3180G1X-58.330Y-7.915 N3190G1X-58.819Y-3.628 N3200G1X-58.809Y1.718 N3210G1X-58.776Y3.062 N3220G1X-58.719Y4.333 N3230G1X-58.633Y5.560 N3240G1X-58.518Y6.769 N3250G1X-58.369Y7.990 N3260G1X-58.186Y9.248 N3270G1X-57.806Y11.446 N3280G1X-57.625Y12.340 N3290G1X-57.215Y14.134 N3300G1X-56.737Y15.955 N3310G1X-56.203Y17.775 N3320G1X-55.618Y19.570 N3330G1X-54.989Y21.317 N3340G1X-54.327Y22.986 N3350G1X-53.631Y24.569 N3360G1X-52.787Y26.387 N3370G2X-51.154Y27.429I1.633J-0.758 N3380G1X-50.800 N3390G2X-49.853Y27.160I0.000J-1.800 N3400G1X-41.331Y21.884 N3410G2X-40.601Y21.009I-0.947J-1.530 N3420G1X-40.439Y20.592 N3430G00Z6.000 N3440G00X-21.056Y47.608 N3450G1Z-0.833F1200.0 N3460G1X-21.006Y47.776F1800.0 N3470G1X-21.192Y47.695 N3480G1X-21.056Y47.608 N3490G1X-21.457Y46.915 N3500G1X-20.592Y46.362 N3510G1X-19.761Y49.155 N3520G1X-21.081Y48.617 N3530G1X-22.152Y48.147 N3540G1X-22.870Y47.813 N3550G1X-21.457Y46.915 N3560G1X-21.887Y46.241 N3570G1X-20.127Y45.115 N3580G1X-18.535Y50.471 N3590G1X-20.294Y49.807 N3600G1X-21.394Y49.353 N3610G1X-22.482Y48.876 N3620G1X-23.557Y48.375 N3630G1X-24.509Y47.906 N3640G1X-21.887Y46.241 N3650G1X-22.317Y45.566 N3660G1X-19.662Y43.867 N3670G1X-17.324Y51.734 N3680G1X-18.322Y51.398 N3690G1X-19.463Y50.986 N3700G1X-20.591Y50.550 N3710G1X-21.707Y50.089 N3720G1X-22.811Y49.605 N3730G1X-23.903Y49.097 N3740G1X-24.981Y48.565 N3750G1X-26.111Y47.975 N3760G1X-22.317Y45.566 N3770G1X-22.747Y44.891 N3780G1X-19.197Y42.620 N3790G1X-16.129Y52.947 N3800G1X-17.415Y52.548 N3810G1X-18.585Y52.154 N3820G1X-19.743Y51.735 N3830G1X-20.888Y51.292 N3840G1X-22.021Y50.825 N3850G1X-23.141Y50.334 N3860G1X-24.248Y49.818 N3870G1X-25.343Y49.279 N3880G1X-26.425Y48.715 N3890G1X-27.676Y48.021 N3900G1X-22.747Y44.891 N3910G1X-23.177Y44.217 N3920G1X-18.732Y41.373 N3930G1X-14.947Y54.114 N3940G1X-16.463Y53.683 N3950G1X-17.662Y53.309 N3960G1X-18.849Y52.909 N3970G1X-20.023Y52.485 N3980G1X-21.185Y52.035 N3990G1X-22.334Y51.561 N4000G1X-23.470Y51.063 N4010G1X-24.594Y50.540 N4020G1X-25.705Y49.992 N4030G1X-26.802Y49.420 N4040G1X-27.887Y48.824 N4050G1X-29.212Y48.049 N4060G1X-23.177Y44.217 N4070G1X-23.607Y43.542 N4080G1X-18.267Y40.126 N4090G1X-13.777Y55.241 N4100G1X-15.466Y54.804 N4110G1X-16.693Y54.450 N4120G1X-17.909Y54.070 N4130G1X-19.113Y53.665 N4140G1X-20.303Y53.234 N4150G1X-21.482Y52.778 N4160G1X-22.647Y52.298 N4170G1X-23.800Y51.792 N4180G1X-24.940Y51.261 N4190G1X-26.066Y50.706 N4200G1X-27.180Y50.126 N4210G1X-28.280Y49.521 N4220G1X-29.367Y48.891 N4230G1X-30.719Y48.058 N4240G1X-23.607Y43.542 N4250G1X-24.037Y42.868 N4260G1X-17.802Y38.878 N4270G1X-12.617Y56.333 N4280G1X-14.422Y55.908 N4290G1X-15.679Y55.575 N4300G1X-16.924Y55.216 N4310G1X-18.156Y54.831 N4320G1X-19.376Y54.420 N4330G1X-20.584Y53.983 N4340G1X-21.778Y53.521 N4350G1X-22.960Y53.034 N4360G1X-24.129Y52.521 N4370G1X-25.285Y51.983 N4380G1X-26.428Y51.419 N4390G1X-27.558Y50.831 N4400G1X-28.673Y50.217 N4410G1X-29.776Y49.579 N4420G1X-30.864Y48.916 N4430G1X-32.200Y48.051 N4440G1X-24.037Y42.868 N4450G1X-24.467Y42.193 N4460G1X-17.337Y37.631 N4470G1X-11.640Y56.811 N4480G2X-11.415Y57.402I4.026J-1.198 N4490G1X-13.333Y56.995 N4500G1X-14.619Y56.684 N4510G1X-15.892Y56.346 N4520G1X-17.154Y55.982 N4530G1X-18.403Y55.592 N4540G1X-19.640Y55.175 N4550G1X-20.864Y54.733 N4560G1X-22.075Y54.264 N4570G1X-23.274Y53.770 N4580G1X-24.459Y53.250 N4590G1X-25.631Y52.704 N4600G1X-26.790Y52.133 N4610G1X-27.935Y51.536 N4620G1X-29.067Y50.914 N4630G1X-30.184Y50.267 N4640G1X-31.288Y49.594 N4650G1X-32.378Y48.896 N4660G1X-33.666Y48.022 N4670G1X-24.467Y42.193 N4680G1X-24.897Y41.518 N4690G1X-16.872Y36.384 N4700G1X-10.873Y56.583 N4710G2X-9.232Y58.604I3.259J-0.970 N4720G1X-10.873Y58.324 N4730G1X-12.199Y58.063 N4740G1X-13.513Y57.774 N4750G1X-14.815Y57.459 N4760G1X-16.106Y57.117 N4770G1X-17.384Y56.748 N4780G1X-18.650Y56.353 N4790G1X-19.904Y55.931 N4800G1X-21.144Y55.482 N4810G1X-22.372Y55.007 N4820G1X-23.587Y54.506 N4830G1X-24.789Y53.979 N4840G1X-25.977Y53.426 N4850G1X-27.152Y52.847 N4860G1X-28.313Y52.242 N4870G1X-29.460Y51.611 N4880G1X-30.593Y50.954 N4890G1X-31.712Y50.272 N4900G1X-32.817Y49.565 N4910G1X-33.907Y48.832 N4920G1X-35.408Y47.758 N4930G2X-34.495Y47.524I-0.382J-3.379 N4940G1X-34.371Y47.473 N4950G2X-33.843Y47.199I-1.295J-3.144 N4960G1X-24.897Y41.518 N4970G00Z6.000 N4980G00X-6.187Y59.013 N4990G1Z-0.833F1200.0 N5000G1X5.912Y59.016F1800.0 N5010G1X3.675Y59.135 N5020G1X1.254Y59.200 N5030G1X-3.466Y59.293 N5040G1X-6.187Y59.013 N5050G00Z6.000 N5060G00X23.080Y47.647 N5070G1Z-0.833F1200.0 N5080G1X23.061Y47.528F1800.0 N5090G1X23.176Y47.602 N5100G1X23.080Y47.647 N5110G1X23.236Y48.456 N5120G1X22.389Y48.840 N5130G2X21.720Y45.721I-8.995J0.298 N5140G1X24.798Y47.690 N5150G1X24.354Y47.938 N5160G1X23.236Y48.456 N5170G1X23.569Y49.183 N5180G1X21.539Y50.081 N5190G2X18.431Y42.668I-8.146J-0.943 N5200G1X26.354Y47.735 N5210G1X24.718Y48.651 N5220G1X23.569Y49.183 N5230G1X23.902Y49.911 N5240G1X21.900Y50.798 N5250G1X20.443Y51.389 N5260G2X16.502Y42.422I-7.049J-2.251 N5270G1X17.221Y40.944 N5280G1X27.899Y47.774 N5290G1X25.082Y49.364 N5300G1X23.902Y49.911 N5310G1X24.235Y50.638 N5320G1X22.212Y51.535 N5330G1X20.218Y52.337 N5340G1X18.939Y52.807 N5350G1X19.299Y52.085 N5360G2X15.404Y42.851I-5.906J-2.947 N5370G1X16.895Y39.786 N5380G1X29.423Y47.799 N5390G1X28.785Y48.187 N5400G1X27.483Y48.937 N5410G1X25.446Y50.077 N5420G1X24.235Y50.638 N5430G1X24.569Y51.365 N5440G1X22.523Y52.272 N5450G1X20.503Y53.084 N5460G1X18.480Y53.816 N5470G1X17.356Y54.187 N5480G1X18.583Y51.728 N5490G2X14.253Y43.402I-5.190J-2.590 N5500G1X16.570Y38.631 N5510G1X30.920Y47.807 N5520G1X30.436Y48.119 N5530G1X29.193Y48.876 N5540G1X27.878Y49.633 N5550G1X25.810Y50.790 N5560G1X24.569Y51.365 N5570G1X24.902Y52.092 N5580G1X22.835Y53.008 N5590G1X20.789Y53.832 N5600G1X18.738Y54.574 N5610G1X16.673Y55.237 N5620G1X15.813Y55.489 N5630G1X17.868Y51.370 N5640G2X13.277Y44.139I-4.474J-2.233 N5650G1X13.025Y44.146 N5660G1X13.670Y42.760 N5670G1X16.246Y37.477 N5680G1X32.392Y47.799 N5690G1X30.860Y48.797 N5700G1X29.601Y49.564 N5710G1X28.272Y50.329 N5720G1X26.174Y51.503 N5730G1X24.902Y52.092 N5740G1X25.235Y52.820 N5750G1X23.146Y53.745 N5760G1X21.075Y54.579 N5770G1X18.997Y55.331 N5780G1X16.905Y56.003 N5790G1X14.790Y56.600 N5800G1X14.303Y56.723 N5810G1X17.152Y51.013 N5820G2X13.296Y44.939I-3.758J-1.875 N5830G1X12.883Y44.949 N5840G1X11.684Y45.134 N5850G1X12.947Y42.416 N5860G1X15.921Y36.323 N5870G1X33.840Y47.776 N5880G1X32.525Y48.676 N5890G1X31.285Y49.475 N5900G1X30.008Y50.253 N5910G1X28.667Y51.024 N5920G1X26.538Y52.216 N5930G1X25.235Y52.820 N5940G1X25.568Y53.547 N5950G1X23.458Y54.482 N5960G1X21.360Y55.326 N5970G1X20.309Y55.717 N5980G1X19.255Y56.088 N5990G1X18.198Y56.438 N6000G1X17.136Y56.769 N6010G1X16.068Y57.081 N6020G1X14.993Y57.373 N6030G1X13.910Y57.647 N6040G1X12.642Y57.941 N6050G2X13.203Y57.135I-2.482J-2.324 N6060G1X16.436Y50.656 N6070G2X13.314Y45.739I-3.042J-1.518 N6080G1X12.954Y45.747 N6090G1X10.333Y46.145 N6100G1X12.224Y42.073 N6110G1X15.597Y35.168 N6120G1X34.384Y47.174 N6130G2X35.427Y47.617I1.832J-2.864 N6140G1X34.196Y48.506 N6150G1X32.968Y49.343 N6160G1X31.710Y50.154 N6170G1X30.416Y50.941 N6180G1X29.062Y51.720 N6190G1X26.902Y52.929 N6200G1X25.568Y53.547 N6210G00Z6.000 N6220G00X36.688Y45.191 N6230G1Z-0.833F1200.0 N6240G1X37.404Y44.808F1800.0 N6250G1X40.727Y41.614 N6260G1X41.610Y40.721 N6270G1X42.477Y39.812 N6280G1X43.321Y38.895 N6290G1X44.134Y37.979 N6300G1X44.908Y37.071 N6310G1X45.636Y36.181 N6320G1X47.236Y34.098 N6330G1X49.956Y29.998 N6340G2X49.821Y28.729I-0.833J-0.553 N6350G1X49.463Y28.379 N6360G1X0.822Y-1.692 N6370G2X0.239Y-1.840I-0.525J0.851 N6380G1X-0.268Y-1.810 N6390G2X-0.737Y-1.662I0.058J0.998 N6400G1X-34.279Y19.133 N6410G1X-49.512Y28.549 N6420G2X-49.986Y29.400I0.526J0.851 N6430G1Y29.665 N6440G2X-49.818Y30.220I1.000J0.000 N6450G1X-47.746Y33.307 N6460G1X-46.606Y34.891 N6470G1X-45.400Y36.457 N6480G1X-44.142Y37.987 N6490G1X-42.849Y39.464 N6500G1X-41.535Y40.872 N6510G1X-40.215Y42.192 N6520G1X-38.902Y43.409 N6530G1X-38.253Y43.973 N6540G1X-37.395Y44.684 N6550G1X-37.056Y44.940 N6560G1X-36.742Y45.144 N6570G1X-36.398Y45.310 N6580G1X-36.138Y45.368 N6590G2X-35.820Y45.388I0.219J-0.976 N6600G1X-35.691Y45.375 N6610G2X-35.409Y45.305I-0.099J-0.995 N6620G1X-35.204Y45.220 N6630G1X-26.187Y39.495 N6640G1X-16.074Y33.024 N6650G1X-15.473Y32.656 N6660G1X-8.573Y55.898 N6670G2X-7.615Y56.613I0.958J-0.285 N6680G1X10.160Y56.617 N6690G2X11.055Y56.063I0.000J-1.000 N6700G1X14.289Y49.584 N6710G2X13.370Y48.138I-0.895J-0.447 N6720G1X13.167Y48.143 N6730G1X10.520Y48.542 N6740G1X9.697Y48.626 N6750G1X8.862Y48.683 N6760G1X8.059Y48.711 N6770G1X7.335Y48.711 N6780G1X6.573Y48.663 N6790G1X7.249Y47.088 N6800G1X10.057Y41.042 N6810G1X13.547Y33.898 N6820G1X14.630Y31.710 N6830G1X19.984Y35.114 N6840G1X35.677Y45.152 N6850G2X36.688Y45.191I0.539J-0.842 N6860G1X37.066Y45.896 N6870G1X37.661Y45.577 N6880G2X38.055Y45.292I-0.850J-1.587 N6890G1X41.291Y42.182 N6900G1X42.184Y41.278 N6910G1X43.061Y40.359 N6920G1X43.915Y39.431 N6930G1X44.737Y38.504 N6940G1X45.522Y37.584 N6950G1X46.261Y36.680 N6960G1X47.888Y34.562 N6970G1X50.623Y30.440 N6980G2X50.380Y28.156I-1.500J-0.995 N6990G1X50.100Y27.883 N7000G2X49.790Y27.641I-1.257J1.289 N7010G1X1.242Y-2.373 N7020G2X0.193Y-2.638I-0.946J1.532 N7030G1X-0.314Y-2.609 N7040G2X-1.159Y-2.342I0.104J1.797 N7050G1X-34.700Y18.453 N7060G1X-49.933Y27.869 N7070G2X-50.786Y29.400I0.946J1.531 N7080G1Y29.665 N7090G2X-50.483Y30.664I1.800J0.000 N7100G1X-48.403Y33.763 N7110G1X-47.247Y35.369 N7120G1X-46.025Y36.955 N7130G1X-44.753Y38.504 N7140G1X-43.443Y40.000 N7150G1X-42.111Y41.427 N7160G1X-40.770Y42.768 N7170G1X-39.434Y44.007 N7180G1X-38.771Y44.584 N7190G1X-37.891Y45.312 N7200G1X-37.516Y45.595 N7210G1X-37.135Y45.843 N7220G1X-36.847Y45.981 N7230G2X-36.462Y46.115I0.780J-1.622 N7240G1X-36.313Y46.149 N7250G2X-35.741Y46.184I0.395J-1.756 N7260G1X-35.612Y46.171 N7270G2X-35.104Y46.044I-0.178J-1.791 N7280G1X-34.834Y45.933 N7290G1X-25.757Y40.169 N7300G1X-15.942Y33.889 N7310G1X-9.340Y56.127 N7320G2X-7.615Y57.413I1.725J-0.513 N7330G1X10.160Y57.417 N7340G2X11.771Y56.420I0.000J-1.800 N7350G1X15.004Y49.942 N7360G2X13.352Y47.338I-1.611J-0.804 N7370G1X13.096Y47.344 N7380G1X10.424Y47.748 N7390G1X9.630Y47.829 N7400G1X8.821Y47.883 N7410G1X7.766Y47.911 N7420G1X7.979Y47.415 N7430G1X10.779Y41.386 N7440G1X14.264Y34.252 N7450G1X14.952Y32.862 N7460G1X19.554Y35.788 N7470G1X35.246Y45.826 N7480G2X37.066Y45.896I0.970J-1.516 N7490G00Z6.000 N7500G00X52.032Y26.051 N7510G1Z-0.833F1200.0 N7520G2X52.235Y25.750I-0.714J-0.700F1800.0 N7530G1X53.243Y23.429 N7540G1X53.927Y21.791 N7550G1X54.557Y20.142 N7560G1X55.133Y18.483 N7570G1X55.655Y16.810 N7580G1X56.126Y15.117 N7590G1X56.547Y13.401 N7600G1X56.919Y11.655 N7610G1X57.243Y9.883 N7620G1X57.704Y7.142 N7630G1X57.930Y3.708 N7640G1X58.029Y1.891 N7650G1X58.062Y0.262 N7660G1X58.028Y-1.372 N7670G1X57.929Y-3.204 N7680G1X57.704Y-6.623 N7690G2X57.644Y-6.904I-0.998J0.066 N7700G1X57.356Y-7.683 N7710G2X55.524Y-7.783I-0.938J0.347 N7720G1X41.729Y19.870 N7730G2X41.919Y21.026I0.895J0.446 N7740G1X42.296Y21.401 N7750G1X50.510Y26.488 N7760G2X51.751Y26.338I0.527J-0.850 N7770G1X52.032Y26.051 N7780G1X52.604Y26.611 N7790G2X52.969Y26.069I-1.286J-1.260 N7800G1X53.979Y23.743 N7810G1X54.670Y22.088 N7820G1X55.309Y20.416 N7830G1X55.893Y18.733 N7840G1X56.423Y17.036 N7850G1X56.900Y15.320 N7860G1X57.327Y13.580 N7870G1X57.704Y11.811 N7880G1X58.031Y10.021 N7890G1X58.499Y7.235 N7900G1X58.729Y3.756 N7910G1X58.828Y1.924 N7920G1X58.862Y0.262 N7930G1X58.828Y-1.406 N7940G1X58.727Y-3.252 N7950G1X58.503Y-6.675 N7960G2X58.395Y-7.182I-1.796J0.118 N7970G1X58.107Y-7.961 N7980G2X54.808Y-8.140I-1.688J0.625 N7990G1X41.013Y19.513 N8000G2X41.355Y21.594I1.611J0.804 N8010G1X41.651Y21.888 N8020G2X41.972Y22.141I1.268J-1.277 N8030G1X50.089Y27.168 N8040G2X52.323Y26.898I0.948J-1.530 N8050G1X52.604Y26.611 N8060G00Z6.000 N8070G00X40.040Y20.669 N8080G1Z-0.833F1200.0 N8090G00Z6.000 N8100G00X58.370Y-12.988 N8110G1Z-0.833F1200.0 N8120G1X58.623Y-11.743F1800.0 N8130G1X58.871Y-10.355 N8140G1X58.994Y-9.556 N8150G2X57.360Y-10.603I-2.575J2.220 N8160G1X57.854Y-11.599 N8170G1X58.093Y-12.143 N8180G1X58.243Y-12.554 N8190G1X58.370Y-12.988 N8200G00Z6.000 N8210G00X48.162Y-28.893 N8220G1Z-0.833F1200.0 N8230G1X47.871Y-28.179F1800.0 N8240G1X35.452Y-3.088 N8250G2X35.357Y-2.772I0.896J0.444 N8260G1X28.547Y10.878 N8270G1X28.214Y11.734 N8280G2X28.620Y12.947I0.932J0.362 N8290G1X38.043Y18.773 N8300G1X38.416Y18.977 N8310G1X38.741Y19.126 N8320G1X38.877Y19.167 N8330G2X39.245Y19.207I0.291J-0.957 N8340G1X39.280Y19.204 N8350G2X40.096Y18.656I-0.078J-0.997 N8360G1X47.668Y3.551 N8370G1X55.679Y-12.615 N8380G1X55.865Y-13.038 N8390G1X56.014Y-13.447 N8400G1X56.109Y-13.904 N8410G1X56.114Y-14.393 N8420G1X56.037Y-14.894 N8430G1X55.899Y-15.444 N8440G1X55.443Y-16.920 N8450G1X54.920Y-18.483 N8460G1X54.337Y-20.087 N8470G1X53.710Y-21.692 N8480G1X53.055Y-23.262 N8490G1X52.387Y-24.762 N8500G1X51.722Y-26.154 N8510G1X51.076Y-27.401 N8520G1X50.455Y-28.482 N8530G1X50.158Y-28.952 N8540G1X49.972Y-29.196 N8550G1X49.813Y-29.325 N8560G2X49.152Y-29.549I-0.632J0.775 N8570G1X49.097Y-29.547 N8580G2X48.382Y-29.215I0.030J1.000 N8590G1X48.333Y-29.160 N8600G2X48.162Y-28.893I0.745J0.667 N8610G1X47.428Y-29.212 N8620G1X47.138Y-28.502 N8630G1X34.735Y-3.442 N8640G2X34.590Y-3.027I1.613J0.798 N8650G1X27.814Y10.554 N8660G1X27.468Y11.444 N8670G2X28.199Y13.628I1.678J0.652 N8680G1X37.646Y19.468 N8690G1X38.058Y19.692 N8700G1X38.457Y19.875 N8710G1X38.644Y19.932 N8720G2X39.307Y20.005I0.524J-1.722 N8730G1X39.342Y20.002 N8740G2X40.811Y19.014I-0.140J-1.795 N8750G1X48.384Y3.908 N8760G1X56.404Y-12.276 N8770G1X56.607Y-12.740 N8780G1X56.786Y-13.227 N8790G1X56.908Y-13.818 N8800G1X56.914Y-14.450 N8810G1X56.822Y-15.052 N8820G1X56.669Y-15.660 N8830G1X56.205Y-17.165 N8840G1X55.676Y-18.747 N8850G1X55.086Y-20.369 N8860G1X54.452Y-21.991 N8870G1X53.790Y-23.579 N8880G1X53.114Y-25.097 N8890G1X52.439Y-26.511 N8900G1X51.781Y-27.780 N8910G1X51.138Y-28.899 N8920G1X50.815Y-29.410 N8930G1X50.679Y-29.588 N8940G2X50.386Y-29.890I-1.430J1.094 N8950G1X50.319Y-29.945 N8960G2X49.128Y-30.349I-1.137J1.396 N8970G1X49.074Y-30.347 N8980G2X47.786Y-29.748I0.054J1.799 N8990G1X47.737Y-29.693 N9000G2X47.428Y-29.212I1.342J1.200 N9010G00Z6.000 N9020G00X49.710Y-33.551 N9030G1Z-0.833F1200.0 N9040G1X50.786Y-31.864F1800.0 N9050G1X51.087Y-31.366 N9060G2X49.775Y-31.897I-1.905J2.816 N9070G1X49.822Y-32.414 N9080G2X49.762Y-33.293I-3.394J-0.210 N9090G1X49.710Y-33.551 N9100G00Z6.000 N9110G00X36.326Y-47.909 N9120G1Z-0.833F1200.0 N9130G1X37.381Y-47.081F1800.0 N9140G1X38.440Y-46.206 N9150G2X36.924Y-46.485I-1.357J3.117 N9160G2X36.326Y-47.909I-3.352J0.570 N9170G00Z6.000 N9180G00X28.066Y-53.259 N9190G1Z-0.833F1200.0 N9200G1X29.233Y-52.688F1800.0 N9210G1X30.205Y-52.079 N9220G1X28.927Y-52.797 N9230G1X28.066Y-53.259 N9240G00Z6.000 N9250G00X6.227Y-59.956 N9260G1Z-0.833F1200.0 N9270G1X7.013Y-59.874F1800.0 N9280G1X8.340Y-59.705 N9290G1X9.658Y-59.506 N9300G1X10.968Y-59.276 N9310G1X12.271Y-59.016 N9320G1X13.569Y-58.725 N9330G1X14.862Y-58.404 N9340G1X16.151Y-58.051 N9350G1X17.437Y-57.666 N9360G1X18.720Y-57.249 N9370G1X20.003Y-56.800 N9380G1X20.723Y-56.530 N9390G1X17.763Y-57.507 N9400G1X16.508Y-57.885 N9410G1X15.258Y-58.230 N9420G1X14.000Y-58.547 N9430G1X12.723Y-58.837 N9440G1X11.414Y-59.103 N9450G1X10.060Y-59.350 N9460G1X6.227Y-59.956 N9470G00Z6.000 N9480G00X-28.350Y-53.184 N9490G1Z-0.833F1200.0 N9500G1X-26.859Y-53.963F1800.0 N9510G1X-25.843Y-54.462 N9520G1X-24.818Y-54.941 N9530G1X-23.786Y-55.400 N9540G1X-22.745Y-55.838 N9550G1X-21.697Y-56.256 N9560G1X-20.640Y-56.654 N9570G1X-19.575Y-57.031 N9580G1X-18.501Y-57.388 N9590G1X-17.420Y-57.726 N9600G1X-16.329Y-58.042 N9610G1X-15.231Y-58.339 N9620G1X-14.123Y-58.616 N9630G1X-13.008Y-58.872 N9640G1X-11.883Y-59.108 N9650G1X-10.750Y-59.324 N9660G1X-9.608Y-59.520 N9670G1X-8.458Y-59.695 N9680G1X-7.298Y-59.850 N9690G1X-6.130Y-59.985 N9700G1X-4.952Y-60.099 N9710G1X-1.234Y-60.372 N9720G1X1.594Y-60.310 N9730G1X2.725Y-60.256 N9740G1X3.986Y-60.164 N9750G1X5.904Y-59.990 N9760G1X-4.309Y-60.113 N9770G1X-5.628Y-59.933 N9780G1X-9.247Y-59.528 N9790G1X-13.011Y-58.770 N9800G1X-14.901Y-58.321 N9810G1X-15.869Y-58.065 N9820G1X-17.773Y-57.511 N9830G1X-19.686Y-56.891 N9840G1X-21.575Y-56.215 N9850G1X-23.408Y-55.493 N9860G1X-25.204Y-54.717 N9870G1X-26.892Y-53.914 N9880G1X-28.350Y-53.184 N9890G00Z6.000 N9900G00X-33.584Y-50.010 N9910G1Z-0.833F1200.0 N9920G1X-31.823Y-51.161F1800.0 N9930G1X-30.846Y-51.763 N9940G1X-29.861Y-52.343 N9950G1X-28.928Y-52.870 N9960G1X-31.098Y-51.563 N9970G1X-33.584Y-50.010 N9980G00Z6.000 N9990G00X-38.508Y-46.337 N10000G1Z-0.833F1200.0 N10010G1X-36.593Y-47.844F1800.0 N10020G1X-35.650Y-48.552 N10030G2X-36.720Y-46.816I2.226J2.570 N10040G1X-36.768 N10050G2X-38.508Y-46.337I0.000J3.400 N10060G00Z6.000 N10070G00X-39.422Y-45.611 N10080G1Z-0.833F1200.0 N10090G1X-39.309Y-45.701F1800.0 N10100G1X-39.612Y-45.426 N10110G1X-39.422Y-45.611 N10120G1X-39.952Y-46.212 N10130G1X-37.079Y-48.479 N10140G1X-36.129Y-49.193 N10150G1X-35.171Y-49.886 N10160G1X-34.205Y-50.557 N10170G1X-33.231Y-51.208 N10180G1X-32.249Y-51.839 N10190G1X-31.259Y-52.448 N10200G1X-30.261Y-53.036 N10210G1X-29.255Y-53.604 N10220G1X-28.241Y-54.152 N10230G1X-27.219Y-54.678 N10240G1X-26.188Y-55.184 N10250G1X-25.150Y-55.669 N10260G1X-24.103Y-56.134 N10270G1X-23.049Y-56.578 N10280G1X-21.986Y-57.002 N10290G1X-20.914Y-57.405 N10300G1X-19.835Y-57.788 N10310G1X-18.747Y-58.150 N10320G1X-17.650Y-58.492 N10330G1X-16.545Y-58.813 N10340G1X-15.432Y-59.113 N10350G1X-14.310Y-59.394 N10360G1X-13.179Y-59.653 N10370G1X-12.040Y-59.893 N10380G1X-10.893Y-60.111 N10390G1X-9.736Y-60.309 N10400G1X-8.571Y-60.487 N10410G1X-7.397Y-60.644 N10420G1X-6.214Y-60.780 N10430G1X-5.023Y-60.896 N10440G1X-1.254Y-61.172 N10450G1X1.623Y-61.109 N10460G1X2.773Y-61.055 N10470G1X4.050Y-60.962 N10480G1X5.741Y-60.811 N10490G1X7.105Y-60.669 N10500G1X8.450Y-60.498 N10510G1X9.787Y-60.296 N10520G1X11.115Y-60.063 N10530G1X12.437Y-59.799 N10540G1X13.753Y-59.504 N10550G1X15.064Y-59.178 N10560G1X16.371Y-58.820 N10570G1X17.675Y-58.430 N10580G1X18.976Y-58.007 N10590G1X20.276Y-57.552 N10600G1X21.575Y-57.065 N10610G1X22.875Y-56.544 N10620G1X24.175Y-55.989 N10630G1X25.478Y-55.401 N10640G1X26.795Y-54.772 N10650G1X29.622Y-53.388 N10660G1X32.803Y-51.384 N10670G1X34.546Y-50.208 N10680G1X36.239Y-48.982 N10690G1X37.882Y-47.705 N10700G1X39.476Y-46.377 N10710G1X41.018Y-45.001 N10720G1X42.509Y-43.576 N10730G1X43.948Y-42.103 N10740G1X45.335Y-40.582 N10750G1X46.670Y-39.014 N10760G1X47.951Y-37.399 N10770G1X49.178Y-35.739 N10780G1X50.350Y-34.033 N10790G1X51.468Y-32.283 N10800G1X52.530Y-30.488 N10810G1X53.536Y-28.650 N10820G1X55.364Y-25.045 N10830G1X56.659Y-21.706 N10840G1X57.161Y-20.298 N10850G1X57.626Y-18.894 N10860G1X58.054Y-17.494 N10870G1X58.446Y-16.095 N10880G1X58.802Y-14.696 N10890G1X59.123Y-13.296 N10900G1X59.409Y-11.893 N10910G1X59.661Y-10.486 N10920G1X59.877Y-9.073 N10930G1X60.060Y-7.652 N10940G1X60.209Y-6.222 N10950G1X60.324Y-4.781 N10960G1X60.406Y-3.328 N10970G1X60.454Y-1.862 N10980G1X60.469Y-0.366 N10990G1X60.466Y3.187 N11000G1X60.250Y5.256 N11010G1X60.027Y7.125 N11020G1X59.756Y8.959 N11030G1X59.433Y10.776 N11040G1X59.059Y12.574 N11050G1X58.635Y14.353 N11060G1X58.161Y16.114 N11070G1X57.636Y17.854 N11080G1X57.061Y19.573 N11090G1X56.437Y21.272 N11100G1X55.764Y22.949 N11110G1X55.042Y24.603 N11120G1X54.270Y26.234 N11130G1X53.451Y27.841 N11140G1X52.582Y29.425 N11150G1X51.665Y30.983 N11160G1X50.697Y32.521 N11170G1X49.811Y33.854 N11180G1X48.945Y35.096 N11190G1X48.083Y36.266 N11200G1X47.205Y37.389 N11210G1X46.292Y38.491 N11220G1X45.321Y39.598 N11230G1X44.273Y40.735 N11240G1X41.138Y43.952 N11250G1X39.472Y45.394 N11260G1X38.273Y46.406 N11270G1X37.081Y47.363 N11280G1X35.877Y48.280 N11290G1X34.655Y49.161 N11300G1X33.410Y50.010 N11310G1X32.134Y50.832 N11320G1X30.823Y51.630 N11330G1X29.457Y52.416 N11340G1X27.266Y53.642 N11350G1X24.830Y54.760 N11360G1X22.708Y55.657 N11370G1X21.646Y56.074 N11380G1X20.581Y56.469 N11390G1X19.514Y56.845 N11400G1X18.443Y57.200 N11410G1X17.367Y57.535 N11420G1X16.285Y57.851 N11430G1X15.196Y58.147 N11440G1X14.099Y58.425 N11450G1X12.994Y58.683 N11460G1X11.879Y58.923 N11470G1X9.616Y59.349 N11480G1X7.791Y59.631 N11490G1X6.379Y59.783 N11500G1X5.598Y59.842 N11510G1X3.705Y59.935 N11520G1X1.273Y60.000 N11530G1X-3.498Y60.094 N11540G1X-6.923Y59.737 N11550G1X-8.299Y59.556 N11560G1X-9.665Y59.347 N11570G1X-11.019Y59.110 N11580G1X-12.362Y58.846 N11590G1X-13.693Y58.554 N11600G1X-15.012Y58.235 N11610G1X-16.319Y57.888 N11620G1X-17.614Y57.514 N11630G1X-18.897Y57.114 N11640G1X-20.167Y56.686 N11650G1X-21.425Y56.231 N11660G1X-22.669Y55.750 N11670G1X-23.900Y55.242 N11680G1X-25.118Y54.708 N11690G1X-26.323Y54.147 N11700G1X-27.513Y53.560 N11710G1X-28.690Y52.947 N11720G1X-29.853Y52.308 N11730G1X-31.002Y51.642 N11740G1X-32.136Y50.951 N11750G1X-33.256Y50.234 N11760G1X-34.361Y49.491 N11770G1X-35.450Y48.722 N11780G1X-36.525Y47.927 N11790G1X-37.584Y47.107 N11800G1X-38.628Y46.262 N11810G1X-39.656Y45.391 N11820G1X-40.667Y44.495 N11830G1X-41.663Y43.573 N11840G1X-42.642Y42.627 N11850G1X-43.614Y41.645 N11860G1X-45.651Y39.543 N11870G1X-46.697Y38.255 N11880G1X-47.896Y36.743 N11890G1X-48.994Y35.285 N11900G1X-50.012Y33.850 N11910G1X-50.965Y32.416 N11920G1X-51.869Y30.961 N11930G1X-52.737Y29.461 N11940G1X-53.585Y27.895 N11950G1X-54.431Y26.226 N11960G1X-56.005Y23.027 N11970G1X-56.787Y20.921 N11980G1X-57.358Y19.307 N11990G1X-57.891Y17.655 N12000G1X-58.387Y15.957 N12010G1X-58.844Y14.229 N12020G1X-59.258Y12.483 N12030G1X-59.626Y10.732 N12040G1X-59.944Y8.989 N12050G1X-60.206Y7.295 N12060G1X-60.316Y6.241 N12070G1X-60.426Y4.693 N12080G1X-60.519Y2.881 N12090G1X-60.581Y1.028 N12100G1X-60.682Y-3.252 N12110G1X-60.333Y-6.898 N12120G1X-60.158Y-8.346 N12130G1X-59.956Y-9.763 N12140G1X-59.728Y-11.152 N12150G1X-59.473Y-12.516 N12160G1X-59.190Y-13.859 N12170G1X-58.877Y-15.183 N12180G1X-58.535Y-16.492 N12190G1X-58.163Y-17.790 N12200G1X-57.759Y-19.080 N12210G1X-57.322Y-20.365 N12220G1X-56.852Y-21.649 N12230G1X-56.348Y-22.934 N12240G1X-55.808Y-24.224 N12250G1X-55.231Y-25.523 N12260G1X-53.246Y-29.680 N12270G1X-51.448Y-32.631 N12280G1X-50.393Y-34.257 N12290G1X-49.302Y-35.826 N12300G1X-48.168Y-37.350 N12310G1X-46.984Y-38.837 N12320G1X-45.741Y-40.296 N12330G1X-44.433Y-41.738 N12340G1X-43.758Y-42.448 N12350G1X-42.316Y-43.898 N12360G1X-39.952Y-46.212 N12370G1X-40.482Y-46.813 N12380G1X-37.565Y-49.115 N12390G1X-36.604Y-49.837 N12400G1X-35.634Y-50.538 N12410G1X-34.655Y-51.219 N12420G1X-33.669Y-51.878 N12430G1X-32.675Y-52.516 N12440G1X-31.672Y-53.133 N12450G1X-30.661Y-53.729 N12460G1X-29.641Y-54.305 N12470G1X-28.614Y-54.859 N12480G1X-27.578Y-55.393 N12490G1X-26.534Y-55.905 N12500G1X-25.482Y-56.397 N12510G1X-24.421Y-56.868 N12520G1X-23.352Y-57.319 N12530G1X-22.275Y-57.748 N12540G1X-21.189Y-58.157 N12550G1X-20.095Y-58.544 N12560G1X-18.992Y-58.911 N12570G1X-17.881Y-59.258 N12580G1X-16.761Y-59.583 N12590G1X-15.633Y-59.888 N12600G1X-14.496Y-60.172 N12610G1X-13.351Y-60.435 N12620G1X-12.197Y-60.677 N12630G1X-11.035Y-60.898 N12640G1X-9.864Y-61.099 N12650G1X-8.684Y-61.279 N12660G1X-7.496Y-61.438 N12670G1X-6.299Y-61.576 N12680G1X-5.093Y-61.693 N12690G1X-1.275Y-61.973 N12700G1X1.652Y-61.909 N12710G1X2.821Y-61.853 N12720G1X4.115Y-61.759 N12730G1X5.818Y-61.608 N12740G1X7.197Y-61.464 N12750G1X8.561Y-61.290 N12760G1X9.916Y-61.085 N12770G1X11.263Y-60.849 N12780G1X12.603Y-60.582 N12790G1X13.937Y-60.283 N12800G1X15.267Y-59.952 N12810G1X16.591Y-59.589 N12820G1X17.913Y-59.193 N12830G1X19.232Y-58.765 N12840G1X20.549Y-58.304 N12850G1X21.865Y-57.810 N12860G1X23.180Y-57.283 N12870G1X24.497Y-56.722 N12880G1X25.815Y-56.126 N12890G1X27.143Y-55.493 N12900G1X30.012Y-54.088 N12910G1X33.239Y-52.054 N12920G1X35.004Y-50.864 N12930G1X36.719Y-49.622 N12940G1X38.384Y-48.328 N12950G1X39.998Y-46.983 N12960G1X41.561Y-45.589 N12970G1X43.072Y-44.145 N12980G1X44.530Y-42.652 N12990G1X45.936Y-41.110 N13000G1X47.288Y-39.522 N13010G1X48.586Y-37.886 N13020G1X49.829Y-36.203 N13030G1X51.017Y-34.475 N13040G1X52.149Y-32.702 N13050G1X53.225Y-30.884 N13060G1X54.244Y-29.022 N13070G1X56.095Y-25.372 N13080G1X57.410Y-21.983 N13090G1X57.918Y-20.558 N13100G1X58.388Y-19.137 N13110G1X58.822Y-17.719 N13120G1X59.219Y-16.302 N13130G1X59.580Y-14.884 N13140G1X59.905Y-13.466 N13150G1X60.195Y-12.043 N13160G1X60.450Y-10.617 N13170G1X60.670Y-9.184 N13180G1X60.855Y-7.744 N13190G1X61.005Y-6.295 N13200G1X61.122Y-4.835 N13210G1X61.205Y-3.364 N13220G1X61.254Y-1.879 N13230G1X61.269Y-0.370 N13240G1X61.266Y3.229 N13250G1X61.045Y5.345 N13260G1X60.820Y7.231 N13270G1X60.545Y9.088 N13280G1X60.219Y10.927 N13290G1X59.840Y12.748 N13300G1X59.411Y14.550 N13310G1X58.930Y16.333 N13320G1X58.398Y18.096 N13330G1X57.816Y19.838 N13340G1X57.184Y21.559 N13350G1X56.502Y23.258 N13360G1X55.770Y24.934 N13370G1X54.989Y26.587 N13380G1X54.158Y28.216 N13390G1X53.278Y29.820 N13400G1X52.349Y31.399 N13410G1X51.369Y32.956 N13420G1X50.473Y34.304 N13430G1X49.595Y35.562 N13440G1X48.720Y36.749 N13450G1X47.829Y37.890 N13460G1X46.901Y39.010 N13470G1X45.916Y40.133 N13480G1X44.855Y41.284 N13490G1X41.686Y44.536 N13500G1X39.992Y46.002 N13510G1X38.782Y47.024 N13520G1X37.574Y47.994 N13530G1X36.353Y48.923 N13540G1X35.114Y49.816 N13550G1X33.852Y50.677 N13560G1X32.559Y51.510 N13570G1X31.231Y52.318 N13580G1X29.852Y53.112 N13590G1X27.630Y54.355 N13600G1X25.154Y55.491 N13610G1X24.080Y55.956 N13620G1X23.006Y56.399 N13630G1X21.931Y56.821 N13640G1X20.853Y57.222 N13650G1X19.773Y57.602 N13660G1X18.688Y57.962 N13670G1X17.598Y58.301 N13680G1X16.502Y58.621 N13690G1X15.399Y58.921 N13700G1X14.288Y59.202 N13710G1X13.169Y59.464 N13720G1X12.040Y59.707 N13730G1X10.901Y59.931 N13740G1X8.589Y60.325 N13750G1X7.190Y60.508 N13760G1X5.647Y60.640 N13770G1X3.736Y60.734 N13780G1X1.291Y60.800 N13790G1X-3.530Y60.894 N13800G1X-7.019Y60.531 N13810G1X-8.412Y60.348 N13820G1X-9.794Y60.137 N13830G1X-11.165Y59.897 N13840G1X-12.525Y59.629 N13850G1X-13.873Y59.334 N13860G1X-15.209Y59.010 N13870G1X-16.533Y58.659 N13880G1X-17.845Y58.281 N13890G1X-19.144Y57.875 N13900G1X-20.431Y57.441 N13910G1X-21.705Y56.981 N13920G1X-22.966Y56.493 N13930G1X-24.213Y55.979 N13940G1X-25.448Y55.437 N13950G1X-26.668Y54.869 N13960G1X-27.875Y54.274 N13970G1X-29.068Y53.652 N13980G1X-30.247Y53.004 N13990G1X-31.411Y52.330 N14000G1X-32.560Y51.629 N14010G1X-33.695Y50.902 N14020G1X-34.814Y50.149 N14030G1X-35.919Y49.370 N14040G1X-37.008Y48.565 N14050G1X-38.081Y47.735 N14060G1X-39.138Y46.878 N14070G1X-40.179Y45.996 N14080G1X-41.204Y45.088 N14090G1X-42.213Y44.155 N14100G1X-43.204Y43.196 N14110G1X-44.186Y42.205 N14120G1X-46.250Y40.075 N14130G1X-47.321Y38.756 N14140G1X-48.529Y37.232 N14150G1X-49.639Y35.757 N14160G1X-50.671Y34.303 N14170G1X-51.638Y32.848 N14180G1X-52.555Y31.372 N14190G1X-53.435Y29.852 N14200G1X-54.293Y28.266 N14210G1X-55.147Y26.583 N14220G1X-56.741Y23.343 N14230G1X-57.539Y21.194 N14240G1X-58.116Y19.563 N14250G1X-58.656Y17.890 N14260G1X-59.158Y16.172 N14270G1X-59.620Y14.424 N14280G1X-60.039Y12.657 N14290G1X-60.411Y10.886 N14300G1X-60.733Y9.122 N14310G1X-60.999Y7.397 N14320G1X-61.113Y6.311 N14330G1X-61.224Y4.742 N14340G1X-61.318Y2.915 N14350G1X-61.381Y1.051 N14360G1X-61.483Y-3.279 N14370G1X-61.128Y-6.987 N14380G1X-60.951Y-8.451 N14390G1X-60.747Y-9.884 N14400G1X-60.516Y-11.290 N14410G1X-60.258Y-12.672 N14420G1X-59.970Y-14.033 N14430G1X-59.654Y-15.376 N14440G1X-59.307Y-16.704 N14450G1X-58.929Y-18.020 N14460G1X-58.519Y-19.328 N14470G1X-58.077Y-20.632 N14480G1X-57.600Y-21.933 N14490G1X-57.089Y-23.235 N14500G1X-56.542Y-24.541 N14510G1X-55.959Y-25.855 N14520G1X-55.334Y-27.187 N14530G1X-53.950Y-30.062 N14540G1X-52.126Y-33.056 N14550G1X-51.057Y-34.702 N14560G1X-49.952Y-36.293 N14570G1X-48.802Y-37.838 N14580G1X-47.601Y-39.345 N14590G1X-46.342Y-40.825 N14600G1X-45.017Y-42.285 N14610G1X-44.331Y-43.005 N14620G1X-42.880Y-44.466 N14630G1X-40.482Y-46.813 N14640G1X-41.012Y-47.413 N14650G1X-38.051Y-49.750 N14660G1X-37.078Y-50.481 N14670G1X-36.096Y-51.191 N14680G1X-35.106Y-51.880 N14690G1X-34.107Y-52.547 N14700G1X-33.100Y-53.193 N14710G1X-32.085Y-53.818 N14720G1X-31.061Y-54.422 N14730G1X-30.028Y-55.005 N14740G1X-28.987Y-55.567 N14750G1X-27.938Y-56.107 N14760G1X-26.880Y-56.627 N14770G1X-25.814Y-57.125 N14780G1X-24.739Y-57.603 N14790G1X-23.655Y-58.059 N14800G1X-22.564Y-58.494 N14810G1X-21.463Y-58.908 N14820G1X-20.355Y-59.301 N14830G1X-19.237Y-59.673 N14840G1X-18.112Y-60.024 N14850G1X-16.977Y-60.353 N14860G1X-15.834Y-60.662 N14870G1X-14.683Y-60.950 N14880G1X-13.523Y-61.216 N14890G1X-12.354Y-61.461 N14900G1X-11.177Y-61.686 N14910G1X-9.992Y-61.889 N14920G1X-8.798Y-62.071 N14930G1X-7.595Y-62.232 N14940G1X-6.383Y-62.372 N14950G1X-5.163Y-62.490 N14960G1X-1.295Y-62.773 N14970G1X1.681Y-62.708 N14980G1X2.869Y-62.652 N14990G1X4.179Y-62.556 N15000G1X5.895Y-62.404 N15010G1X7.289Y-62.259 N15020G1X8.671Y-62.082 N15030G1X10.044Y-61.875 N15040G1X11.410Y-61.635 N15050G1X12.769Y-61.364 N15060G1X14.121Y-61.061 N15070G1X15.469Y-60.726 N15080G1X16.812Y-60.358 N15090G1X18.151Y-59.957 N15100G1X19.487Y-59.523 N15110G1X20.821Y-59.057 N15120G1X22.154Y-58.556 N15130G1X23.486Y-58.022 N15140G1X24.818Y-57.454 N15150G1X26.152Y-56.852 N15160G1X27.491Y-56.213 N15170G1X30.401Y-54.788 N15180G1X33.675Y-52.725 N15190G1X35.462Y-51.520 N15200G1X37.199Y-50.262 N15210G1X38.886Y-48.951 N15220G1X40.521Y-47.589 N15230G1X42.104Y-46.176 N15240G1X43.634Y-44.713 N15250G1X45.112Y-43.201 N15260G1X46.536Y-41.639 N15270G1X47.906Y-40.030 N15280G1X49.221Y-38.372 N15290G1X50.480Y-36.668 N15300G1X51.684Y-34.917 N15310G1X52.831Y-33.121 N15320G1X53.920Y-31.280 N15330G1X54.952Y-29.394 N15340G1X56.826Y-25.699 N15350G1X58.161Y-22.260 N15360G1X58.674Y-20.818 N15370G1X59.150Y-19.380 N15380G1X59.589Y-17.944 N15390G1X59.992Y-16.509 N15400G1X60.358Y-15.073 N15410G1X60.687Y-13.635 N15420G1X60.981Y-12.194 N15430G1X61.239Y-10.748 N15440G1X61.462Y-9.296 N15450G1X61.649Y-7.837 N15460G1X61.802Y-6.368 N15470G1X61.920Y-4.890 N15480G1X62.004Y-3.400 N15490G1X62.054Y-1.897 N15500G1X62.069Y-0.374 N15510G1X62.066Y3.271 N15520G1X61.840Y5.434 N15530G1X61.613Y7.337 N15540G1X61.335Y9.216 N15550G1X61.004Y11.078 N15560G1X60.621Y12.922 N15570G1X60.186Y14.747 N15580G1X59.699Y16.553 N15590G1X59.161Y18.338 N15600G1X58.572Y20.103 N15610G1X57.931Y21.846 N15620G1X57.240Y23.567 N15630G1X56.498Y25.265 N15640G1X55.707Y26.939 N15650G1X54.865Y28.590 N15660G1X53.973Y30.215 N15670G1X53.032Y31.815 N15680G1X52.041Y33.390 N15690G1X51.134Y34.755 N15700G1X50.245Y36.028 N15710G1X49.357Y37.233 N15720G1X48.452Y38.392 N15730G1X47.510Y39.529 N15740G1X46.511Y40.668 N15750G1X45.438Y41.832 N15760G1X44.267Y43.048 N15770G1X42.235Y45.120 N15780G1X40.512Y46.610 N15790G1X39.291Y47.641 N15800G1X38.066Y48.624 N15810G1X36.829Y49.566 N15820G1X35.574Y50.471 N15830G1X34.294Y51.344 N15840G1X32.984Y52.188 N15850G1X31.638Y53.007 N15860G1X30.247Y53.807 N15870G1X27.994Y55.068 N15880G1X25.478Y56.223 N15890G1X24.392Y56.693 N15900G1X23.305Y57.141 N15910G1X22.217Y57.568 N15920G1X21.126Y57.974 N15930G1X20.031Y58.359 N15940G1X18.932Y58.723 N15950G1X17.829Y59.067 N15960G1X16.719Y59.391 N15970G1X15.602Y59.695 N15980G1X14.478Y59.979 N15990G1X13.345Y60.244 N16000G1X12.202Y60.490 N16010G1X11.049Y60.718 N16020G1X9.885Y60.926 N16030G1X7.998Y61.218 N16040G1X6.515Y61.377 N16050G1X5.697Y61.439 N16060G1X3.766Y61.534 N16070G1X1.310Y61.599 N16080G1X-3.562Y61.695 N16090G1X-7.115Y61.326 N16100G1X-8.525Y61.140 N16110G1X-9.924Y60.926 N16120G1X-11.311Y60.683 N16130G1X-12.688Y60.412 N16140G1X-14.052Y60.113 N16150G1X-15.405Y59.786 N16160G1X-16.746Y59.430 N16170G1X-18.075Y59.047 N16180G1X-19.391Y58.636 N16190G1X-20.695Y58.197 N16200G1X-21.985Y57.730 N16210G1X-23.263Y57.236 N16220G1X-24.527Y56.715 N16230G1X-25.777Y56.166 N16240G1X-27.014Y55.590 N16250G1X-28.237Y54.987 N16260G1X-29.446Y54.358 N16270G1X-30.640Y53.701 N16280G1X-31.819Y53.018 N16290G1X-32.984Y52.308 N16300G1X-34.134Y51.571 N16310G1X-35.268Y50.808 N16320G1X-36.387Y50.019 N16330G1X-37.490Y49.203 N16340G1X-38.578Y48.362 N16350G1X-39.649Y47.494 N16360G1X-40.703Y46.601 N16370G1X-41.741Y45.681 N16380G1X-42.763Y44.736 N16390G1X-43.767Y43.765 N16400G1X-44.757Y42.765 N16410G1X-46.849Y40.606 N16420G1X-47.945Y39.257 N16430G1X-49.162Y37.721 N16440G1X-50.285Y36.229 N16450G1X-51.331Y34.756 N16460G1X-52.311Y33.281 N16470G1X-53.241Y31.784 N16480G1X-54.134Y30.243 N16490G1X-55.002Y28.637 N16500G1X-55.862Y26.941 N16510G1X-57.476Y23.660 N16520G1X-58.291Y21.467 N16530G1X-58.874Y19.820 N16540G1X-59.420Y18.125 N16550G1X-59.929Y16.387 N16560G1X-60.397Y14.618 N16570G1X-60.820Y12.832 N16580G1X-61.196Y11.040 N16590G1X-61.522Y9.255 N16600G1X-61.793Y7.500 N16610G1X-61.910Y6.381 N16620G1X-62.023Y4.791 N16630G1X-62.118Y2.949 N16640G1X-62.181Y1.074 N16650G1X-62.284Y-3.306 N16660G1X-61.923Y-7.075 N16670G1X-61.744Y-8.555 N16680G1X-61.538Y-10.005 N16690G1X-61.304Y-11.429 N16700G1X-61.042Y-12.829 N16710G1X-60.751Y-14.207 N16720G1X-60.430Y-15.569 N16730G1X-60.079Y-16.915 N16740G1X-59.695Y-18.250 N16750G1X-59.280Y-19.577 N16760G1X-58.831Y-20.898 N16770G1X-58.348Y-22.216 N16780G1X-57.830Y-23.535 N16790G1X-57.277Y-24.858 N16800G1X-56.687Y-26.187 N16810G1X-56.056Y-27.530 N16820G1X-54.654Y-30.444 N16830G1X-52.803Y-33.481 N16840G1X-51.721Y-35.148 N16850G1X-50.601Y-36.761 N16860G1X-49.436Y-38.326 N16870G1X-48.219Y-39.854 N16880G1X-46.943Y-41.353 N16890G1X-45.601Y-42.831 N16900G1X-44.905Y-43.563 N16910G1X-43.443Y-45.034 N16920G1X-41.012Y-47.413 N16930G00Z6.000 N16940G00X-41.573Y-42.508 N16950G1Z-0.833F1200.0 N16960G1X-42.833Y-41.222F1800.0 N16970G1X-44.130Y-39.834 N16980G1X-45.383Y-38.436 N16990G1X-46.518Y-37.115 N17000G1X-47.454Y-35.958 N17010G1X-47.851Y-35.430 N17020G1X-48.192Y-34.935 N17030G1X-48.488Y-34.426 N17040G1X-48.594Y-34.170 N17050G2X-48.746Y-33.670I2.399J1.002 N17060G1X-48.761Y-33.598 N17070G2X-48.810Y-33.096I2.551J0.502 N17080G1Y-32.918 N17090G2X-48.540Y-31.766I2.600J0.000 N17100G1X-48.534Y-31.752 N17110G1X-48.920Y-31.763 N17120G2X-51.193Y-30.426I0.000J2.600 N17130G1X-52.049Y-28.885 N17140G1X-52.864Y-27.376 N17150G1X-53.631Y-25.889 N17160G1X-55.269Y-22.198 N17170G1X-56.082Y-20.114 N17180G1X-56.763Y-18.173 N17190G1X-57.038Y-17.308 N17200G1X-57.259Y-16.533 N17210G1X-57.417Y-15.861 N17220G1X-57.483Y-15.464 N17230G1X-57.510Y-15.105 N17240G1Y-14.555 N17250G2X-57.235Y-13.393I2.600J0.000 N17260G1X-56.030Y-10.979 N17270G2X-57.331Y-10.778I-0.265J2.586 N17280G1X-57.359Y-10.765 N17290G2X-58.626Y-9.588I1.036J2.385 N17300G1X-58.664Y-9.514 N17310G2X-58.843Y-9.082I2.303J1.207 N17320G1X-58.956Y-8.721 N17330G1X-59.119Y-8.056 N17340G1X-59.619Y-3.673 N17350G1X-59.609Y1.730 N17360G1X-59.576Y3.089 N17370G1X-59.518Y4.379 N17380G1X-59.431Y5.626 N17390G1X-59.313Y6.856 N17400G1X-59.162Y8.095 N17410G1X-58.977Y9.371 N17420G1X-58.592Y11.598 N17430G1X-58.407Y12.509 N17440G1X-57.992Y14.324 N17450G1X-57.508Y16.170 N17460G1X-56.967Y18.012 N17470G1X-56.374Y19.829 N17480G1X-55.737Y21.600 N17490G1X-55.066Y23.291 N17500G1X-54.358Y24.902 N17510G1X-53.513Y26.724 N17520G2X-51.305Y28.225I2.358J-1.095 N17530G2X-51.586Y29.400I2.319J1.175 N17540G1Y29.665 N17550G2X-51.148Y31.109I2.600J0.000 N17560G1X-49.060Y34.220 N17570G1X-47.889Y35.847 N17580G1X-46.651Y37.453 N17590G1X-45.363Y39.021 N17600G1X-44.037Y40.537 N17610G1X-42.686Y41.983 N17620G1X-41.325Y43.344 N17630G1X-39.965Y44.605 N17640G1X-39.288Y45.194 N17650G1X-38.387Y45.939 N17660G1X-37.976Y46.250 N17670G1X-37.529Y46.541 N17680G1X-37.194Y46.702 N17690G2X-36.638Y46.896I1.127J-2.343 N17700G1X-36.489Y46.929 N17710G2X-35.662Y46.980I0.570J-2.537 N17720G1X-35.533Y46.967 N17730G2X-34.799Y46.784I-0.257J-2.587 N17740G1X-34.465Y46.646 N17750G1X-25.327Y40.844 N17760G1X-16.407Y35.137 N17770G1X-10.107Y56.355 N17780G2X-7.615Y58.213I2.492J-0.742 N17790G1X10.160Y58.217 N17800G2X12.487Y56.778I0.000J-2.600 N17810G1X15.720Y50.299 N17820G2X13.333Y46.539I-2.326J-1.161 N17830G1X13.025Y46.546 N17840G1X10.327Y46.954 N17850G1X9.562Y47.031 N17860G1X9.022Y47.068 N17870G1X11.502Y41.729 N17880G1X15.274Y34.015 N17890G1X34.815Y46.500 N17900G2X37.444Y46.602I1.401J-2.190 N17910G1X38.039Y46.283 N17920G2X38.608Y45.870I-1.228J-2.292 N17930G1X41.854Y42.750 N17940G1X42.758Y41.836 N17950G1X43.645Y40.906 N17960G1X44.508Y39.967 N17970G1X45.341Y39.029 N17980G1X46.136Y38.097 N17990G1X46.887Y37.179 N18000G1X48.541Y35.025 N18010G1X51.290Y30.882 N18020G2X51.412Y28.211I-2.166J-1.438 N18030G2X52.894Y27.458I-0.375J-2.573 N18040G1X53.175Y27.171 N18050G2X53.702Y26.388I-1.857J-1.819 N18060G1X54.715Y24.056 N18070G1X55.413Y22.385 N18080G1X56.060Y20.690 N18090G1X56.652Y18.984 N18100G1X57.190Y17.263 N18110G1X57.674Y15.522 N18120G1X58.107Y13.758 N18130G1X58.489Y11.966 N18140G1X58.819Y10.159 N18150G1X59.295Y7.328 N18160G1X59.527Y3.804 N18170G1X59.628Y1.958 N18180G1X59.662Y0.262 N18190G1X59.627Y-1.439 N18200G1X59.526Y-3.300 N18210G1X59.301Y-6.728 N18220G2X59.145Y-7.459I-2.594J0.170 N18230G1X58.857Y-8.238 N18240G2X56.129Y-9.920I-2.438J0.902 N18250G1X57.129Y-11.938 N18260G1X57.350Y-12.441 N18270G1X57.557Y-13.008 N18280G1X57.656Y-13.484 N18290G2X57.710Y-13.985I-2.546J-0.527 N18300G1X57.715Y-14.506 N18310G1X57.607Y-15.210 N18320G1X57.440Y-15.876 N18330G1X56.966Y-17.410 N18340G1X56.431Y-19.010 N18350G1X55.834Y-20.651 N18360G1X55.194Y-22.291 N18370G1X54.524Y-23.896 N18380G1X53.840Y-25.432 N18390G1X53.155Y-26.867 N18400G1X52.486Y-28.159 N18410G1X51.820Y-29.317 N18420G1X51.473Y-29.867 N18430G1X51.314Y-30.074 N18440G2X50.891Y-30.511I-2.065J1.580 N18450G1X50.824Y-30.565 N18460G2X49.104Y-31.148I-1.642J2.016 N18470G1X48.733Y-31.118 N18480G1X48.844Y-31.424 N18490G1X48.935Y-31.780 N18500G2X49.011Y-32.265I-2.519J-0.645 N18510G1X49.024Y-32.464 N18520G2X48.978Y-33.136I-2.595J-0.161 N18530G1X48.940Y-33.322 N18540G2X48.761Y-33.879I-2.549J0.512 N18550G1X48.591Y-34.257 N18560G1X48.084Y-35.037 N18570G1X45.981Y-37.722 N18580G1X44.527Y-39.405 N18590G1X43.005Y-41.053 N18600G1X41.488Y-42.589 N18610G1X40.758Y-43.288 N18620G1X38.808Y-45.034 N18630G2X36.160Y-45.519I-1.725J1.945 N18640G1X36.170Y-45.826 N18650G2X35.016Y-48.077I-2.598J-0.089 N18660G1X33.011Y-49.417 N18670G1X32.006Y-50.067 N18680G1X30.902Y-50.744 N18690G1X29.739Y-51.424 N18700G1X28.542Y-52.095 N18710G1X27.336Y-52.744 N18720G1X26.146Y-53.355 N18730G1X24.995Y-53.915 N18740G1X23.927Y-54.403 N18750G1X21.882Y-55.298 N18760G1X17.524Y-56.743 N18770G1X16.286Y-57.116 N18780G1X15.053Y-57.457 N18790G1X13.814Y-57.769 N18800G1X12.554Y-58.054 N18810G1X11.262Y-58.318 N18820G1X9.924Y-58.562 N18830G1X5.929Y-59.193 N18840G1X-4.259Y-59.313 N18850G1X-5.529Y-59.139 N18860G1X-9.124Y-58.737 N18870G1X-12.840Y-57.988 N18880G1X-14.703Y-57.546 N18890G1X-15.655Y-57.294 N18900G1X-17.538Y-56.747 N18910G1X-19.428Y-56.134 N18920G1X-21.293Y-55.466 N18930G1X-23.105Y-54.752 N18940G1X-24.874Y-53.988 N18950G1X-26.537Y-53.196 N18960G1X-28.305Y-52.311 N18970G1X-30.681Y-50.881 N18980G1X-32.590Y-49.699 N18990G1X-34.002Y-48.768 N19000G1X-34.941Y-48.094 N19010G2X-36.024Y-45.961I1.517J2.112 N19020G2X-36.558Y-46.016I-0.534J2.545 N19030G1X-36.768 N19040G2X-38.517Y-45.340I0.000J2.600 N19050G1X-40.964Y-43.101 N19060G1X-41.573Y-42.508 N19070G00Z6.000 N19080G00X-49.408Y-34.280 N19090G1Z-0.833F1200.0 N19100G1X-49.546Y-33.753F1800.0 N19110G2X-49.610Y-33.096I3.336J0.657 N19120G1X-49.583Y-32.497 N19130G2X-50.977Y-31.869I0.664J3.335 N19140G1X-50.253Y-33.016 N19150G1X-49.408Y-34.280 N19160G00Z6.000 N19170G00X-47.635Y-29.201 N19180G1Z-0.833F1200.0 N19190G1X-47.647Y-29.261F1800.0 N19200G2X-47.793Y-29.617I-0.981J0.194 N19210G1X-47.825Y-29.667 N19220G2X-48.091Y-29.939I-0.835J0.550 N19230G1X-48.139Y-29.972 N19240G2X-48.505Y-30.129I-0.570J0.822 N19250G1X-48.665Y-30.163 N19260G1X-48.920 N19270G2X-49.794Y-29.648I0.000J1.000 N19280G1X-50.646Y-28.116 N19290G1X-51.449Y-26.629 N19300G1X-52.188Y-25.197 N19310G1X-53.794Y-21.576 N19320G1X-54.581Y-19.558 N19330G1X-55.243Y-17.673 N19340G1X-55.506Y-16.846 N19350G1X-55.710Y-16.130 N19360G1X-55.847Y-15.547 N19370G1X-55.892Y-15.274 N19380G1X-55.910Y-15.045 N19390G1Y-14.555 N19400G2X-55.804Y-14.108I1.000J0.000 N19410G1X-39.503Y18.517 N19420G2X-38.096Y18.928I0.895J-0.447 N19430G1X-36.897Y18.211 N19440G1X-28.286Y12.880 N19450G1X-27.897Y12.507 N19460G2X-27.690Y11.349I-0.693J-0.721 N19470G1X-29.909Y6.771 N19480G1X-39.435Y-12.483 N19490G1X-47.619Y-29.091 N19500G1X-47.635Y-29.201 N19510G1X-46.850Y-29.356 N19520G1X-46.862Y-29.417 N19530G2X-47.124Y-30.057I-1.766J0.350 N19540G1X-47.157Y-30.107 N19550G2X-47.635Y-30.596I-1.504J0.990 N19560G1X-47.683Y-30.629 N19570G2X-48.341Y-30.912I-1.026J1.479 N19580G1X-48.582Y-30.963 N19590G1X-48.920 N19600G2X-50.493Y-30.037I0.000J1.800 N19610G1X-51.347Y-28.500 N19620G1X-52.156Y-27.003 N19630G1X-52.910Y-25.543 N19640G1X-54.531Y-21.887 N19650G1X-55.332Y-19.836 N19660G1X-56.003Y-17.923 N19670G1X-56.272Y-17.077 N19680G1X-56.485Y-16.331 N19690G1X-56.632Y-15.704 N19700G1X-56.687Y-15.369 N19710G1X-56.710Y-15.075 N19720G1Y-14.555 N19730G2X-56.520Y-13.750I1.800J0.000 N19740G1X-40.219Y18.874 N19750G2X-37.685Y19.614I1.610J-0.805 N19760G1X-36.481Y18.895 N19770G1X-27.955Y13.616 N19780G1X-27.655Y13.384 N19790G1X-27.343Y13.084 N19800G2X-26.970Y11.001I-1.247J-1.298 N19810G1X-29.191Y6.419 N19820G1X-38.717Y-12.837 N19830G1X-46.850Y-29.356 N19840G00Z6.000 N19850G00X-58.290Y-14.189 N19860G1Z-0.833F1200.0 N19870G2X-57.951Y-13.035I3.380J-0.366F1800.0 N19880G1X-57.260Y-11.653 N19890G1X-57.677Y-11.499 N19900G2X-59.036Y-10.429I1.355J3.118 N19910G1X-58.688Y-12.360 N19920G1X-58.290Y-14.189 N19930G00Z6.000 N19940G00X10.084Y1.490 N19950G1Z-1.667F1200.0 N19960G2X10.610Y1.640I0.526J-0.850F1800.0 N19970G1X10.919 N19980G2X11.815Y1.085I0.000J-1.000 N19990G1X33.655Y-42.857 N20000G1X34.084Y-43.963 N20010G1X34.389Y-44.828 N20020G1X34.500Y-45.215 N20030G1X34.559Y-45.527 N20040G1X34.571Y-45.881 N20050G2X34.127Y-46.746I-0.999J-0.034 N20060G1X32.131Y-48.080 N20070G1X31.153Y-48.713 N20080G1X30.080Y-49.371 N20090G1X28.944Y-50.036 N20100G1X27.772Y-50.693 N20110G1X26.592Y-51.327 N20120G1X25.430Y-51.924 N20130G1X24.312Y-52.468 N20140G1X23.274Y-52.942 N20150G1X21.306Y-53.804 N20160G1X17.047Y-55.216 N20170G1X15.842Y-55.579 N20180G1X14.645Y-55.910 N20190G1X13.442Y-56.212 N20200G1X12.218Y-56.490 N20210G1X10.959Y-56.747 N20220G1X9.651Y-56.985 N20230G1X5.796Y-57.595 N20240G1X-4.160Y-57.711 N20250G1X-5.332Y-57.551 N20260G1X-8.879Y-57.154 N20270G1X-12.499Y-56.425 N20280G1X-14.306Y-55.996 N20290G1X-15.227Y-55.752 N20300G1X-17.068Y-55.217 N20310G1X-18.911Y-54.619 N20320G1X-20.731Y-53.968 N20330G1X-22.501Y-53.271 N20340G1X-24.213Y-52.531 N20350G1X-25.828Y-51.762 N20360G1X-27.533Y-50.908 N20370G1X-29.848Y-49.515 N20380G1X-31.736Y-48.347 N20390G1X-33.086Y-47.457 N20400G1X-34.007Y-46.795 N20410G2X-34.320Y-45.538I0.583J0.812 N20420G1X-29.513Y-35.844 N20430G1X-11.200Y0.901 N20440G2X-10.305Y1.455I0.895J-0.446 N20450G1X-10.085 N20460G2X-9.559Y1.305I0.000J-1.000 N20470G1X0.099Y-4.680 N20480G1X10.084Y1.490 N20490G1X9.663Y2.170 N20500G2X10.610Y2.440I0.947J-1.531 N20510G1X10.919 N20520G2X12.531Y1.441I0.000J-1.800 N20530G1X34.387Y-42.533 N20540G1X34.834Y-43.685 N20550G1X35.151Y-44.584 N20560G1X35.280Y-45.030 N20570G1X35.356Y-45.439 N20580G1X35.371Y-45.853 N20590G2X34.572Y-47.412I-1.799J-0.061 N20600G1X32.571Y-48.748 N20610G1X31.580Y-49.390 N20620G1X30.491Y-50.058 N20630G1X29.341Y-50.730 N20640G1X28.157Y-51.394 N20650G1X26.964Y-52.035 N20660G1X25.788Y-52.639 N20670G1X24.654Y-53.192 N20680G1X23.600Y-53.673 N20690G1X21.594Y-54.551 N20700G1X17.286Y-55.980 N20710G1X16.064Y-56.347 N20720G1X14.849Y-56.683 N20730G1X13.628Y-56.990 N20740G1X12.386Y-57.272 N20750G1X11.111Y-57.532 N20760G1X9.787Y-57.773 N20770G1X5.862Y-58.394 N20780G1X-4.210Y-58.512 N20790G1X-5.430Y-58.345 N20800G1X-9.001Y-57.945 N20810G1X-12.670Y-57.207 N20820G1X-14.505Y-56.771 N20830G1X-15.441Y-56.523 N20840G1X-17.303Y-55.982 N20850G1X-19.169Y-55.377 N20860G1X-21.012Y-54.717 N20870G1X-22.803Y-54.012 N20880G1X-24.543Y-53.260 N20890G1X-26.183Y-52.479 N20900G1X-27.919Y-51.610 N20910G1X-30.264Y-50.198 N20920G1X-32.163Y-49.023 N20930G1X-33.544Y-48.112 N20940G1X-34.474Y-47.444 N20950G2X-35.036Y-45.183I1.050J1.462 N20960G1X-30.230Y-35.488 N20970G1X-11.916Y1.257 N20980G2X-10.305Y2.255I1.611J-0.803 N20990G1X-10.085 N21000G2X-9.137Y1.985I0.000J-1.800 N21010G1X0.103Y-3.741 N21020G1X9.663Y2.170 N21030G00Z6.000 N21040G00X11.673Y3.128 N21050G1Z-1.667F1200.0 N21060G1X11.736Y3.108F1800.0 N21070G1X11.740Y3.170 N21080G1X11.673Y3.128 N21090G00Z6.000 N21100G00X13.806Y3.805 N21110G1Z-1.667F1200.0 N21120G1X25.007Y10.712F1800.0 N21130G1X25.467Y10.870 N21140G2X26.688Y10.364I0.323J-0.946 N21150G1X37.387Y-11.413 N21160G1X46.546Y-29.956 N21170G1X47.184Y-31.538 N21180G1X47.313Y-31.895 N21190G1X47.408Y-32.269 N21200G1X47.435Y-32.693 N21210G1X47.349Y-33.118 N21220G1X47.183Y-33.487 N21230G1X46.781Y-34.106 N21240G1X44.741Y-36.711 N21250G1X43.334Y-38.339 N21260G1X41.847Y-39.948 N21270G1X40.371Y-41.444 N21280G1X39.666Y-42.119 N21290G1X37.747Y-43.837 N21300G2X36.188Y-43.534I-0.663J0.748 N21310G1X13.425Y2.220 N21320G2X13.321Y2.702I0.895J0.445 N21330G1X13.332Y2.989 N21340G2X13.806Y3.805I0.999J-0.036 N21350G1X13.386Y4.486 N21360G1X24.491Y11.335 N21370G2X24.854Y11.506I0.945J-1.532 N21380G1X25.208Y11.627 N21390G2X27.406Y10.716I0.582J-1.703 N21400G1X38.105Y-11.059 N21410G1X47.276Y-29.629 N21420G1X47.931Y-31.253 N21430G1X48.078Y-31.659 N21440G1X48.202Y-32.144 N21450G1X48.225Y-32.513 N21460G2X48.193Y-32.979I-1.797J-0.111 N21470G1X48.156Y-33.165 N21480G2X48.032Y-33.550I-1.765J0.354 N21490G1X47.887Y-33.872 N21500G1X47.432Y-34.571 N21510G1X45.361Y-37.217 N21520G1X43.931Y-38.872 N21530G1X42.426Y-40.500 N21540G1X40.929Y-42.017 N21550G1X40.212Y-42.703 N21560G1X38.277Y-44.436 N21570G2X35.472Y-43.891I-1.194J1.347 N21580G1X12.709Y1.864 N21590G2X12.522Y2.730I1.612J0.802 N21600G1X12.532Y3.018 N21610G2X13.386Y4.486I1.799J-0.065 N21620G00Z6.000 N21630G00X-11.216Y2.890 N21640G1Z-1.667F1200.0 N21650G1X-11.152Y2.913F1800.0 N21660G1X-11.230Y2.961 N21670G1X-11.216Y2.890 N21680G00Z6.000 N21690G00X-25.977Y10.311 N21700G1Z-1.667F1200.0 N21710G1X-25.843Y10.450F1800.0 N21720G2X-24.597Y10.606I0.720J-0.694 N21730G1X-15.185Y4.776 N21740G1X-14.121Y4.099 N21750G1X-13.732Y3.831 N21760G1X-13.416Y3.589 N21770G1X-13.140Y3.330 N21780G1X-12.990Y3.121 N21790G2X-12.832Y2.780I-0.813J-0.583 N21800G1X-12.805Y2.671 N21810G2X-12.812Y2.160I-0.970J-0.243 N21820G1X-12.869Y1.956 N21830G1X-13.079Y1.563 N21840G1X-35.662Y-43.861 N21850G2X-36.558Y-44.416I-0.895J0.445 N21860G1X-36.768 N21870G2X-37.441Y-44.156I0.000J1.000 N21880G1X-39.860Y-41.943 N21890G1X-40.443Y-41.375 N21900G1X-41.676Y-40.116 N21910G1X-42.950Y-38.753 N21920G1X-44.181Y-37.381 N21930G1X-45.289Y-36.090 N21940G1X-46.192Y-34.974 N21950G1X-46.552Y-34.495 N21960G1X-46.839Y-34.078 N21970G1X-47.051Y-33.713 N21980G1X-47.157Y-33.460 N21990G1X-47.210Y-33.194 N22000G1Y-32.918 N22010G2X-47.106Y-32.475I1.000J0.000 N22020G1X-34.013Y-5.953 N22030G1X-26.154Y10.057 N22040G2X-25.977Y10.311I0.898J-0.440 N22050G1X-26.553Y10.866 N22060G1X-26.419Y11.005 N22070G2X-24.176Y11.286I1.296J-1.249 N22080G1X-14.759Y5.453 N22090G1X-13.680Y4.767 N22100G1X-13.261Y4.478 N22110G1X-12.898Y4.199 N22120G1X-12.535Y3.860 N22130G1X-12.340Y3.587 N22140G2X-12.056Y2.975I-1.463J-1.049 N22150G1X-12.029Y2.865 N22160G2X-12.041Y1.945I-1.746J-0.437 N22170G1X-12.069Y1.847 N22180G2X-12.215Y1.481I-1.734J0.484 N22190G1X-34.946Y-44.217 N22200G2X-36.558Y-45.216I-1.612J0.801 N22210G1X-36.768 N22220G2X-37.979Y-44.748I0.000J1.800 N22230G1X-40.412Y-42.522 N22240G1X-41.008Y-41.942 N22250G1X-42.255Y-40.669 N22260G1X-43.540Y-39.294 N22270G1X-44.782Y-37.909 N22280G1X-45.903Y-36.602 N22290G1X-46.823Y-35.466 N22300G1X-47.201Y-34.962 N22310G1X-47.516Y-34.507 N22320G1X-47.770Y-34.069 N22330G1X-47.926Y-33.694 N22340G1X-48.010Y-33.272 N22350G1Y-32.918 N22360G2X-47.823Y-32.120I1.800J0.000 N22370G1X-34.731Y-5.599 N22380G1X-26.873Y10.410 N22390G2X-26.553Y10.866I1.616J-0.792 N22400G00Z6.000 N22410G00X-39.574Y20.484 N22420G1Z-1.667F1200.0 N22430G1X-39.533Y20.500F1800.0 N22440G1X-39.584Y20.532 N22450G1X-39.574Y20.484 N22460G00Z6.000 N22470G00X-41.184Y20.301 N22480G1Z-1.667F1200.0 N22490G2X-41.221Y19.490I-0.931J-0.364F1800.0 N22500G1X-48.285Y5.352 N22510G1X-55.401Y-8.841 N22520G2X-56.693Y-9.310I-0.894J0.448 N22530G1X-56.721Y-9.298 N22540G2X-57.209Y-8.845I0.398J0.917 N22550G1X-57.289Y-8.691 N22560G1X-57.414Y-8.291 N22570G1X-57.541Y-7.774 N22580G1X-58.019Y-3.582 N22590G1X-58.009Y1.705 N22600G1X-57.977Y3.034 N22610G1X-57.920Y4.287 N22620G1X-57.836Y5.494 N22630G1X-57.722Y6.683 N22640G1X-57.576Y7.884 N22650G1X-57.396Y9.125 N22660G1X-57.021Y11.295 N22670G1X-56.843Y12.171 N22680G1X-56.438Y13.943 N22690G1X-55.966Y15.741 N22700G1X-55.438Y17.538 N22710G1X-54.861Y19.310 N22720G1X-54.241Y21.034 N22730G1X-53.587Y22.681 N22740G1X-52.903Y24.236 N22750G1X-52.061Y26.050 N22760G2X-51.154Y26.629I0.907J-0.421 N22770G1X-50.800 N22780G2X-50.274Y26.479I0.000J-1.000 N22790G1X-41.752Y21.204 N22800G2X-41.347Y20.717I-0.526J-0.850 N22810G1X-41.184Y20.301 N22820G1X-40.439Y20.592 N22830G2X-40.505Y19.133I-1.677J-0.655 N22840G1X-47.570Y4.994 N22850G1X-54.686Y-9.200 N22860G2X-57.012Y-10.044I-1.609J0.807 N22870G1X-57.040Y-10.032 N22880G2X-57.917Y-9.216I0.717J1.651 N22890G1X-58.031Y-8.999 N22900G1X-58.185Y-8.506 N22910G1X-58.330Y-7.915 N22920G1X-58.819Y-3.628 N22930G1X-58.809Y1.718 N22940G1X-58.776Y3.062 N22950G1X-58.719Y4.333 N22960G1X-58.633Y5.560 N22970G1X-58.518Y6.769 N22980G1X-58.369Y7.990 N22990G1X-58.186Y9.248 N23000G1X-57.806Y11.446 N23010G1X-57.625Y12.340 N23020G1X-57.215Y14.134 N23030G1X-56.737Y15.955 N23040G1X-56.203Y17.775 N23050G1X-55.618Y19.570 N23060G1X-54.989Y21.317 N23070G1X-54.327Y22.986 N23080G1X-53.631Y24.569 N23090G1X-52.787Y26.387 N23100G2X-51.154Y27.429I1.633J-0.758 N23110G1X-50.800 N23120G2X-49.853Y27.160I0.000J-1.800 N23130G1X-41.331Y21.884 N23140G2X-40.601Y21.009I-0.947J-1.530 N23150G1X-40.439Y20.592 N23160G00Z6.000 N23170G00X-21.056Y47.608 N23180G1Z-1.667F1200.0 N23190G1X-21.006Y47.776F1800.0 N23200G1X-21.192Y47.695 N23210G1X-21.056Y47.608 N23220G1X-21.457Y46.915 N23230G1X-20.592Y46.362 N23240G1X-19.761Y49.155 N23250G1X-21.081Y48.617 N23260G1X-22.152Y48.147 N23270G1X-22.870Y47.813 N23280G1X-21.457Y46.915 N23290G1X-21.887Y46.241 N23300G1X-20.127Y45.115 N23310G1X-18.535Y50.471 N23320G1X-20.294Y49.807 N23330G1X-21.394Y49.353 N23340G1X-22.482Y48.876 N23350G1X-23.557Y48.375 N23360G1X-24.509Y47.906 N23370G1X-21.887Y46.241 N23380G1X-22.317Y45.566 N23390G1X-19.662Y43.867 N23400G1X-17.324Y51.734 N23410G1X-18.322Y51.398 N23420G1X-19.463Y50.986 N23430G1X-20.591Y50.550 N23440G1X-21.707Y50.089 N23450G1X-22.811Y49.605 N23460G1X-23.903Y49.097 N23470G1X-24.981Y48.565 N23480G1X-26.111Y47.975 N23490G1X-22.317Y45.566 N23500G1X-22.747Y44.891 N23510G1X-19.197Y42.620 N23520G1X-16.129Y52.947 N23530G1X-17.415Y52.548 N23540G1X-18.585Y52.154 N23550G1X-19.743Y51.735 N23560G1X-20.888Y51.292 N23570G1X-22.021Y50.825 N23580G1X-23.141Y50.334 N23590G1X-24.248Y49.818 N23600G1X-25.343Y49.279 N23610G1X-26.425Y48.715 N23620G1X-27.676Y48.021 N23630G1X-22.747Y44.891 N23640G1X-23.177Y44.217 N23650G1X-18.732Y41.373 N23660G1X-14.947Y54.114 N23670G1X-16.463Y53.683 N23680G1X-17.662Y53.309 N23690G1X-18.849Y52.909 N23700G1X-20.023Y52.485 N23710G1X-21.185Y52.035 N23720G1X-22.334Y51.561 N23730G1X-23.470Y51.063 N23740G1X-24.594Y50.540 N23750G1X-25.705Y49.992 N23760G1X-26.802Y49.420 N23770G1X-27.887Y48.824 N23780G1X-29.212Y48.049 N23790G1X-23.177Y44.217 N23800G1X-23.607Y43.542 N23810G1X-18.267Y40.126 N23820G1X-13.777Y55.241 N23830G1X-15.466Y54.804 N23840G1X-16.693Y54.450 N23850G1X-17.909Y54.070 N23860G1X-19.113Y53.665 N23870G1X-20.303Y53.234 N23880G1X-21.482Y52.778 N23890G1X-22.647Y52.298 N23900G1X-23.800Y51.792 N23910G1X-24.940Y51.261 N23920G1X-26.066Y50.706 N23930G1X-27.180Y50.126 N23940G1X-28.280Y49.521 N23950G1X-29.367Y48.891 N23960G1X-30.719Y48.058 N23970G1X-23.607Y43.542 N23980G1X-24.037Y42.868 N23990G1X-17.802Y38.878 N24000G1X-12.617Y56.333 N24010G1X-14.422Y55.908 N24020G1X-15.679Y55.575 N24030G1X-16.924Y55.216 N24040G1X-18.156Y54.831 N24050G1X-19.376Y54.420 N24060G1X-20.584Y53.983 N24070G1X-21.778Y53.521 N24080G1X-22.960Y53.034 N24090G1X-24.129Y52.521 N24100G1X-25.285Y51.983 N24110G1X-26.428Y51.419 N24120G1X-27.558Y50.831 N24130G1X-28.673Y50.217 N24140G1X-29.776Y49.579 N24150G1X-30.864Y48.916 N24160G1X-32.200Y48.051 N24170G1X-24.037Y42.868 N24180G1X-24.467Y42.193 N24190G1X-17.337Y37.631 N24200G1X-11.640Y56.811 N24210G2X-11.415Y57.402I4.026J-1.198 N24220G1X-13.333Y56.995 N24230G1X-14.619Y56.684 N24240G1X-15.892Y56.346 N24250G1X-17.154Y55.982 N24260G1X-18.403Y55.592 N24270G1X-19.640Y55.175 N24280G1X-20.864Y54.733 N24290G1X-22.075Y54.264 N24300G1X-23.274Y53.770 N24310G1X-24.459Y53.250 N24320G1X-25.631Y52.704 N24330G1X-26.790Y52.133 N24340G1X-27.935Y51.536 N24350G1X-29.067Y50.914 N24360G1X-30.184Y50.267 N24370G1X-31.288Y49.594 N24380G1X-32.378Y48.896 N24390G1X-33.666Y48.022 N24400G1X-24.467Y42.193 N24410G1X-24.897Y41.518 N24420G1X-16.872Y36.384 N24430G1X-10.873Y56.583 N24440G2X-9.232Y58.604I3.259J-0.970 N24450G1X-10.873Y58.324 N24460G1X-12.199Y58.063 N24470G1X-13.513Y57.774 N24480G1X-14.815Y57.459 N24490G1X-16.106Y57.117 N24500G1X-17.384Y56.748 N24510G1X-18.650Y56.353 N24520G1X-19.904Y55.931 N24530G1X-21.144Y55.482 N24540G1X-22.372Y55.007 N24550G1X-23.587Y54.506 N24560G1X-24.789Y53.979 N24570G1X-25.977Y53.426 N24580G1X-27.152Y52.847 N24590G1X-28.313Y52.242 N24600G1X-29.460Y51.611 N24610G1X-30.593Y50.954 N24620G1X-31.712Y50.272 N24630G1X-32.817Y49.565 N24640G1X-33.907Y48.832 N24650G1X-35.408Y47.758 N24660G2X-34.495Y47.524I-0.382J-3.379 N24670G1X-34.371Y47.473 N24680G2X-33.843Y47.199I-1.295J-3.144 N24690G1X-24.897Y41.518 N24700G00Z6.000 N24710G00X-6.187Y59.013 N24720G1Z-1.667F1200.0 N24730G1X5.912Y59.016F1800.0 N24740G1X3.675Y59.135 N24750G1X1.254Y59.200 N24760G1X-3.466Y59.293 N24770G1X-6.187Y59.013 N24780G00Z6.000 N24790G00X23.080Y47.647 N24800G1Z-1.667F1200.0 N24810G1X23.061Y47.528F1800.0 N24820G1X23.176Y47.602 N24830G1X23.080Y47.647 N24840G1X23.236Y48.456 N24850G1X22.389Y48.840 N24860G2X21.720Y45.721I-8.995J0.298 N24870G1X24.798Y47.690 N24880G1X24.354Y47.938 N24890G1X23.236Y48.456 N24900G1X23.569Y49.183 N24910G1X21.539Y50.081 N24920G2X18.431Y42.668I-8.146J-0.943 N24930G1X26.354Y47.735 N24940G1X24.718Y48.651 N24950G1X23.569Y49.183 N24960G1X23.902Y49.911 N24970G1X21.900Y50.798 N24980G1X20.443Y51.389 N24990G2X16.502Y42.422I-7.049J-2.251 N25000G1X17.221Y40.944 N25010G1X27.899Y47.774 N25020G1X25.082Y49.364 N25030G1X23.902Y49.911 N25040G1X24.235Y50.638 N25050G1X22.212Y51.535 N25060G1X20.218Y52.337 N25070G1X18.939Y52.807 N25080G1X19.299Y52.085 N25090G2X15.404Y42.851I-5.906J-2.947 N25100G1X16.895Y39.786 N25110G1X29.423Y47.799 N25120G1X28.785Y48.187 N25130G1X27.483Y48.937 N25140G1X25.446Y50.077 N25150G1X24.235Y50.638 N25160G1X24.569Y51.365 N25170G1X22.523Y52.272 N25180G1X20.503Y53.084 N25190G1X18.480Y53.816 N25200G1X17.356Y54.187 N25210G1X18.583Y51.728 N25220G2X14.253Y43.402I-5.190J-2.590 N25230G1X16.570Y38.631 N25240G1X30.920Y47.807 N25250G1X30.436Y48.119 N25260G1X29.193Y48.876 N25270G1X27.878Y49.633 N25280G1X25.810Y50.790 N25290G1X24.569Y51.365 N25300G1X24.902Y52.092 N25310G1X22.835Y53.008 N25320G1X20.789Y53.832 N25330G1X18.738Y54.574 N25340G1X16.673Y55.237 N25350G1X15.813Y55.489 N25360G1X17.868Y51.370 N25370G2X13.277Y44.139I-4.474J-2.233 N25380G1X13.025Y44.146 N25390G1X13.670Y42.760 N25400G1X16.246Y37.477 N25410G1X32.392Y47.799 N25420G1X30.860Y48.797 N25430G1X29.601Y49.564 N25440G1X28.272Y50.329 N25450G1X26.174Y51.503 N25460G1X24.902Y52.092 N25470G1X25.235Y52.820 N25480G1X23.146Y53.745 N25490G1X21.075Y54.579 N25500G1X18.997Y55.331 N25510G1X16.905Y56.003 N25520G1X14.790Y56.600 N25530G1X14.303Y56.723 N25540G1X17.152Y51.013 N25550G2X13.296Y44.939I-3.758J-1.875 N25560G1X12.883Y44.949 N25570G1X11.684Y45.134 N25580G1X12.947Y42.416 N25590G1X15.921Y36.323 N25600G1X33.840Y47.776 N25610G1X32.525Y48.676 N25620G1X31.285Y49.475 N25630G1X30.008Y50.253 N25640G1X28.667Y51.024 N25650G1X26.538Y52.216 N25660G1X25.235Y52.820 N25670G1X25.568Y53.547 N25680G1X23.458Y54.482 N25690G1X21.360Y55.326 N25700G1X20.309Y55.717 N25710G1X19.255Y56.088 N25720G1X18.198Y56.438 N25730G1X17.136Y56.769 N25740G1X16.068Y57.081 N25750G1X14.993Y57.373 N25760G1X13.910Y57.647 N25770G1X12.642Y57.941 N25780G2X13.203Y57.135I-2.482J-2.324 N25790G1X16.436Y50.656 N25800G2X13.314Y45.739I-3.042J-1.518 N25810G1X12.954Y45.747 N25820G1X10.333Y46.145 N25830G1X12.224Y42.073 N25840G1X15.597Y35.168 N25850G1X34.384Y47.174 N25860G2X35.427Y47.617I1.832J-2.864 N25870G1X34.196Y48.506 N25880G1X32.968Y49.343 N25890G1X31.710Y50.154 N25900G1X30.416Y50.941 N25910G1X29.062Y51.720 N25920G1X26.902Y52.929 N25930G1X25.568Y53.547 N25940G00Z6.000 N25950G00X36.688Y45.191 N25960G1Z-1.667F1200.0 N25970G1X37.404Y44.808F1800.0 N25980G1X40.727Y41.614 N25990G1X41.610Y40.721 N26000G1X42.477Y39.812 N26010G1X43.321Y38.895 N26020G1X44.134Y37.979 N26030G1X44.908Y37.071 N26040G1X45.636Y36.181 N26050G1X47.236Y34.098 N26060G1X49.956Y29.998 N26070G2X49.821Y28.729I-0.833J-0.553 N26080G1X49.463Y28.379 N26090G1X0.822Y-1.692 N26100G2X0.239Y-1.840I-0.525J0.851 N26110G1X-0.268Y-1.810 N26120G2X-0.737Y-1.662I0.058J0.998 N26130G1X-34.279Y19.133 N26140G1X-49.512Y28.549 N26150G2X-49.986Y29.400I0.526J0.851 N26160G1Y29.665 N26170G2X-49.818Y30.220I1.000J0.000 N26180G1X-47.746Y33.307 N26190G1X-46.606Y34.891 N26200G1X-45.400Y36.457 N26210G1X-44.142Y37.987 N26220G1X-42.849Y39.464 N26230G1X-41.535Y40.872 N26240G1X-40.215Y42.192 N26250G1X-38.902Y43.409 N26260G1X-38.253Y43.973 N26270G1X-37.395Y44.684 N26280G1X-37.056Y44.940 N26290G1X-36.742Y45.144 N26300G1X-36.398Y45.310 N26310G1X-36.138Y45.368 N26320G2X-35.820Y45.388I0.219J-0.976 N26330G1X-35.691Y45.375 N26340G2X-35.409Y45.305I-0.099J-0.995 N26350G1X-35.204Y45.220 N26360G1X-26.187Y39.495 N26370G1X-16.074Y33.024 N26380G1X-15.473Y32.656 N26390G1X-8.573Y55.898 N26400G2X-7.615Y56.613I0.958J-0.285 N26410G1X10.160Y56.617 N26420G2X11.055Y56.063I0.000J-1.000 N26430G1X14.289Y49.584 N26440G2X13.370Y48.138I-0.895J-0.447 N26450G1X13.167Y48.143 N26460G1X10.520Y48.542 N26470G1X9.697Y48.626 N26480G1X8.862Y48.683 N26490G1X8.059Y48.711 N26500G1X7.335Y48.711 N26510G1X6.573Y48.663 N26520G1X7.249Y47.088 N26530G1X10.057Y41.042 N26540G1X13.547Y33.898 N26550G1X14.630Y31.710 N26560G1X19.984Y35.114 N26570G1X35.677Y45.152 N26580G2X36.688Y45.191I0.539J-0.842 N26590G1X37.066Y45.896 N26600G1X37.661Y45.577 N26610G2X38.055Y45.292I-0.850J-1.587 N26620G1X41.291Y42.182 N26630G1X42.184Y41.278 N26640G1X43.061Y40.359 N26650G1X43.915Y39.431 N26660G1X44.737Y38.504 N26670G1X45.522Y37.584 N26680G1X46.261Y36.680 N26690G1X47.888Y34.562 N26700G1X50.623Y30.440 N26710G2X50.380Y28.156I-1.500J-0.995 N26720G1X50.100Y27.883 N26730G2X49.790Y27.641I-1.257J1.289 N26740G1X1.242Y-2.373 N26750G2X0.193Y-2.638I-0.946J1.532 N26760G1X-0.314Y-2.609 N26770G2X-1.159Y-2.342I0.104J1.797 N26780G1X-34.700Y18.453 N26790G1X-49.933Y27.869 N26800G2X-50.786Y29.400I0.946J1.531 N26810G1Y29.665 N26820G2X-50.483Y30.664I1.800J0.000 N26830G1X-48.403Y33.763 N26840G1X-47.247Y35.369 N26850G1X-46.025Y36.955 N26860G1X-44.753Y38.504 N26870G1X-43.443Y40.000 N26880G1X-42.111Y41.427 N26890G1X-40.770Y42.768 N26900G1X-39.434Y44.007 N26910G1X-38.771Y44.584 N26920G1X-37.891Y45.312 N26930G1X-37.516Y45.595 N26940G1X-37.135Y45.843 N26950G1X-36.847Y45.981 N26960G2X-36.462Y46.115I0.780J-1.622 N26970G1X-36.313Y46.149 N26980G2X-35.741Y46.184I0.395J-1.756 N26990G1X-35.612Y46.171 N27000G2X-35.104Y46.044I-0.178J-1.791 N27010G1X-34.834Y45.933 N27020G1X-25.757Y40.169 N27030G1X-15.942Y33.889 N27040G1X-9.340Y56.127 N27050G2X-7.615Y57.413I1.725J-0.513 N27060G1X10.160Y57.417 N27070G2X11.771Y56.420I0.000J-1.800 N27080G1X15.004Y49.942 N27090G2X13.352Y47.338I-1.611J-0.804 N27100G1X13.096Y47.344 N27110G1X10.424Y47.748 N27120G1X9.630Y47.829 N27130G1X8.821Y47.883 N27140G1X7.766Y47.911 N27150G1X7.979Y47.415 N27160G1X10.779Y41.386 N27170G1X14.264Y34.252 N27180G1X14.952Y32.862 N27190G1X19.554Y35.788 N27200G1X35.246Y45.826 N27210G2X37.066Y45.896I0.970J-1.516 N27220G00Z6.000 N27230G00X52.032Y26.051 N27240G1Z-1.667F1200.0 N27250G2X52.235Y25.750I-0.714J-0.700F1800.0 N27260G1X53.243Y23.429 N27270G1X53.927Y21.791 N27280G1X54.557Y20.142 N27290G1X55.133Y18.483 N27300G1X55.655Y16.810 N27310G1X56.126Y15.117 N27320G1X56.547Y13.401 N27330G1X56.919Y11.655 N27340G1X57.243Y9.883 N27350G1X57.704Y7.142 N27360G1X57.930Y3.708 N27370G1X58.029Y1.891 N27380G1X58.062Y0.262 N27390G1X58.028Y-1.372 N27400G1X57.929Y-3.204 N27410G1X57.704Y-6.623 N27420G2X57.644Y-6.904I-0.998J0.066 N27430G1X57.356Y-7.683 N27440G2X55.524Y-7.783I-0.938J0.347 N27450G1X41.729Y19.870 N27460G2X41.919Y21.026I0.895J0.446 N27470G1X42.296Y21.401 N27480G1X50.510Y26.488 N27490G2X51.751Y26.338I0.527J-0.850 N27500G1X52.032Y26.051 N27510G1X52.604Y26.611 N27520G2X52.969Y26.069I-1.286J-1.260 N27530G1X53.979Y23.743 N27540G1X54.670Y22.088 N27550G1X55.309Y20.416 N27560G1X55.893Y18.733 N27570G1X56.423Y17.036 N27580G1X56.900Y15.320 N27590G1X57.327Y13.580 N27600G1X57.704Y11.811 N27610G1X58.031Y10.021 N27620G1X58.499Y7.235 N27630G1X58.729Y3.756 N27640G1X58.828Y1.924 N27650G1X58.862Y0.262 N27660G1X58.828Y-1.406 N27670G1X58.727Y-3.252 N27680G1X58.503Y-6.675 N27690G2X58.395Y-7.182I-1.796J0.118 N27700G1X58.107Y-7.961 N27710G2X54.808Y-8.140I-1.688J0.625 N27720G1X41.013Y19.513 N27730G2X41.355Y21.594I1.611J0.804 N27740G1X41.651Y21.888 N27750G2X41.972Y22.141I1.268J-1.277 N27760G1X50.089Y27.168 N27770G2X52.323Y26.898I0.948J-1.530 N27780G1X52.604Y26.611 N27790G00Z6.000 N27800G00X40.040Y20.669 N27810G1Z-1.667F1200.0 N27820G00Z6.000 N27830G00X58.370Y-12.988 N27840G1Z-1.667F1200.0 N27850G1X58.623Y-11.743F1800.0 N27860G1X58.871Y-10.355 N27870G1X58.994Y-9.556 N27880G2X57.360Y-10.603I-2.575J2.220 N27890G1X57.854Y-11.599 N27900G1X58.093Y-12.143 N27910G1X58.243Y-12.554 N27920G1X58.370Y-12.988 N27930G00Z6.000 N27940G00X48.162Y-28.893 N27950G1Z-1.667F1200.0 N27960G1X47.871Y-28.179F1800.0 N27970G1X35.452Y-3.088 N27980G2X35.357Y-2.772I0.896J0.444 N27990G1X28.547Y10.878 N28000G1X28.214Y11.734 N28010G2X28.620Y12.947I0.932J0.362 N28020G1X38.043Y18.773 N28030G1X38.416Y18.977 N28040G1X38.741Y19.126 N28050G1X38.877Y19.167 N28060G2X39.245Y19.207I0.291J-0.957 N28070G1X39.280Y19.204 N28080G2X40.096Y18.656I-0.078J-0.997 N28090G1X47.668Y3.551 N28100G1X55.679Y-12.615 N28110G1X55.865Y-13.038 N28120G1X56.014Y-13.447 N28130G1X56.109Y-13.904 N28140G1X56.114Y-14.393 N28150G1X56.037Y-14.894 N28160G1X55.899Y-15.444 N28170G1X55.443Y-16.920 N28180G1X54.920Y-18.483 N28190G1X54.337Y-20.087 N28200G1X53.710Y-21.692 N28210G1X53.055Y-23.262 N28220G1X52.387Y-24.762 N28230G1X51.722Y-26.154 N28240G1X51.076Y-27.401 N28250G1X50.455Y-28.482 N28260G1X50.158Y-28.952 N28270G1X49.972Y-29.196 N28280G1X49.813Y-29.325 N28290G2X49.152Y-29.549I-0.632J0.775 N28300G1X49.097Y-29.547 N28310G2X48.382Y-29.215I0.030J1.000 N28320G1X48.333Y-29.160 N28330G2X48.162Y-28.893I0.745J0.667 N28340G1X47.428Y-29.212 N28350G1X47.138Y-28.502 N28360G1X34.735Y-3.442 N28370G2X34.590Y-3.027I1.613J0.798 N28380G1X27.814Y10.554 N28390G1X27.468Y11.444 N28400G2X28.199Y13.628I1.678J0.652 N28410G1X37.646Y19.468 N28420G1X38.058Y19.692 N28430G1X38.457Y19.875 N28440G1X38.644Y19.932 N28450G2X39.307Y20.005I0.524J-1.722 N28460G1X39.342Y20.002 N28470G2X40.811Y19.014I-0.140J-1.795 N28480G1X48.384Y3.908 N28490G1X56.404Y-12.276 N28500G1X56.607Y-12.740 N28510G1X56.786Y-13.227 N28520G1X56.908Y-13.818 N28530G1X56.914Y-14.450 N28540G1X56.822Y-15.052 N28550G1X56.669Y-15.660 N28560G1X56.205Y-17.165 N28570G1X55.676Y-18.747 N28580G1X55.086Y-20.369 N28590G1X54.452Y-21.991 N28600G1X53.790Y-23.579 N28610G1X53.114Y-25.097 N28620G1X52.439Y-26.511 N28630G1X51.781Y-27.780 N28640G1X51.138Y-28.899 N28650G1X50.815Y-29.410 N28660G1X50.679Y-29.588 N28670G2X50.386Y-29.890I-1.430J1.094 N28680G1X50.319Y-29.945 N28690G2X49.128Y-30.349I-1.137J1.396 N28700G1X49.074Y-30.347 N28710G2X47.786Y-29.748I0.054J1.799 N28720G1X47.737Y-29.693 N28730G2X47.428Y-29.212I1.342J1.200 N28740G00Z6.000 N28750G00X49.710Y-33.551 N28760G1Z-1.667F1200.0 N28770G1X50.786Y-31.864F1800.0 N28780G1X51.087Y-31.366 N28790G2X49.775Y-31.897I-1.905J2.816 N28800G1X49.822Y-32.414 N28810G2X49.762Y-33.293I-3.394J-0.210 N28820G1X49.710Y-33.551 N28830G00Z6.000 N28840G00X36.326Y-47.909 N28850G1Z-1.667F1200.0 N28860G1X37.381Y-47.081F1800.0 N28870G1X38.440Y-46.206 N28880G2X36.924Y-46.485I-1.357J3.117 N28890G2X36.326Y-47.909I-3.352J0.570 N28900G00Z6.000 N28910G00X28.066Y-53.259 N28920G1Z-1.667F1200.0 N28930G1X29.233Y-52.688F1800.0 N28940G1X30.205Y-52.079 N28950G1X28.927Y-52.797 N28960G1X28.066Y-53.259 N28970G00Z6.000 N28980G00X6.227Y-59.956 N28990G1Z-1.667F1200.0 N29000G1X7.013Y-59.874F1800.0 N29010G1X8.340Y-59.705 N29020G1X9.658Y-59.506 N29030G1X10.968Y-59.276 N29040G1X12.271Y-59.016 N29050G1X13.569Y-58.725 N29060G1X14.862Y-58.404 N29070G1X16.151Y-58.051 N29080G1X17.437Y-57.666 N29090G1X18.720Y-57.249 N29100G1X20.003Y-56.800 N29110G1X20.723Y-56.530 N29120G1X17.763Y-57.507 N29130G1X16.508Y-57.885 N29140G1X15.258Y-58.230 N29150G1X14.000Y-58.547 N29160G1X12.723Y-58.837 N29170G1X11.414Y-59.103 N29180G1X10.060Y-59.350 N29190G1X6.227Y-59.956 N29200G00Z6.000 N29210G00X-28.350Y-53.184 N29220G1Z-1.667F1200.0 N29230G1X-26.859Y-53.963F1800.0 N29240G1X-25.843Y-54.462 N29250G1X-24.818Y-54.941 N29260G1X-23.786Y-55.400 N29270G1X-22.745Y-55.838 N29280G1X-21.697Y-56.256 N29290G1X-20.640Y-56.654 N29300G1X-19.575Y-57.031 N29310G1X-18.501Y-57.388 N29320G1X-17.420Y-57.726 N29330G1X-16.329Y-58.042 N29340G1X-15.231Y-58.339 N29350G1X-14.123Y-58.616 N29360G1X-13.008Y-58.872 N29370G1X-11.883Y-59.108 N29380G1X-10.750Y-59.324 N29390G1X-9.608Y-59.520 N29400G1X-8.458Y-59.695 N29410G1X-7.298Y-59.850 N29420G1X-6.130Y-59.985 N29430G1X-4.952Y-60.099 N29440G1X-1.234Y-60.372 N29450G1X1.594Y-60.310 N29460G1X2.725Y-60.256 N29470G1X3.986Y-60.164 N29480G1X5.904Y-59.990 N29490G1X-4.309Y-60.113 N29500G1X-5.628Y-59.933 N29510G1X-9.247Y-59.528 N29520G1X-13.011Y-58.770 N29530G1X-14.901Y-58.321 N29540G1X-15.869Y-58.065 N29550G1X-17.773Y-57.511 N29560G1X-19.686Y-56.891 N29570G1X-21.575Y-56.215 N29580G1X-23.408Y-55.493 N29590G1X-25.204Y-54.717 N29600G1X-26.892Y-53.914 N29610G1X-28.350Y-53.184 N29620G00Z6.000 N29630G00X-33.584Y-50.010 N29640G1Z-1.667F1200.0 N29650G1X-31.823Y-51.161F1800.0 N29660G1X-30.846Y-51.763 N29670G1X-29.861Y-52.343 N29680G1X-28.928Y-52.870 N29690G1X-31.098Y-51.563 N29700G1X-33.584Y-50.010 N29710G00Z6.000 N29720G00X-38.508Y-46.337 N29730G1Z-1.667F1200.0 N29740G1X-36.593Y-47.844F1800.0 N29750G1X-35.650Y-48.552 N29760G2X-36.720Y-46.816I2.226J2.570 N29770G1X-36.768 N29780G2X-38.508Y-46.337I0.000J3.400 N29790G00Z6.000 N29800G00X-39.422Y-45.611 N29810G1Z-1.667F1200.0 N29820G1X-39.309Y-45.701F1800.0 N29830G1X-39.612Y-45.426 N29840G1X-39.422Y-45.611 N29850G1X-39.952Y-46.212 N29860G1X-37.079Y-48.479 N29870G1X-36.129Y-49.193 N29880G1X-35.171Y-49.886 N29890G1X-34.205Y-50.557 N29900G1X-33.231Y-51.208 N29910G1X-32.249Y-51.839 N29920G1X-31.259Y-52.448 N29930G1X-30.261Y-53.036 N29940G1X-29.255Y-53.604 N29950G1X-28.241Y-54.152 N29960G1X-27.219Y-54.678 N29970G1X-26.188Y-55.184 N29980G1X-25.150Y-55.669 N29990G1X-24.103Y-56.134 N30000G1X-23.049Y-56.578 N30010G1X-21.986Y-57.002 N30020G1X-20.914Y-57.405 N30030G1X-19.835Y-57.788 N30040G1X-18.747Y-58.150 N30050G1X-17.650Y-58.492 N30060G1X-16.545Y-58.813 N30070G1X-15.432Y-59.113 N30080G1X-14.310Y-59.394 N30090G1X-13.179Y-59.653 N30100G1X-12.040Y-59.893 N30110G1X-10.893Y-60.111 N30120G1X-9.736Y-60.309 N30130G1X-8.571Y-60.487 N30140G1X-7.397Y-60.644 N30150G1X-6.214Y-60.780 N30160G1X-5.023Y-60.896 N30170G1X-1.254Y-61.172 N30180G1X1.623Y-61.109 N30190G1X2.773Y-61.055 N30200G1X4.050Y-60.962 N30210G1X5.741Y-60.811 N30220G1X7.105Y-60.669 N30230G1X8.450Y-60.498 N30240G1X9.787Y-60.296 N30250G1X11.115Y-60.063 N30260G1X12.437Y-59.799 N30270G1X13.753Y-59.504 N30280G1X15.064Y-59.178 N30290G1X16.371Y-58.820 N30300G1X17.675Y-58.430 N30310G1X18.976Y-58.007 N30320G1X20.276Y-57.552 N30330G1X21.575Y-57.065 N30340G1X22.875Y-56.544 N30350G1X24.175Y-55.989 N30360G1X25.478Y-55.401 N30370G1X26.795Y-54.772 N30380G1X29.622Y-53.388 N30390G1X32.803Y-51.384 N30400G1X34.546Y-50.208 N30410G1X36.239Y-48.982 N30420G1X37.882Y-47.705 N30430G1X39.476Y-46.377 N30440G1X41.018Y-45.001 N30450G1X42.509Y-43.576 N30460G1X43.948Y-42.103 N30470G1X45.335Y-40.582 N30480G1X46.670Y-39.014 N30490G1X47.951Y-37.399 N30500G1X49.178Y-35.739 N30510G1X50.350Y-34.033 N30520G1X51.468Y-32.283 N30530G1X52.530Y-30.488 N30540G1X53.536Y-28.650 N30550G1X55.364Y-25.045 N30560G1X56.659Y-21.706 N30570G1X57.161Y-20.298 N30580G1X57.626Y-18.894 N30590G1X58.054Y-17.494 N30600G1X58.446Y-16.095 N30610G1X58.802Y-14.696 N30620G1X59.123Y-13.296 N30630G1X59.409Y-11.893 N30640G1X59.661Y-10.486 N30650G1X59.877Y-9.073 N30660G1X60.060Y-7.652 N30670G1X60.209Y-6.222 N30680G1X60.324Y-4.781 N30690G1X60.406Y-3.328 N30700G1X60.454Y-1.862 N30710G1X60.469Y-0.366 N30720G1X60.466Y3.187 N30730G1X60.250Y5.256 N30740G1X60.027Y7.125 N30750G1X59.756Y8.959 N30760G1X59.433Y10.776 N30770G1X59.059Y12.574 N30780G1X58.635Y14.353 N30790G1X58.161Y16.114 N30800G1X57.636Y17.854 N30810G1X57.061Y19.573 N30820G1X56.437Y21.272 N30830G1X55.764Y22.949 N30840G1X55.042Y24.603 N30850G1X54.270Y26.234 N30860G1X53.451Y27.841 N30870G1X52.582Y29.425 N30880G1X51.665Y30.983 N30890G1X50.697Y32.521 N30900G1X49.811Y33.854 N30910G1X48.945Y35.096 N30920G1X48.083Y36.266 N30930G1X47.205Y37.389 N30940G1X46.292Y38.491 N30950G1X45.321Y39.598 N30960G1X44.273Y40.735 N30970G1X41.138Y43.952 N30980G1X39.472Y45.394 N30990G1X38.273Y46.406 N31000G1X37.081Y47.363 N31010G1X35.877Y48.280 N31020G1X34.655Y49.161 N31030G1X33.410Y50.010 N31040G1X32.134Y50.832 N31050G1X30.823Y51.630 N31060G1X29.457Y52.416 N31070G1X27.266Y53.642 N31080G1X24.830Y54.760 N31090G1X22.708Y55.657 N31100G1X21.646Y56.074 N31110G1X20.581Y56.469 N31120G1X19.514Y56.845 N31130G1X18.443Y57.200 N31140G1X17.367Y57.535 N31150G1X16.285Y57.851 N31160G1X15.196Y58.147 N31170G1X14.099Y58.425 N31180G1X12.994Y58.683 N31190G1X11.879Y58.923 N31200G1X9.616Y59.349 N31210G1X7.791Y59.631 N31220G1X6.379Y59.783 N31230G1X5.598Y59.842 N31240G1X3.705Y59.935 N31250G1X1.273Y60.000 N31260G1X-3.498Y60.094 N31270G1X-6.923Y59.737 N31280G1X-8.299Y59.556 N31290G1X-9.665Y59.347 N31300G1X-11.019Y59.110 N31310G1X-12.362Y58.846 N31320G1X-13.693Y58.554 N31330G1X-15.012Y58.235 N31340G1X-16.319Y57.888 N31350G1X-17.614Y57.514 N31360G1X-18.897Y57.114 N31370G1X-20.167Y56.686 N31380G1X-21.425Y56.231 N31390G1X-22.669Y55.750 N31400G1X-23.900Y55.242 N31410G1X-25.118Y54.708 N31420G1X-26.323Y54.147 N31430G1X-27.513Y53.560 N31440G1X-28.690Y52.947 N31450G1X-29.853Y52.308 N31460G1X-31.002Y51.642 N31470G1X-32.136Y50.951 N31480G1X-33.256Y50.234 N31490G1X-34.361Y49.491 N31500G1X-35.450Y48.722 N31510G1X-36.525Y47.927 N31520G1X-37.584Y47.107 N31530G1X-38.628Y46.262 N31540G1X-39.656Y45.391 N31550G1X-40.667Y44.495 N31560G1X-41.663Y43.573 N31570G1X-42.642Y42.627 N31580G1X-43.614Y41.645 N31590G1X-45.651Y39.543 N31600G1X-46.697Y38.255 N31610G1X-47.896Y36.743 N31620G1X-48.994Y35.285 N31630G1X-50.012Y33.850 N31640G1X-50.965Y32.416 N31650G1X-51.869Y30.961 N31660G1X-52.737Y29.461 N31670G1X-53.585Y27.895 N31680G1X-54.431Y26.226 N31690G1X-56.005Y23.027 N31700G1X-56.787Y20.921 N31710G1X-57.358Y19.307 N31720G1X-57.891Y17.655 N31730G1X-58.387Y15.957 N31740G1X-58.844Y14.229 N31750G1X-59.258Y12.483 N31760G1X-59.626Y10.732 N31770G1X-59.944Y8.989 N31780G1X-60.206Y7.295 N31790G1X-60.316Y6.241 N31800G1X-60.426Y4.693 N31810G1X-60.519Y2.881 N31820G1X-60.581Y1.028 N31830G1X-60.682Y-3.252 N31840G1X-60.333Y-6.898 N31850G1X-60.158Y-8.346 N31860G1X-59.956Y-9.763 N31870G1X-59.728Y-11.152 N31880G1X-59.473Y-12.516 N31890G1X-59.190Y-13.859 N31900G1X-58.877Y-15.183 N31910G1X-58.535Y-16.492 N31920G1X-58.163Y-17.790 N31930G1X-57.759Y-19.080 N31940G1X-57.322Y-20.365 N31950G1X-56.852Y-21.649 N31960G1X-56.348Y-22.934 N31970G1X-55.808Y-24.224 N31980G1X-55.231Y-25.523 N31990G1X-53.246Y-29.680 N32000G1X-51.448Y-32.631 N32010G1X-50.393Y-34.257 N32020G1X-49.302Y-35.826 N32030G1X-48.168Y-37.350 N32040G1X-46.984Y-38.837 N32050G1X-45.741Y-40.296 N32060G1X-44.433Y-41.738 N32070G1X-43.758Y-42.448 N32080G1X-42.316Y-43.898 N32090G1X-39.952Y-46.212 N32100G1X-40.482Y-46.813 N32110G1X-37.565Y-49.115 N32120G1X-36.604Y-49.837 N32130G1X-35.634Y-50.538 N32140G1X-34.655Y-51.219 N32150G1X-33.669Y-51.878 N32160G1X-32.675Y-52.516 N32170G1X-31.672Y-53.133 N32180G1X-30.661Y-53.729 N32190G1X-29.641Y-54.305 N32200G1X-28.614Y-54.859 N32210G1X-27.578Y-55.393 N32220G1X-26.534Y-55.905 N32230G1X-25.482Y-56.397 N32240G1X-24.421Y-56.868 N32250G1X-23.352Y-57.319 N32260G1X-22.275Y-57.748 N32270G1X-21.189Y-58.157 N32280G1X-20.095Y-58.544 N32290G1X-18.992Y-58.911 N32300G1X-17.881Y-59.258 N32310G1X-16.761Y-59.583 N32320G1X-15.633Y-59.888 N32330G1X-14.496Y-60.172 N32340G1X-13.351Y-60.435 N32350G1X-12.197Y-60.677 N32360G1X-11.035Y-60.898 N32370G1X-9.864Y-61.099 N32380G1X-8.684Y-61.279 N32390G1X-7.496Y-61.438 N32400G1X-6.299Y-61.576 N32410G1X-5.093Y-61.693 N32420G1X-1.275Y-61.973 N32430G1X1.652Y-61.909 N32440G1X2.821Y-61.853 N32450G1X4.115Y-61.759 N32460G1X5.818Y-61.608 N32470G1X7.197Y-61.464 N32480G1X8.561Y-61.290 N32490G1X9.916Y-61.085 N32500G1X11.263Y-60.849 N32510G1X12.603Y-60.582 N32520G1X13.937Y-60.283 N32530G1X15.267Y-59.952 N32540G1X16.591Y-59.589 N32550G1X17.913Y-59.193 N32560G1X19.232Y-58.765 N32570G1X20.549Y-58.304 N32580G1X21.865Y-57.810 N32590G1X23.180Y-57.283 N32600G1X24.497Y-56.722 N32610G1X25.815Y-56.126 N32620G1X27.143Y-55.493 N32630G1X30.012Y-54.088 N32640G1X33.239Y-52.054 N32650G1X35.004Y-50.864 N32660G1X36.719Y-49.622 N32670G1X38.384Y-48.328 N32680G1X39.998Y-46.983 N32690G1X41.561Y-45.589 N32700G1X43.072Y-44.145 N32710G1X44.530Y-42.652 N32720G1X45.936Y-41.110 N32730G1X47.288Y-39.522 N32740G1X48.586Y-37.886 N32750G1X49.829Y-36.203 N32760G1X51.017Y-34.475 N32770G1X52.149Y-32.702 N32780G1X53.225Y-30.884 N32790G1X54.244Y-29.022 N32800G1X56.095Y-25.372 N32810G1X57.410Y-21.983 N32820G1X57.918Y-20.558 N32830G1X58.388Y-19.137 N32840G1X58.822Y-17.719 N32850G1X59.219Y-16.302 N32860G1X59.580Y-14.884 N32870G1X59.905Y-13.466 N32880G1X60.195Y-12.043 N32890G1X60.450Y-10.617 N32900G1X60.670Y-9.184 N32910G1X60.855Y-7.744 N32920G1X61.005Y-6.295 N32930G1X61.122Y-4.835 N32940G1X61.205Y-3.364 N32950G1X61.254Y-1.879 N32960G1X61.269Y-0.370 N32970G1X61.266Y3.229 N32980G1X61.045Y5.345 N32990G1X60.820Y7.231 N33000G1X60.545Y9.088 N33010G1X60.219Y10.927 N33020G1X59.840Y12.748 N33030G1X59.411Y14.550 N33040G1X58.930Y16.333 N33050G1X58.398Y18.096 N33060G1X57.816Y19.838 N33070G1X57.184Y21.559 N33080G1X56.502Y23.258 N33090G1X55.770Y24.934 N33100G1X54.989Y26.587 N33110G1X54.158Y28.216 N33120G1X53.278Y29.820 N33130G1X52.349Y31.399 N33140G1X51.369Y32.956 N33150G1X50.473Y34.304 N33160G1X49.595Y35.562 N33170G1X48.720Y36.749 N33180G1X47.829Y37.890 N33190G1X46.901Y39.010 N33200G1X45.916Y40.133 N33210G1X44.855Y41.284 N33220G1X41.686Y44.536 N33230G1X39.992Y46.002 N33240G1X38.782Y47.024 N33250G1X37.574Y47.994 N33260G1X36.353Y48.923 N33270G1X35.114Y49.816 N33280G1X33.852Y50.677 N33290G1X32.559Y51.510 N33300G1X31.231Y52.318 N33310G1X29.852Y53.112 N33320G1X27.630Y54.355 N33330G1X25.154Y55.491 N33340G1X24.080Y55.956 N33350G1X23.006Y56.399 N33360G1X21.931Y56.821 N33370G1X20.853Y57.222 N33380G1X19.773Y57.602 N33390G1X18.688Y57.962 N33400G1X17.598Y58.301 N33410G1X16.502Y58.621 N33420G1X15.399Y58.921 N33430G1X14.288Y59.202 N33440G1X13.169Y59.464 N33450G1X12.040Y59.707 N33460G1X10.901Y59.931 N33470G1X8.589Y60.325 N33480G1X7.190Y60.508 N33490G1X5.647Y60.640 N33500G1X3.736Y60.734 N33510G1X1.291Y60.800 N33520G1X-3.530Y60.894 N33530G1X-7.019Y60.531 N33540G1X-8.412Y60.348 N33550G1X-9.794Y60.137 N33560G1X-11.165Y59.897 N33570G1X-12.525Y59.629 N33580G1X-13.873Y59.334 N33590G1X-15.209Y59.010 N33600G1X-16.533Y58.659 N33610G1X-17.845Y58.281 N33620G1X-19.144Y57.875 N33630G1X-20.431Y57.441 N33640G1X-21.705Y56.981 N33650G1X-22.966Y56.493 N33660G1X-24.213Y55.979 N33670G1X-25.448Y55.437 N33680G1X-26.668Y54.869 N33690G1X-27.875Y54.274 N33700G1X-29.068Y53.652 N33710G1X-30.247Y53.004 N33720G1X-31.411Y52.330 N33730G1X-32.560Y51.629 N33740G1X-33.695Y50.902 N33750G1X-34.814Y50.149 N33760G1X-35.919Y49.370 N33770G1X-37.008Y48.565 N33780G1X-38.081Y47.735 N33790G1X-39.138Y46.878 N33800G1X-40.179Y45.996 N33810G1X-41.204Y45.088 N33820G1X-42.213Y44.155 N33830G1X-43.204Y43.196 N33840G1X-44.186Y42.205 N33850G1X-46.250Y40.075 N33860G1X-47.321Y38.756 N33870G1X-48.529Y37.232 N33880G1X-49.639Y35.757 N33890G1X-50.671Y34.303 N33900G1X-51.638Y32.848 N33910G1X-52.555Y31.372 N33920G1X-53.435Y29.852 N33930G1X-54.293Y28.266 N33940G1X-55.147Y26.583 N33950G1X-56.741Y23.343 N33960G1X-57.539Y21.194 N33970G1X-58.116Y19.563 N33980G1X-58.656Y17.890 N33990G1X-59.158Y16.172 N34000G1X-59.620Y14.424 N34010G1X-60.039Y12.657 N34020G1X-60.411Y10.886 N34030G1X-60.733Y9.122 N34040G1X-60.999Y7.397 N34050G1X-61.113Y6.311 N34060G1X-61.224Y4.742 N34070G1X-61.318Y2.915 N34080G1X-61.381Y1.051 N34090G1X-61.483Y-3.279 N34100G1X-61.128Y-6.987 N34110G1X-60.951Y-8.451 N34120G1X-60.747Y-9.884 N34130G1X-60.516Y-11.290 N34140G1X-60.258Y-12.672 N34150G1X-59.970Y-14.033 N34160G1X-59.654Y-15.376 N34170G1X-59.307Y-16.704 N34180G1X-58.929Y-18.020 N34190G1X-58.519Y-19.328 N34200G1X-58.077Y-20.632 N34210G1X-57.600Y-21.933 N34220G1X-57.089Y-23.235 N34230G1X-56.542Y-24.541 N34240G1X-55.959Y-25.855 N34250G1X-55.334Y-27.187 N34260G1X-53.950Y-30.062 N34270G1X-52.126Y-33.056 N34280G1X-51.057Y-34.702 N34290G1X-49.952Y-36.293 N34300G1X-48.802Y-37.838 N34310G1X-47.601Y-39.345 N34320G1X-46.342Y-40.825 N34330G1X-45.017Y-42.285 N34340G1X-44.331Y-43.005 N34350G1X-42.880Y-44.466 N34360G1X-40.482Y-46.813 N34370G1X-41.012Y-47.413 N34380G1X-38.051Y-49.750 N34390G1X-37.078Y-50.481 N34400G1X-36.096Y-51.191 N34410G1X-35.106Y-51.880 N34420G1X-34.107Y-52.547 N34430G1X-33.100Y-53.193 N34440G1X-32.085Y-53.818 N34450G1X-31.061Y-54.422 N34460G1X-30.028Y-55.005 N34470G1X-28.987Y-55.567 N34480G1X-27.938Y-56.107 N34490G1X-26.880Y-56.627 N34500G1X-25.814Y-57.125 N34510G1X-24.739Y-57.603 N34520G1X-23.655Y-58.059 N34530G1X-22.564Y-58.494 N34540G1X-21.463Y-58.908 N34550G1X-20.355Y-59.301 N34560G1X-19.237Y-59.673 N34570G1X-18.112Y-60.024 N34580G1X-16.977Y-60.353 N34590G1X-15.834Y-60.662 N34600G1X-14.683Y-60.950 N34610G1X-13.523Y-61.216 N34620G1X-12.354Y-61.461 N34630G1X-11.177Y-61.686 N34640G1X-9.992Y-61.889 N34650G1X-8.798Y-62.071 N34660G1X-7.595Y-62.232 N34670G1X-6.383Y-62.372 N34680G1X-5.163Y-62.490 N34690G1X-1.295Y-62.773 N34700G1X1.681Y-62.708 N34710G1X2.869Y-62.652 N34720G1X4.179Y-62.556 N34730G1X5.895Y-62.404 N34740G1X7.289Y-62.259 N34750G1X8.671Y-62.082 N34760G1X10.044Y-61.875 N34770G1X11.410Y-61.635 N34780G1X12.769Y-61.364 N34790G1X14.121Y-61.061 N34800G1X15.469Y-60.726 N34810G1X16.812Y-60.358 N34820G1X18.151Y-59.957 N34830G1X19.487Y-59.523 N34840G1X20.821Y-59.057 N34850G1X22.154Y-58.556 N34860G1X23.486Y-58.022 N34870G1X24.818Y-57.454 N34880G1X26.152Y-56.852 N34890G1X27.491Y-56.213 N34900G1X30.401Y-54.788 N34910G1X33.675Y-52.725 N34920G1X35.462Y-51.520 N34930G1X37.199Y-50.262 N34940G1X38.886Y-48.951 N34950G1X40.521Y-47.589 N34960G1X42.104Y-46.176 N34970G1X43.634Y-44.713 N34980G1X45.112Y-43.201 N34990G1X46.536Y-41.639 N35000G1X47.906Y-40.030 N35010G1X49.221Y-38.372 N35020G1X50.480Y-36.668 N35030G1X51.684Y-34.917 N35040G1X52.831Y-33.121 N35050G1X53.920Y-31.280 N35060G1X54.952Y-29.394 N35070G1X56.826Y-25.699 N35080G1X58.161Y-22.260 N35090G1X58.674Y-20.818 N35100G1X59.150Y-19.380 N35110G1X59.589Y-17.944 N35120G1X59.992Y-16.509 N35130G1X60.358Y-15.073 N35140G1X60.687Y-13.635 N35150G1X60.981Y-12.194 N35160G1X61.239Y-10.748 N35170G1X61.462Y-9.296 N35180G1X61.649Y-7.837 N35190G1X61.802Y-6.368 N35200G1X61.920Y-4.890 N35210G1X62.004Y-3.400 N35220G1X62.054Y-1.897 N35230G1X62.069Y-0.374 N35240G1X62.066Y3.271 N35250G1X61.840Y5.434 N35260G1X61.613Y7.337 N35270G1X61.335Y9.216 N35280G1X61.004Y11.078 N35290G1X60.621Y12.922 N35300G1X60.186Y14.747 N35310G1X59.699Y16.553 N35320G1X59.161Y18.338 N35330G1X58.572Y20.103 N35340G1X57.931Y21.846 N35350G1X57.240Y23.567 N35360G1X56.498Y25.265 N35370G1X55.707Y26.939 N35380G1X54.865Y28.590 N35390G1X53.973Y30.215 N35400G1X53.032Y31.815 N35410G1X52.041Y33.390 N35420G1X51.134Y34.755 N35430G1X50.245Y36.028 N35440G1X49.357Y37.233 N35450G1X48.452Y38.392 N35460G1X47.510Y39.529 N35470G1X46.511Y40.668 N35480G1X45.438Y41.832 N35490G1X44.267Y43.048 N35500G1X42.235Y45.120 N35510G1X40.512Y46.610 N35520G1X39.291Y47.641 N35530G1X38.066Y48.624 N35540G1X36.829Y49.566 N35550G1X35.574Y50.471 N35560G1X34.294Y51.344 N35570G1X32.984Y52.188 N35580G1X31.638Y53.007 N35590G1X30.247Y53.807 N35600G1X27.994Y55.068 N35610G1X25.478Y56.223 N35620G1X24.392Y56.693 N35630G1X23.305Y57.141 N35640G1X22.217Y57.568 N35650G1X21.126Y57.974 N35660G1X20.031Y58.359 N35670G1X18.932Y58.723 N35680G1X17.829Y59.067 N35690G1X16.719Y59.391 N35700G1X15.602Y59.695 N35710G1X14.478Y59.979 N35720G1X13.345Y60.244 N35730G1X12.202Y60.490 N35740G1X11.049Y60.718 N35750G1X9.885Y60.926 N35760G1X7.998Y61.218 N35770G1X6.515Y61.377 N35780G1X5.697Y61.439 N35790G1X3.766Y61.534 N35800G1X1.310Y61.599 N35810G1X-3.562Y61.695 N35820G1X-7.115Y61.326 N35830G1X-8.525Y61.140 N35840G1X-9.924Y60.926 N35850G1X-11.311Y60.683 N35860G1X-12.688Y60.412 N35870G1X-14.052Y60.113 N35880G1X-15.405Y59.786 N35890G1X-16.746Y59.430 N35900G1X-18.075Y59.047 N35910G1X-19.391Y58.636 N35920G1X-20.695Y58.197 N35930G1X-21.985Y57.730 N35940G1X-23.263Y57.236 N35950G1X-24.527Y56.715 N35960G1X-25.777Y56.166 N35970G1X-27.014Y55.590 N35980G1X-28.237Y54.987 N35990G1X-29.446Y54.358 N36000G1X-30.640Y53.701 N36010G1X-31.819Y53.018 N36020G1X-32.984Y52.308 N36030G1X-34.134Y51.571 N36040G1X-35.268Y50.808 N36050G1X-36.387Y50.019 N36060G1X-37.490Y49.203 N36070G1X-38.578Y48.362 N36080G1X-39.649Y47.494 N36090G1X-40.703Y46.601 N36100G1X-41.741Y45.681 N36110G1X-42.763Y44.736 N36120G1X-43.767Y43.765 N36130G1X-44.757Y42.765 N36140G1X-46.849Y40.606 N36150G1X-47.945Y39.257 N36160G1X-49.162Y37.721 N36170G1X-50.285Y36.229 N36180G1X-51.331Y34.756 N36190G1X-52.311Y33.281 N36200G1X-53.241Y31.784 N36210G1X-54.134Y30.243 N36220G1X-55.002Y28.637 N36230G1X-55.862Y26.941 N36240G1X-57.476Y23.660 N36250G1X-58.291Y21.467 N36260G1X-58.874Y19.820 N36270G1X-59.420Y18.125 N36280G1X-59.929Y16.387 N36290G1X-60.397Y14.618 N36300G1X-60.820Y12.832 N36310G1X-61.196Y11.040 N36320G1X-61.522Y9.255 N36330G1X-61.793Y7.500 N36340G1X-61.910Y6.381 N36350G1X-62.023Y4.791 N36360G1X-62.118Y2.949 N36370G1X-62.181Y1.074 N36380G1X-62.284Y-3.306 N36390G1X-61.923Y-7.075 N36400G1X-61.744Y-8.555 N36410G1X-61.538Y-10.005 N36420G1X-61.304Y-11.429 N36430G1X-61.042Y-12.829 N36440G1X-60.751Y-14.207 N36450G1X-60.430Y-15.569 N36460G1X-60.079Y-16.915 N36470G1X-59.695Y-18.250 N36480G1X-59.280Y-19.577 N36490G1X-58.831Y-20.898 N36500G1X-58.348Y-22.216 N36510G1X-57.830Y-23.535 N36520G1X-57.277Y-24.858 N36530G1X-56.687Y-26.187 N36540G1X-56.056Y-27.530 N36550G1X-54.654Y-30.444 N36560G1X-52.803Y-33.481 N36570G1X-51.721Y-35.148 N36580G1X-50.601Y-36.761 N36590G1X-49.436Y-38.326 N36600G1X-48.219Y-39.854 N36610G1X-46.943Y-41.353 N36620G1X-45.601Y-42.831 N36630G1X-44.905Y-43.563 N36640G1X-43.443Y-45.034 N36650G1X-41.012Y-47.413 N36660G00Z6.000 N36670G00X-41.573Y-42.508 N36680G1Z-1.667F1200.0 N36690G1X-42.833Y-41.222F1800.0 N36700G1X-44.130Y-39.834 N36710G1X-45.383Y-38.436 N36720G1X-46.518Y-37.115 N36730G1X-47.454Y-35.958 N36740G1X-47.851Y-35.430 N36750G1X-48.192Y-34.935 N36760G1X-48.488Y-34.426 N36770G1X-48.594Y-34.170 N36780G2X-48.746Y-33.670I2.399J1.002 N36790G1X-48.761Y-33.598 N36800G2X-48.810Y-33.096I2.551J0.502 N36810G1Y-32.918 N36820G2X-48.540Y-31.766I2.600J0.000 N36830G1X-48.534Y-31.752 N36840G1X-48.920Y-31.763 N36850G2X-51.193Y-30.426I0.000J2.600 N36860G1X-52.049Y-28.885 N36870G1X-52.864Y-27.376 N36880G1X-53.631Y-25.889 N36890G1X-55.269Y-22.198 N36900G1X-56.082Y-20.114 N36910G1X-56.763Y-18.173 N36920G1X-57.038Y-17.308 N36930G1X-57.259Y-16.533 N36940G1X-57.417Y-15.861 N36950G1X-57.483Y-15.464 N36960G1X-57.510Y-15.105 N36970G1Y-14.555 N36980G2X-57.235Y-13.393I2.600J0.000 N36990G1X-56.030Y-10.979 N37000G2X-57.331Y-10.778I-0.265J2.586 N37010G1X-57.359Y-10.765 N37020G2X-58.626Y-9.588I1.036J2.385 N37030G1X-58.664Y-9.514 N37040G2X-58.843Y-9.082I2.303J1.207 N37050G1X-58.956Y-8.721 N37060G1X-59.119Y-8.056 N37070G1X-59.619Y-3.673 N37080G1X-59.609Y1.730 N37090G1X-59.576Y3.089 N37100G1X-59.518Y4.379 N37110G1X-59.431Y5.626 N37120G1X-59.313Y6.856 N37130G1X-59.162Y8.095 N37140G1X-58.977Y9.371 N37150G1X-58.592Y11.598 N37160G1X-58.407Y12.509 N37170G1X-57.992Y14.324 N37180G1X-57.508Y16.170 N37190G1X-56.967Y18.012 N37200G1X-56.374Y19.829 N37210G1X-55.737Y21.600 N37220G1X-55.066Y23.291 N37230G1X-54.358Y24.902 N37240G1X-53.513Y26.724 N37250G2X-51.305Y28.225I2.358J-1.095 N37260G2X-51.586Y29.400I2.319J1.175 N37270G1Y29.665 N37280G2X-51.148Y31.109I2.600J0.000 N37290G1X-49.060Y34.220 N37300G1X-47.889Y35.847 N37310G1X-46.651Y37.453 N37320G1X-45.363Y39.021 N37330G1X-44.037Y40.537 N37340G1X-42.686Y41.983 N37350G1X-41.325Y43.344 N37360G1X-39.965Y44.605 N37370G1X-39.288Y45.194 N37380G1X-38.387Y45.939 N37390G1X-37.976Y46.250 N37400G1X-37.529Y46.541 N37410G1X-37.194Y46.702 N37420G2X-36.638Y46.896I1.127J-2.343 N37430G1X-36.489Y46.929 N37440G2X-35.662Y46.980I0.570J-2.537 N37450G1X-35.533Y46.967 N37460G2X-34.799Y46.784I-0.257J-2.587 N37470G1X-34.465Y46.646 N37480G1X-25.327Y40.844 N37490G1X-16.407Y35.137 N37500G1X-10.107Y56.355 N37510G2X-7.615Y58.213I2.492J-0.742 N37520G1X10.160Y58.217 N37530G2X12.487Y56.778I0.000J-2.600 N37540G1X15.720Y50.299 N37550G2X13.333Y46.539I-2.326J-1.161 N37560G1X13.025Y46.546 N37570G1X10.327Y46.954 N37580G1X9.562Y47.031 N37590G1X9.022Y47.068 N37600G1X11.502Y41.729 N37610G1X15.274Y34.015 N37620G1X34.815Y46.500 N37630G2X37.444Y46.602I1.401J-2.190 N37640G1X38.039Y46.283 N37650G2X38.608Y45.870I-1.228J-2.292 N37660G1X41.854Y42.750 N37670G1X42.758Y41.836 N37680G1X43.645Y40.906 N37690G1X44.508Y39.967 N37700G1X45.341Y39.029 N37710G1X46.136Y38.097 N37720G1X46.887Y37.179 N37730G1X48.541Y35.025 N37740G1X51.290Y30.882 N37750G2X51.412Y28.211I-2.166J-1.438 N37760G2X52.894Y27.458I-0.375J-2.573 N37770G1X53.175Y27.171 N37780G2X53.702Y26.388I-1.857J-1.819 N37790G1X54.715Y24.056 N37800G1X55.413Y22.385 N37810G1X56.060Y20.690 N37820G1X56.652Y18.984 N37830G1X57.190Y17.263 N37840G1X57.674Y15.522 N37850G1X58.107Y13.758 N37860G1X58.489Y11.966 N37870G1X58.819Y10.159 N37880G1X59.295Y7.328 N37890G1X59.527Y3.804 N37900G1X59.628Y1.958 N37910G1X59.662Y0.262 N37920G1X59.627Y-1.439 N37930G1X59.526Y-3.300 N37940G1X59.301Y-6.728 N37950G2X59.145Y-7.459I-2.594J0.170 N37960G1X58.857Y-8.238 N37970G2X56.129Y-9.920I-2.438J0.902 N37980G1X57.129Y-11.938 N37990G1X57.350Y-12.441 N38000G1X57.557Y-13.008 N38010G1X57.656Y-13.484 N38020G2X57.710Y-13.985I-2.546J-0.527 N38030G1X57.715Y-14.506 N38040G1X57.607Y-15.210 N38050G1X57.440Y-15.876 N38060G1X56.966Y-17.410 N38070G1X56.431Y-19.010 N38080G1X55.834Y-20.651 N38090G1X55.194Y-22.291 N38100G1X54.524Y-23.896 N38110G1X53.840Y-25.432 N38120G1X53.155Y-26.867 N38130G1X52.486Y-28.159 N38140G1X51.820Y-29.317 N38150G1X51.473Y-29.867 N38160G1X51.314Y-30.074 N38170G2X50.891Y-30.511I-2.065J1.580 N38180G1X50.824Y-30.565 N38190G2X49.104Y-31.148I-1.642J2.016 N38200G1X48.733Y-31.118 N38210G1X48.844Y-31.424 N38220G1X48.935Y-31.780 N38230G2X49.011Y-32.265I-2.519J-0.645 N38240G1X49.024Y-32.464 N38250G2X48.978Y-33.136I-2.595J-0.161 N38260G1X48.940Y-33.322 N38270G2X48.761Y-33.879I-2.549J0.512 N38280G1X48.591Y-34.257 N38290G1X48.084Y-35.037 N38300G1X45.981Y-37.722 N38310G1X44.527Y-39.405 N38320G1X43.005Y-41.053 N38330G1X41.488Y-42.589 N38340G1X40.758Y-43.288 N38350G1X38.808Y-45.034 N38360G2X36.160Y-45.519I-1.725J1.945 N38370G1X36.170Y-45.826 N38380G2X35.016Y-48.077I-2.598J-0.089 N38390G1X33.011Y-49.417 N38400G1X32.006Y-50.067 N38410G1X30.902Y-50.744 N38420G1X29.739Y-51.424 N38430G1X28.542Y-52.095 N38440G1X27.336Y-52.744 N38450G1X26.146Y-53.355 N38460G1X24.995Y-53.915 N38470G1X23.927Y-54.403 N38480G1X21.882Y-55.298 N38490G1X17.524Y-56.743 N38500G1X16.286Y-57.116 N38510G1X15.053Y-57.457 N38520G1X13.814Y-57.769 N38530G1X12.554Y-58.054 N38540G1X11.262Y-58.318 N38550G1X9.924Y-58.562 N38560G1X5.929Y-59.193 N38570G1X-4.259Y-59.313 N38580G1X-5.529Y-59.139 N38590G1X-9.124Y-58.737 N38600G1X-12.840Y-57.988 N38610G1X-14.703Y-57.546 N38620G1X-15.655Y-57.294 N38630G1X-17.538Y-56.747 N38640G1X-19.428Y-56.134 N38650G1X-21.293Y-55.466 N38660G1X-23.105Y-54.752 N38670G1X-24.874Y-53.988 N38680G1X-26.537Y-53.196 N38690G1X-28.305Y-52.311 N38700G1X-30.681Y-50.881 N38710G1X-32.590Y-49.699 N38720G1X-34.002Y-48.768 N38730G1X-34.941Y-48.094 N38740G2X-36.024Y-45.961I1.517J2.112 N38750G2X-36.558Y-46.016I-0.534J2.545 N38760G1X-36.768 N38770G2X-38.517Y-45.340I0.000J2.600 N38780G1X-40.964Y-43.101 N38790G1X-41.573Y-42.508 N38800G00Z6.000 N38810G00X-49.408Y-34.280 N38820G1Z-1.667F1200.0 N38830G1X-49.546Y-33.753F1800.0 N38840G2X-49.610Y-33.096I3.336J0.657 N38850G1X-49.583Y-32.497 N38860G2X-50.977Y-31.869I0.664J3.335 N38870G1X-50.253Y-33.016 N38880G1X-49.408Y-34.280 N38890G00Z6.000 N38900G00X-47.635Y-29.201 N38910G1Z-1.667F1200.0 N38920G1X-47.647Y-29.261F1800.0 N38930G2X-47.793Y-29.617I-0.981J0.194 N38940G1X-47.825Y-29.667 N38950G2X-48.091Y-29.939I-0.835J0.550 N38960G1X-48.139Y-29.972 N38970G2X-48.505Y-30.129I-0.570J0.822 N38980G1X-48.665Y-30.163 N38990G1X-48.920 N39000G2X-49.794Y-29.648I0.000J1.000 N39010G1X-50.646Y-28.116 N39020G1X-51.449Y-26.629 N39030G1X-52.188Y-25.197 N39040G1X-53.794Y-21.576 N39050G1X-54.581Y-19.558 N39060G1X-55.243Y-17.673 N39070G1X-55.506Y-16.846 N39080G1X-55.710Y-16.130 N39090G1X-55.847Y-15.547 N39100G1X-55.892Y-15.274 N39110G1X-55.910Y-15.045 N39120G1Y-14.555 N39130G2X-55.804Y-14.108I1.000J0.000 N39140G1X-39.503Y18.517 N39150G2X-38.096Y18.928I0.895J-0.447 N39160G1X-36.897Y18.211 N39170G1X-28.286Y12.880 N39180G1X-27.897Y12.507 N39190G2X-27.690Y11.349I-0.693J-0.721 N39200G1X-29.909Y6.771 N39210G1X-39.435Y-12.483 N39220G1X-47.619Y-29.091 N39230G1X-47.635Y-29.201 N39240G1X-46.850Y-29.356 N39250G1X-46.862Y-29.417 N39260G2X-47.124Y-30.057I-1.766J0.350 N39270G1X-47.157Y-30.107 N39280G2X-47.635Y-30.596I-1.504J0.990 N39290G1X-47.683Y-30.629 N39300G2X-48.341Y-30.912I-1.026J1.479 N39310G1X-48.582Y-30.963 N39320G1X-48.920 N39330G2X-50.493Y-30.037I0.000J1.800 N39340G1X-51.347Y-28.500 N39350G1X-52.156Y-27.003 N39360G1X-52.910Y-25.543 N39370G1X-54.531Y-21.887 N39380G1X-55.332Y-19.836 N39390G1X-56.003Y-17.923 N39400G1X-56.272Y-17.077 N39410G1X-56.485Y-16.331 N39420G1X-56.632Y-15.704 N39430G1X-56.687Y-15.369 N39440G1X-56.710Y-15.075 N39450G1Y-14.555 N39460G2X-56.520Y-13.750I1.800J0.000 N39470G1X-40.219Y18.874 N39480G2X-37.685Y19.614I1.610J-0.805 N39490G1X-36.481Y18.895 N39500G1X-27.955Y13.616 N39510G1X-27.655Y13.384 N39520G1X-27.343Y13.084 N39530G2X-26.970Y11.001I-1.247J-1.298 N39540G1X-29.191Y6.419 N39550G1X-38.717Y-12.837 N39560G1X-46.850Y-29.356 N39570G00Z6.000 N39580G00X-58.290Y-14.189 N39590G1Z-1.667F1200.0 N39600G2X-57.951Y-13.035I3.380J-0.366F1800.0 N39610G1X-57.260Y-11.653 N39620G1X-57.677Y-11.499 N39630G2X-59.036Y-10.429I1.355J3.118 N39640G1X-58.688Y-12.360 N39650G1X-58.290Y-14.189 N39660G00Z6.000 N39670G00X10.084Y1.490 N39680G1Z-2.500F1200.0 N39690G2X10.610Y1.640I0.526J-0.850F1800.0 N39700G1X10.919 N39710G2X11.815Y1.085I0.000J-1.000 N39720G1X33.655Y-42.857 N39730G1X34.084Y-43.963 N39740G1X34.389Y-44.828 N39750G1X34.500Y-45.215 N39760G1X34.559Y-45.527 N39770G1X34.571Y-45.881 N39780G2X34.127Y-46.746I-0.999J-0.034 N39790G1X32.131Y-48.080 N39800G1X31.153Y-48.713 N39810G1X30.080Y-49.371 N39820G1X28.944Y-50.036 N39830G1X27.772Y-50.693 N39840G1X26.592Y-51.327 N39850G1X25.430Y-51.924 N39860G1X24.312Y-52.468 N39870G1X23.274Y-52.942 N39880G1X21.306Y-53.804 N39890G1X17.047Y-55.216 N39900G1X15.842Y-55.579 N39910G1X14.645Y-55.910 N39920G1X13.442Y-56.212 N39930G1X12.218Y-56.490 N39940G1X10.959Y-56.747 N39950G1X9.651Y-56.985 N39960G1X5.796Y-57.595 N39970G1X-4.160Y-57.711 N39980G1X-5.332Y-57.551 N39990G1X-8.879Y-57.154 N40000G1X-12.499Y-56.425 N40010G1X-14.306Y-55.996 N40020G1X-15.227Y-55.752 N40030G1X-17.068Y-55.217 N40040G1X-18.911Y-54.619 N40050G1X-20.731Y-53.968 N40060G1X-22.501Y-53.271 N40070G1X-24.213Y-52.531 N40080G1X-25.828Y-51.762 N40090G1X-27.533Y-50.908 N40100G1X-29.848Y-49.515 N40110G1X-31.736Y-48.347 N40120G1X-33.086Y-47.457 N40130G1X-34.007Y-46.795 N40140G2X-34.320Y-45.538I0.583J0.812 N40150G1X-29.513Y-35.844 N40160G1X-11.200Y0.901 N40170G2X-10.305Y1.455I0.895J-0.446 N40180G1X-10.085 N40190G2X-9.559Y1.305I0.000J-1.000 N40200G1X0.099Y-4.680 N40210G1X10.084Y1.490 N40220G1X9.663Y2.170 N40230G2X10.610Y2.440I0.947J-1.531 N40240G1X10.919 N40250G2X12.531Y1.441I0.000J-1.800 N40260G1X34.387Y-42.533 N40270G1X34.834Y-43.685 N40280G1X35.151Y-44.584 N40290G1X35.280Y-45.030 N40300G1X35.356Y-45.439 N40310G1X35.371Y-45.853 N40320G2X34.572Y-47.412I-1.799J-0.061 N40330G1X32.571Y-48.748 N40340G1X31.580Y-49.390 N40350G1X30.491Y-50.058 N40360G1X29.341Y-50.730 N40370G1X28.157Y-51.394 N40380G1X26.964Y-52.035 N40390G1X25.788Y-52.639 N40400G1X24.654Y-53.192 N40410G1X23.600Y-53.673 N40420G1X21.594Y-54.551 N40430G1X17.286Y-55.980 N40440G1X16.064Y-56.347 N40450G1X14.849Y-56.683 N40460G1X13.628Y-56.990 N40470G1X12.386Y-57.272 N40480G1X11.111Y-57.532 N40490G1X9.787Y-57.773 N40500G1X5.862Y-58.394 N40510G1X-4.210Y-58.512 N40520G1X-5.430Y-58.345 N40530G1X-9.001Y-57.945 N40540G1X-12.670Y-57.207 N40550G1X-14.505Y-56.771 N40560G1X-15.441Y-56.523 N40570G1X-17.303Y-55.982 N40580G1X-19.169Y-55.377 N40590G1X-21.012Y-54.717 N40600G1X-22.803Y-54.012 N40610G1X-24.543Y-53.260 N40620G1X-26.183Y-52.479 N40630G1X-27.919Y-51.610 N40640G1X-30.264Y-50.198 N40650G1X-32.163Y-49.023 N40660G1X-33.544Y-48.112 N40670G1X-34.474Y-47.444 N40680G2X-35.036Y-45.183I1.050J1.462 N40690G1X-30.230Y-35.488 N40700G1X-11.916Y1.257 N40710G2X-10.305Y2.255I1.611J-0.803 N40720G1X-10.085 N40730G2X-9.137Y1.985I0.000J-1.800 N40740G1X0.103Y-3.741 N40750G1X9.663Y2.170 N40760G00Z6.000 N40770G00X11.673Y3.128 N40780G1Z-2.500F1200.0 N40790G1X11.736Y3.108F1800.0 N40800G1X11.740Y3.170 N40810G1X11.673Y3.128 N40820G00Z6.000 N40830G00X13.806Y3.805 N40840G1Z-2.500F1200.0 N40850G1X25.007Y10.712F1800.0 N40860G1X25.467Y10.870 N40870G2X26.688Y10.364I0.323J-0.946 N40880G1X37.387Y-11.413 N40890G1X46.546Y-29.956 N40900G1X47.184Y-31.538 N40910G1X47.313Y-31.895 N40920G1X47.408Y-32.269 N40930G1X47.435Y-32.693 N40940G1X47.349Y-33.118 N40950G1X47.183Y-33.487 N40960G1X46.781Y-34.106 N40970G1X44.741Y-36.711 N40980G1X43.334Y-38.339 N40990G1X41.847Y-39.948 N41000G1X40.371Y-41.444 N41010G1X39.666Y-42.119 N41020G1X37.747Y-43.837 N41030G2X36.188Y-43.534I-0.663J0.748 N41040G1X13.425Y2.220 N41050G2X13.321Y2.702I0.895J0.445 N41060G1X13.332Y2.989 N41070G2X13.806Y3.805I0.999J-0.036 N41080G1X13.386Y4.486 N41090G1X24.491Y11.335 N41100G2X24.854Y11.506I0.945J-1.532 N41110G1X25.208Y11.627 N41120G2X27.406Y10.716I0.582J-1.703 N41130G1X38.105Y-11.059 N41140G1X47.276Y-29.629 N41150G1X47.931Y-31.253 N41160G1X48.078Y-31.659 N41170G1X48.202Y-32.144 N41180G1X48.225Y-32.513 N41190G2X48.193Y-32.979I-1.797J-0.111 N41200G1X48.156Y-33.165 N41210G2X48.032Y-33.550I-1.765J0.354 N41220G1X47.887Y-33.872 N41230G1X47.432Y-34.571 N41240G1X45.361Y-37.217 N41250G1X43.931Y-38.872 N41260G1X42.426Y-40.500 N41270G1X40.929Y-42.017 N41280G1X40.212Y-42.703 N41290G1X38.277Y-44.436 N41300G2X35.472Y-43.891I-1.194J1.347 N41310G1X12.709Y1.864 N41320G2X12.522Y2.730I1.612J0.802 N41330G1X12.532Y3.018 N41340G2X13.386Y4.486I1.799J-0.065 N41350G00Z6.000 N41360G00X-11.216Y2.890 N41370G1Z-2.500F1200.0 N41380G1X-11.152Y2.913F1800.0 N41390G1X-11.230Y2.961 N41400G1X-11.216Y2.890 N41410G00Z6.000 N41420G00X-25.977Y10.311 N41430G1Z-2.500F1200.0 N41440G1X-25.843Y10.450F1800.0 N41450G2X-24.597Y10.606I0.720J-0.694 N41460G1X-15.185Y4.776 N41470G1X-14.121Y4.099 N41480G1X-13.732Y3.831 N41490G1X-13.416Y3.589 N41500G1X-13.140Y3.330 N41510G1X-12.990Y3.121 N41520G2X-12.832Y2.780I-0.813J-0.583 N41530G1X-12.805Y2.671 N41540G2X-12.812Y2.160I-0.970J-0.243 N41550G1X-12.869Y1.956 N41560G1X-13.079Y1.563 N41570G1X-35.662Y-43.861 N41580G2X-36.558Y-44.416I-0.895J0.445 N41590G1X-36.768 N41600G2X-37.441Y-44.156I0.000J1.000 N41610G1X-39.860Y-41.943 N41620G1X-40.443Y-41.375 N41630G1X-41.676Y-40.116 N41640G1X-42.950Y-38.753 N41650G1X-44.181Y-37.381 N41660G1X-45.289Y-36.090 N41670G1X-46.192Y-34.974 N41680G1X-46.552Y-34.495 N41690G1X-46.839Y-34.078 N41700G1X-47.051Y-33.713 N41710G1X-47.157Y-33.460 N41720G1X-47.210Y-33.194 N41730G1Y-32.918 N41740G2X-47.106Y-32.475I1.000J0.000 N41750G1X-34.013Y-5.953 N41760G1X-26.154Y10.057 N41770G2X-25.977Y10.311I0.898J-0.440 N41780G1X-26.553Y10.866 N41790G1X-26.419Y11.005 N41800G2X-24.176Y11.286I1.296J-1.249 N41810G1X-14.759Y5.453 N41820G1X-13.680Y4.767 N41830G1X-13.261Y4.478 N41840G1X-12.898Y4.199 N41850G1X-12.535Y3.860 N41860G1X-12.340Y3.587 N41870G2X-12.056Y2.975I-1.463J-1.049 N41880G1X-12.029Y2.865 N41890G2X-12.041Y1.945I-1.746J-0.437 N41900G1X-12.069Y1.847 N41910G2X-12.215Y1.481I-1.734J0.484 N41920G1X-34.946Y-44.217 N41930G2X-36.558Y-45.216I-1.612J0.801 N41940G1X-36.768 N41950G2X-37.979Y-44.748I0.000J1.800 N41960G1X-40.412Y-42.522 N41970G1X-41.008Y-41.942 N41980G1X-42.255Y-40.669 N41990G1X-43.540Y-39.294 N42000G1X-44.782Y-37.909 N42010G1X-45.903Y-36.602 N42020G1X-46.823Y-35.466 N42030G1X-47.201Y-34.962 N42040G1X-47.516Y-34.507 N42050G1X-47.770Y-34.069 N42060G1X-47.926Y-33.694 N42070G1X-48.010Y-33.272 N42080G1Y-32.918 N42090G2X-47.823Y-32.120I1.800J0.000 N42100G1X-34.731Y-5.599 N42110G1X-26.873Y10.410 N42120G2X-26.553Y10.866I1.616J-0.792 N42130G00Z6.000 N42140G00X-39.574Y20.484 N42150G1Z-2.500F1200.0 N42160G1X-39.533Y20.500F1800.0 N42170G1X-39.584Y20.532 N42180G1X-39.574Y20.484 N42190G00Z6.000 N42200G00X-41.184Y20.301 N42210G1Z-2.500F1200.0 N42220G2X-41.221Y19.490I-0.931J-0.364F1800.0 N42230G1X-48.285Y5.352 N42240G1X-55.401Y-8.841 N42250G2X-56.693Y-9.310I-0.894J0.448 N42260G1X-56.721Y-9.298 N42270G2X-57.209Y-8.845I0.398J0.917 N42280G1X-57.289Y-8.691 N42290G1X-57.414Y-8.291 N42300G1X-57.541Y-7.774 N42310G1X-58.019Y-3.582 N42320G1X-58.009Y1.705 N42330G1X-57.977Y3.034 N42340G1X-57.920Y4.287 N42350G1X-57.836Y5.494 N42360G1X-57.722Y6.683 N42370G1X-57.576Y7.884 N42380G1X-57.396Y9.125 N42390G1X-57.021Y11.295 N42400G1X-56.843Y12.171 N42410G1X-56.438Y13.943 N42420G1X-55.966Y15.741 N42430G1X-55.438Y17.538 N42440G1X-54.861Y19.310 N42450G1X-54.241Y21.034 N42460G1X-53.587Y22.681 N42470G1X-52.903Y24.236 N42480G1X-52.061Y26.050 N42490G2X-51.154Y26.629I0.907J-0.421 N42500G1X-50.800 N42510G2X-50.274Y26.479I0.000J-1.000 N42520G1X-41.752Y21.204 N42530G2X-41.347Y20.717I-0.526J-0.850 N42540G1X-41.184Y20.301 N42550G1X-40.439Y20.592 N42560G2X-40.505Y19.133I-1.677J-0.655 N42570G1X-47.570Y4.994 N42580G1X-54.686Y-9.200 N42590G2X-57.012Y-10.044I-1.609J0.807 N42600G1X-57.040Y-10.032 N42610G2X-57.917Y-9.216I0.717J1.651 N42620G1X-58.031Y-8.999 N42630G1X-58.185Y-8.506 N42640G1X-58.330Y-7.915 N42650G1X-58.819Y-3.628 N42660G1X-58.809Y1.718 N42670G1X-58.776Y3.062 N42680G1X-58.719Y4.333 N42690G1X-58.633Y5.560 N42700G1X-58.518Y6.769 N42710G1X-58.369Y7.990 N42720G1X-58.186Y9.248 N42730G1X-57.806Y11.446 N42740G1X-57.625Y12.340 N42750G1X-57.215Y14.134 N42760G1X-56.737Y15.955 N42770G1X-56.203Y17.775 N42780G1X-55.618Y19.570 N42790G1X-54.989Y21.317 N42800G1X-54.327Y22.986 N42810G1X-53.631Y24.569 N42820G1X-52.787Y26.387 N42830G2X-51.154Y27.429I1.633J-0.758 N42840G1X-50.800 N42850G2X-49.853Y27.160I0.000J-1.800 N42860G1X-41.331Y21.884 N42870G2X-40.601Y21.009I-0.947J-1.530 N42880G1X-40.439Y20.592 N42890G00Z6.000 N42900G00X-21.056Y47.608 N42910G1Z-2.500F1200.0 N42920G1X-21.006Y47.776F1800.0 N42930G1X-21.192Y47.695 N42940G1X-21.056Y47.608 N42950G1X-21.457Y46.915 N42960G1X-20.592Y46.362 N42970G1X-19.761Y49.155 N42980G1X-21.081Y48.617 N42990G1X-22.152Y48.147 N43000G1X-22.870Y47.813 N43010G1X-21.457Y46.915 N43020G1X-21.887Y46.241 N43030G1X-20.127Y45.115 N43040G1X-18.535Y50.471 N43050G1X-20.294Y49.807 N43060G1X-21.394Y49.353 N43070G1X-22.482Y48.876 N43080G1X-23.557Y48.375 N43090G1X-24.509Y47.906 N43100G1X-21.887Y46.241 N43110G1X-22.317Y45.566 N43120G1X-19.662Y43.867 N43130G1X-17.324Y51.734 N43140G1X-18.322Y51.398 N43150G1X-19.463Y50.986 N43160G1X-20.591Y50.550 N43170G1X-21.707Y50.089 N43180G1X-22.811Y49.605 N43190G1X-23.903Y49.097 N43200G1X-24.981Y48.565 N43210G1X-26.111Y47.975 N43220G1X-22.317Y45.566 N43230G1X-22.747Y44.891 N43240G1X-19.197Y42.620 N43250G1X-16.129Y52.947 N43260G1X-17.415Y52.548 N43270G1X-18.585Y52.154 N43280G1X-19.743Y51.735 N43290G1X-20.888Y51.292 N43300G1X-22.021Y50.825 N43310G1X-23.141Y50.334 N43320G1X-24.248Y49.818 N43330G1X-25.343Y49.279 N43340G1X-26.425Y48.715 N43350G1X-27.676Y48.021 N43360G1X-22.747Y44.891 N43370G1X-23.177Y44.217 N43380G1X-18.732Y41.373 N43390G1X-14.947Y54.114 N43400G1X-16.463Y53.683 N43410G1X-17.662Y53.309 N43420G1X-18.849Y52.909 N43430G1X-20.023Y52.485 N43440G1X-21.185Y52.035 N43450G1X-22.334Y51.561 N43460G1X-23.470Y51.063 N43470G1X-24.594Y50.540 N43480G1X-25.705Y49.992 N43490G1X-26.802Y49.420 N43500G1X-27.887Y48.824 N43510G1X-29.212Y48.049 N43520G1X-23.177Y44.217 N43530G1X-23.607Y43.542 N43540G1X-18.267Y40.126 N43550G1X-13.777Y55.241 N43560G1X-15.466Y54.804 N43570G1X-16.693Y54.450 N43580G1X-17.909Y54.070 N43590G1X-19.113Y53.665 N43600G1X-20.303Y53.234 N43610G1X-21.482Y52.778 N43620G1X-22.647Y52.298 N43630G1X-23.800Y51.792 N43640G1X-24.940Y51.261 N43650G1X-26.066Y50.706 N43660G1X-27.180Y50.126 N43670G1X-28.280Y49.521 N43680G1X-29.367Y48.891 N43690G1X-30.719Y48.058 N43700G1X-23.607Y43.542 N43710G1X-24.037Y42.868 N43720G1X-17.802Y38.878 N43730G1X-12.617Y56.333 N43740G1X-14.422Y55.908 N43750G1X-15.679Y55.575 N43760G1X-16.924Y55.216 N43770G1X-18.156Y54.831 N43780G1X-19.376Y54.420 N43790G1X-20.584Y53.983 N43800G1X-21.778Y53.521 N43810G1X-22.960Y53.034 N43820G1X-24.129Y52.521 N43830G1X-25.285Y51.983 N43840G1X-26.428Y51.419 N43850G1X-27.558Y50.831 N43860G1X-28.673Y50.217 N43870G1X-29.776Y49.579 N43880G1X-30.864Y48.916 N43890G1X-32.200Y48.051 N43900G1X-24.037Y42.868 N43910G1X-24.467Y42.193 N43920G1X-17.337Y37.631 N43930G1X-11.640Y56.811 N43940G2X-11.415Y57.402I4.026J-1.198 N43950G1X-13.333Y56.995 N43960G1X-14.619Y56.684 N43970G1X-15.892Y56.346 N43980G1X-17.154Y55.982 N43990G1X-18.403Y55.592 N44000G1X-19.640Y55.175 N44010G1X-20.864Y54.733 N44020G1X-22.075Y54.264 N44030G1X-23.274Y53.770 N44040G1X-24.459Y53.250 N44050G1X-25.631Y52.704 N44060G1X-26.790Y52.133 N44070G1X-27.935Y51.536 N44080G1X-29.067Y50.914 N44090G1X-30.184Y50.267 N44100G1X-31.288Y49.594 N44110G1X-32.378Y48.896 N44120G1X-33.666Y48.022 N44130G1X-24.467Y42.193 N44140G1X-24.897Y41.518 N44150G1X-16.872Y36.384 N44160G1X-10.873Y56.583 N44170G2X-9.232Y58.604I3.259J-0.970 N44180G1X-10.873Y58.324 N44190G1X-12.199Y58.063 N44200G1X-13.513Y57.774 N44210G1X-14.815Y57.459 N44220G1X-16.106Y57.117 N44230G1X-17.384Y56.748 N44240G1X-18.650Y56.353 N44250G1X-19.904Y55.931 N44260G1X-21.144Y55.482 N44270G1X-22.372Y55.007 N44280G1X-23.587Y54.506 N44290G1X-24.789Y53.979 N44300G1X-25.977Y53.426 N44310G1X-27.152Y52.847 N44320G1X-28.313Y52.242 N44330G1X-29.460Y51.611 N44340G1X-30.593Y50.954 N44350G1X-31.712Y50.272 N44360G1X-32.817Y49.565 N44370G1X-33.907Y48.832 N44380G1X-35.408Y47.758 N44390G2X-34.495Y47.524I-0.382J-3.379 N44400G1X-34.371Y47.473 N44410G2X-33.843Y47.199I-1.295J-3.144 N44420G1X-24.897Y41.518 N44430G00Z6.000 N44440G00X-6.187Y59.013 N44450G1Z-2.500F1200.0 N44460G1X5.912Y59.016F1800.0 N44470G1X3.675Y59.135 N44480G1X1.254Y59.200 N44490G1X-3.466Y59.293 N44500G1X-6.187Y59.013 N44510G00Z6.000 N44520G00X23.080Y47.647 N44530G1Z-2.500F1200.0 N44540G1X23.061Y47.528F1800.0 N44550G1X23.176Y47.602 N44560G1X23.080Y47.647 N44570G1X23.236Y48.456 N44580G1X22.389Y48.840 N44590G2X21.720Y45.721I-8.995J0.298 N44600G1X24.798Y47.690 N44610G1X24.354Y47.938 N44620G1X23.236Y48.456 N44630G1X23.569Y49.183 N44640G1X21.539Y50.081 N44650G2X18.431Y42.668I-8.146J-0.943 N44660G1X26.354Y47.735 N44670G1X24.718Y48.651 N44680G1X23.569Y49.183 N44690G1X23.902Y49.911 N44700G1X21.900Y50.798 N44710G1X20.443Y51.389 N44720G2X16.502Y42.422I-7.049J-2.251 N44730G1X17.221Y40.944 N44740G1X27.899Y47.774 N44750G1X25.082Y49.364 N44760G1X23.902Y49.911 N44770G1X24.235Y50.638 N44780G1X22.212Y51.535 N44790G1X20.218Y52.337 N44800G1X18.939Y52.807 N44810G1X19.299Y52.085 N44820G2X15.404Y42.851I-5.906J-2.947 N44830G1X16.895Y39.786 N44840G1X29.423Y47.799 N44850G1X28.785Y48.187 N44860G1X27.483Y48.937 N44870G1X25.446Y50.077 N44880G1X24.235Y50.638 N44890G1X24.569Y51.365 N44900G1X22.523Y52.272 N44910G1X20.503Y53.084 N44920G1X18.480Y53.816 N44930G1X17.356Y54.187 N44940G1X18.583Y51.728 N44950G2X14.253Y43.402I-5.190J-2.590 N44960G1X16.570Y38.631 N44970G1X30.920Y47.807 N44980G1X30.436Y48.119 N44990G1X29.193Y48.876 N45000G1X27.878Y49.633 N45010G1X25.810Y50.790 N45020G1X24.569Y51.365 N45030G1X24.902Y52.092 N45040G1X22.835Y53.008 N45050G1X20.789Y53.832 N45060G1X18.738Y54.574 N45070G1X16.673Y55.237 N45080G1X15.813Y55.489 N45090G1X17.868Y51.370 N45100G2X13.277Y44.139I-4.474J-2.233 N45110G1X13.025Y44.146 N45120G1X13.670Y42.760 N45130G1X16.246Y37.477 N45140G1X32.392Y47.799 N45150G1X30.860Y48.797 N45160G1X29.601Y49.564 N45170G1X28.272Y50.329 N45180G1X26.174Y51.503 N45190G1X24.902Y52.092 N45200G1X25.235Y52.820 N45210G1X23.146Y53.745 N45220G1X21.075Y54.579 N45230G1X18.997Y55.331 N45240G1X16.905Y56.003 N45250G1X14.790Y56.600 N45260G1X14.303Y56.723 N45270G1X17.152Y51.013 N45280G2X13.296Y44.939I-3.758J-1.875 N45290G1X12.883Y44.949 N45300G1X11.684Y45.134 N45310G1X12.947Y42.416 N45320G1X15.921Y36.323 N45330G1X33.840Y47.776 N45340G1X32.525Y48.676 N45350G1X31.285Y49.475 N45360G1X30.008Y50.253 N45370G1X28.667Y51.024 N45380G1X26.538Y52.216 N45390G1X25.235Y52.820 N45400G1X25.568Y53.547 N45410G1X23.458Y54.482 N45420G1X21.360Y55.326 N45430G1X20.309Y55.717 N45440G1X19.255Y56.088 N45450G1X18.198Y56.438 N45460G1X17.136Y56.769 N45470G1X16.068Y57.081 N45480G1X14.993Y57.373 N45490G1X13.910Y57.647 N45500G1X12.642Y57.941 N45510G2X13.203Y57.135I-2.482J-2.324 N45520G1X16.436Y50.656 N45530G2X13.314Y45.739I-3.042J-1.518 N45540G1X12.954Y45.747 N45550G1X10.333Y46.145 N45560G1X12.224Y42.073 N45570G1X15.597Y35.168 N45580G1X34.384Y47.174 N45590G2X35.427Y47.617I1.832J-2.864 N45600G1X34.196Y48.506 N45610G1X32.968Y49.343 N45620G1X31.710Y50.154 N45630G1X30.416Y50.941 N45640G1X29.062Y51.720 N45650G1X26.902Y52.929 N45660G1X25.568Y53.547 N45670G00Z6.000 N45680G00X36.688Y45.191 N45690G1Z-2.500F1200.0 N45700G1X37.404Y44.808F1800.0 N45710G1X40.727Y41.614 N45720G1X41.610Y40.721 N45730G1X42.477Y39.812 N45740G1X43.321Y38.895 N45750G1X44.134Y37.979 N45760G1X44.908Y37.071 N45770G1X45.636Y36.181 N45780G1X47.236Y34.098 N45790G1X49.956Y29.998 N45800G2X49.821Y28.729I-0.833J-0.553 N45810G1X49.463Y28.379 N45820G1X0.822Y-1.692 N45830G2X0.239Y-1.840I-0.525J0.851 N45840G1X-0.268Y-1.810 N45850G2X-0.737Y-1.662I0.058J0.998 N45860G1X-34.279Y19.133 N45870G1X-49.512Y28.549 N45880G2X-49.986Y29.400I0.526J0.851 N45890G1Y29.665 N45900G2X-49.818Y30.220I1.000J0.000 N45910G1X-47.746Y33.307 N45920G1X-46.606Y34.891 N45930G1X-45.400Y36.457 N45940G1X-44.142Y37.987 N45950G1X-42.849Y39.464 N45960G1X-41.535Y40.872 N45970G1X-40.215Y42.192 N45980G1X-38.902Y43.409 N45990G1X-38.253Y43.973 N46000G1X-37.395Y44.684 N46010G1X-37.056Y44.940 N46020G1X-36.742Y45.144 N46030G1X-36.398Y45.310 N46040G1X-36.138Y45.368 N46050G2X-35.820Y45.388I0.219J-0.976 N46060G1X-35.691Y45.375 N46070G2X-35.409Y45.305I-0.099J-0.995 N46080G1X-35.204Y45.220 N46090G1X-26.187Y39.495 N46100G1X-16.074Y33.024 N46110G1X-15.473Y32.656 N46120G1X-8.573Y55.898 N46130G2X-7.615Y56.613I0.958J-0.285 N46140G1X10.160Y56.617 N46150G2X11.055Y56.063I0.000J-1.000 N46160G1X14.289Y49.584 N46170G2X13.370Y48.138I-0.895J-0.447 N46180G1X13.167Y48.143 N46190G1X10.520Y48.542 N46200G1X9.697Y48.626 N46210G1X8.862Y48.683 N46220G1X8.059Y48.711 N46230G1X7.335Y48.711 N46240G1X6.573Y48.663 N46250G1X7.249Y47.088 N46260G1X10.057Y41.042 N46270G1X13.547Y33.898 N46280G1X14.630Y31.710 N46290G1X19.984Y35.114 N46300G1X35.677Y45.152 N46310G2X36.688Y45.191I0.539J-0.842 N46320G1X37.066Y45.896 N46330G1X37.661Y45.577 N46340G2X38.055Y45.292I-0.850J-1.587 N46350G1X41.291Y42.182 N46360G1X42.184Y41.278 N46370G1X43.061Y40.359 N46380G1X43.915Y39.431 N46390G1X44.737Y38.504 N46400G1X45.522Y37.584 N46410G1X46.261Y36.680 N46420G1X47.888Y34.562 N46430G1X50.623Y30.440 N46440G2X50.380Y28.156I-1.500J-0.995 N46450G1X50.100Y27.883 N46460G2X49.790Y27.641I-1.257J1.289 N46470G1X1.242Y-2.373 N46480G2X0.193Y-2.638I-0.946J1.532 N46490G1X-0.314Y-2.609 N46500G2X-1.159Y-2.342I0.104J1.797 N46510G1X-34.700Y18.453 N46520G1X-49.933Y27.869 N46530G2X-50.786Y29.400I0.946J1.531 N46540G1Y29.665 N46550G2X-50.483Y30.664I1.800J0.000 N46560G1X-48.403Y33.763 N46570G1X-47.247Y35.369 N46580G1X-46.025Y36.955 N46590G1X-44.753Y38.504 N46600G1X-43.443Y40.000 N46610G1X-42.111Y41.427 N46620G1X-40.770Y42.768 N46630G1X-39.434Y44.007 N46640G1X-38.771Y44.584 N46650G1X-37.891Y45.312 N46660G1X-37.516Y45.595 N46670G1X-37.135Y45.843 N46680G1X-36.847Y45.981 N46690G2X-36.462Y46.115I0.780J-1.622 N46700G1X-36.313Y46.149 N46710G2X-35.741Y46.184I0.395J-1.756 N46720G1X-35.612Y46.171 N46730G2X-35.104Y46.044I-0.178J-1.791 N46740G1X-34.834Y45.933 N46750G1X-25.757Y40.169 N46760G1X-15.942Y33.889 N46770G1X-9.340Y56.127 N46780G2X-7.615Y57.413I1.725J-0.513 N46790G1X10.160Y57.417 N46800G2X11.771Y56.420I0.000J-1.800 N46810G1X15.004Y49.942 N46820G2X13.352Y47.338I-1.611J-0.804 N46830G1X13.096Y47.344 N46840G1X10.424Y47.748 N46850G1X9.630Y47.829 N46860G1X8.821Y47.883 N46870G1X7.766Y47.911 N46880G1X7.979Y47.415 N46890G1X10.779Y41.386 N46900G1X14.264Y34.252 N46910G1X14.952Y32.862 N46920G1X19.554Y35.788 N46930G1X35.246Y45.826 N46940G2X37.066Y45.896I0.970J-1.516 N46950G00Z6.000 N46960G00X52.032Y26.051 N46970G1Z-2.500F1200.0 N46980G2X52.235Y25.750I-0.714J-0.700F1800.0 N46990G1X53.243Y23.429 N47000G1X53.927Y21.791 N47010G1X54.557Y20.142 N47020G1X55.133Y18.483 N47030G1X55.655Y16.810 N47040G1X56.126Y15.117 N47050G1X56.547Y13.401 N47060G1X56.919Y11.655 N47070G1X57.243Y9.883 N47080G1X57.704Y7.142 N47090G1X57.930Y3.708 N47100G1X58.029Y1.891 N47110G1X58.062Y0.262 N47120G1X58.028Y-1.372 N47130G1X57.929Y-3.204 N47140G1X57.704Y-6.623 N47150G2X57.644Y-6.904I-0.998J0.066 N47160G1X57.356Y-7.683 N47170G2X55.524Y-7.783I-0.938J0.347 N47180G1X41.729Y19.870 N47190G2X41.919Y21.026I0.895J0.446 N47200G1X42.296Y21.401 N47210G1X50.510Y26.488 N47220G2X51.751Y26.338I0.527J-0.850 N47230G1X52.032Y26.051 N47240G1X52.604Y26.611 N47250G2X52.969Y26.069I-1.286J-1.260 N47260G1X53.979Y23.743 N47270G1X54.670Y22.088 N47280G1X55.309Y20.416 N47290G1X55.893Y18.733 N47300G1X56.423Y17.036 N47310G1X56.900Y15.320 N47320G1X57.327Y13.580 N47330G1X57.704Y11.811 N47340G1X58.031Y10.021 N47350G1X58.499Y7.235 N47360G1X58.729Y3.756 N47370G1X58.828Y1.924 N47380G1X58.862Y0.262 N47390G1X58.828Y-1.406 N47400G1X58.727Y-3.252 N47410G1X58.503Y-6.675 N47420G2X58.395Y-7.182I-1.796J0.118 N47430G1X58.107Y-7.961 N47440G2X54.808Y-8.140I-1.688J0.625 N47450G1X41.013Y19.513 N47460G2X41.355Y21.594I1.611J0.804 N47470G1X41.651Y21.888 N47480G2X41.972Y22.141I1.268J-1.277 N47490G1X50.089Y27.168 N47500G2X52.323Y26.898I0.948J-1.530 N47510G1X52.604Y26.611 N47520G00Z6.000 N47530G00X40.040Y20.669 N47540G1Z-2.500F1200.0 N47550G00Z6.000 N47560G00X58.370Y-12.988 N47570G1Z-2.500F1200.0 N47580G1X58.623Y-11.743F1800.0 N47590G1X58.871Y-10.355 N47600G1X58.994Y-9.556 N47610G2X57.360Y-10.603I-2.575J2.220 N47620G1X57.854Y-11.599 N47630G1X58.093Y-12.143 N47640G1X58.243Y-12.554 N47650G1X58.370Y-12.988 N47660G00Z6.000 N47670G00X48.162Y-28.893 N47680G1Z-2.500F1200.0 N47690G1X47.871Y-28.179F1800.0 N47700G1X35.452Y-3.088 N47710G2X35.357Y-2.772I0.896J0.444 N47720G1X28.547Y10.878 N47730G1X28.214Y11.734 N47740G2X28.620Y12.947I0.932J0.362 N47750G1X38.043Y18.773 N47760G1X38.416Y18.977 N47770G1X38.741Y19.126 N47780G1X38.877Y19.167 N47790G2X39.245Y19.207I0.291J-0.957 N47800G1X39.280Y19.204 N47810G2X40.096Y18.656I-0.078J-0.997 N47820G1X47.668Y3.551 N47830G1X55.679Y-12.615 N47840G1X55.865Y-13.038 N47850G1X56.014Y-13.447 N47860G1X56.109Y-13.904 N47870G1X56.114Y-14.393 N47880G1X56.037Y-14.894 N47890G1X55.899Y-15.444 N47900G1X55.443Y-16.920 N47910G1X54.920Y-18.483 N47920G1X54.337Y-20.087 N47930G1X53.710Y-21.692 N47940G1X53.055Y-23.262 N47950G1X52.387Y-24.762 N47960G1X51.722Y-26.154 N47970G1X51.076Y-27.401 N47980G1X50.455Y-28.482 N47990G1X50.158Y-28.952 N48000G1X49.972Y-29.196 N48010G1X49.813Y-29.325 N48020G2X49.152Y-29.549I-0.632J0.775 N48030G1X49.097Y-29.547 N48040G2X48.382Y-29.215I0.030J1.000 N48050G1X48.333Y-29.160 N48060G2X48.162Y-28.893I0.745J0.667 N48070G1X47.428Y-29.212 N48080G1X47.138Y-28.502 N48090G1X34.735Y-3.442 N48100G2X34.590Y-3.027I1.613J0.798 N48110G1X27.814Y10.554 N48120G1X27.468Y11.444 N48130G2X28.199Y13.628I1.678J0.652 N48140G1X37.646Y19.468 N48150G1X38.058Y19.692 N48160G1X38.457Y19.875 N48170G1X38.644Y19.932 N48180G2X39.307Y20.005I0.524J-1.722 N48190G1X39.342Y20.002 N48200G2X40.811Y19.014I-0.140J-1.795 N48210G1X48.384Y3.908 N48220G1X56.404Y-12.276 N48230G1X56.607Y-12.740 N48240G1X56.786Y-13.227 N48250G1X56.908Y-13.818 N48260G1X56.914Y-14.450 N48270G1X56.822Y-15.052 N48280G1X56.669Y-15.660 N48290G1X56.205Y-17.165 N48300G1X55.676Y-18.747 N48310G1X55.086Y-20.369 N48320G1X54.452Y-21.991 N48330G1X53.790Y-23.579 N48340G1X53.114Y-25.097 N48350G1X52.439Y-26.511 N48360G1X51.781Y-27.780 N48370G1X51.138Y-28.899 N48380G1X50.815Y-29.410 N48390G1X50.679Y-29.588 N48400G2X50.386Y-29.890I-1.430J1.094 N48410G1X50.319Y-29.945 N48420G2X49.128Y-30.349I-1.137J1.396 N48430G1X49.074Y-30.347 N48440G2X47.786Y-29.748I0.054J1.799 N48450G1X47.737Y-29.693 N48460G2X47.428Y-29.212I1.342J1.200 N48470G00Z6.000 N48480G00X49.710Y-33.551 N48490G1Z-2.500F1200.0 N48500G1X50.786Y-31.864F1800.0 N48510G1X51.087Y-31.366 N48520G2X49.775Y-31.897I-1.905J2.816 N48530G1X49.822Y-32.414 N48540G2X49.762Y-33.293I-3.394J-0.210 N48550G1X49.710Y-33.551 N48560G00Z6.000 N48570G00X36.326Y-47.909 N48580G1Z-2.500F1200.0 N48590G1X37.381Y-47.081F1800.0 N48600G1X38.440Y-46.206 N48610G2X36.924Y-46.485I-1.357J3.117 N48620G2X36.326Y-47.909I-3.352J0.570 N48630G00Z6.000 N48640G00X28.066Y-53.259 N48650G1Z-2.500F1200.0 N48660G1X29.233Y-52.688F1800.0 N48670G1X30.205Y-52.079 N48680G1X28.927Y-52.797 N48690G1X28.066Y-53.259 N48700G00Z6.000 N48710G00X6.227Y-59.956 N48720G1Z-2.500F1200.0 N48730G1X7.013Y-59.874F1800.0 N48740G1X8.340Y-59.705 N48750G1X9.658Y-59.506 N48760G1X10.968Y-59.276 N48770G1X12.271Y-59.016 N48780G1X13.569Y-58.725 N48790G1X14.862Y-58.404 N48800G1X16.151Y-58.051 N48810G1X17.437Y-57.666 N48820G1X18.720Y-57.249 N48830G1X20.003Y-56.800 N48840G1X20.723Y-56.530 N48850G1X17.763Y-57.507 N48860G1X16.508Y-57.885 N48870G1X15.258Y-58.230 N48880G1X14.000Y-58.547 N48890G1X12.723Y-58.837 N48900G1X11.414Y-59.103 N48910G1X10.060Y-59.350 N48920G1X6.227Y-59.956 N48930G00Z6.000 N48940G00X-28.350Y-53.184 N48950G1Z-2.500F1200.0 N48960G1X-26.859Y-53.963F1800.0 N48970G1X-25.843Y-54.462 N48980G1X-24.818Y-54.941 N48990G1X-23.786Y-55.400 N49000G1X-22.745Y-55.838 N49010G1X-21.697Y-56.256 N49020G1X-20.640Y-56.654 N49030G1X-19.575Y-57.031 N49040G1X-18.501Y-57.388 N49050G1X-17.420Y-57.726 N49060G1X-16.329Y-58.042 N49070G1X-15.231Y-58.339 N49080G1X-14.123Y-58.616 N49090G1X-13.008Y-58.872 N49100G1X-11.883Y-59.108 N49110G1X-10.750Y-59.324 N49120G1X-9.608Y-59.520 N49130G1X-8.458Y-59.695 N49140G1X-7.298Y-59.850 N49150G1X-6.130Y-59.985 N49160G1X-4.952Y-60.099 N49170G1X-1.234Y-60.372 N49180G1X1.594Y-60.310 N49190G1X2.725Y-60.256 N49200G1X3.986Y-60.164 N49210G1X5.904Y-59.990 N49220G1X-4.309Y-60.113 N49230G1X-5.628Y-59.933 N49240G1X-9.247Y-59.528 N49250G1X-13.011Y-58.770 N49260G1X-14.901Y-58.321 N49270G1X-15.869Y-58.065 N49280G1X-17.773Y-57.511 N49290G1X-19.686Y-56.891 N49300G1X-21.575Y-56.215 N49310G1X-23.408Y-55.493 N49320G1X-25.204Y-54.717 N49330G1X-26.892Y-53.914 N49340G1X-28.350Y-53.184 N49350G00Z6.000 N49360G00X-33.584Y-50.010 N49370G1Z-2.500F1200.0 N49380G1X-31.823Y-51.161F1800.0 N49390G1X-30.846Y-51.763 N49400G1X-29.861Y-52.343 N49410G1X-28.928Y-52.870 N49420G1X-31.098Y-51.563 N49430G1X-33.584Y-50.010 N49440G00Z6.000 N49450G00X-38.508Y-46.337 N49460G1Z-2.500F1200.0 N49470G1X-36.593Y-47.844F1800.0 N49480G1X-35.650Y-48.552 N49490G2X-36.720Y-46.816I2.226J2.570 N49500G1X-36.768 N49510G2X-38.508Y-46.337I0.000J3.400 N49520G00Z6.000 N49530G00X-39.422Y-45.611 N49540G1Z-2.500F1200.0 N49550G1X-39.309Y-45.701F1800.0 N49560G1X-39.612Y-45.426 N49570G1X-39.422Y-45.611 N49580G1X-39.952Y-46.212 N49590G1X-37.079Y-48.479 N49600G1X-36.129Y-49.193 N49610G1X-35.171Y-49.886 N49620G1X-34.205Y-50.557 N49630G1X-33.231Y-51.208 N49640G1X-32.249Y-51.839 N49650G1X-31.259Y-52.448 N49660G1X-30.261Y-53.036 N49670G1X-29.255Y-53.604 N49680G1X-28.241Y-54.152 N49690G1X-27.219Y-54.678 N49700G1X-26.188Y-55.184 N49710G1X-25.150Y-55.669 N49720G1X-24.103Y-56.134 N49730G1X-23.049Y-56.578 N49740G1X-21.986Y-57.002 N49750G1X-20.914Y-57.405 N49760G1X-19.835Y-57.788 N49770G1X-18.747Y-58.150 N49780G1X-17.650Y-58.492 N49790G1X-16.545Y-58.813 N49800G1X-15.432Y-59.113 N49810G1X-14.310Y-59.394 N49820G1X-13.179Y-59.653 N49830G1X-12.040Y-59.893 N49840G1X-10.893Y-60.111 N49850G1X-9.736Y-60.309 N49860G1X-8.571Y-60.487 N49870G1X-7.397Y-60.644 N49880G1X-6.214Y-60.780 N49890G1X-5.023Y-60.896 N49900G1X-1.254Y-61.172 N49910G1X1.623Y-61.109 N49920G1X2.773Y-61.055 N49930G1X4.050Y-60.962 N49940G1X5.741Y-60.811 N49950G1X7.105Y-60.669 N49960G1X8.450Y-60.498 N49970G1X9.787Y-60.296 N49980G1X11.115Y-60.063 N49990G1X12.437Y-59.799 N50000G1X13.753Y-59.504 N50010G1X15.064Y-59.178 N50020G1X16.371Y-58.820 N50030G1X17.675Y-58.430 N50040G1X18.976Y-58.007 N50050G1X20.276Y-57.552 N50060G1X21.575Y-57.065 N50070G1X22.875Y-56.544 N50080G1X24.175Y-55.989 N50090G1X25.478Y-55.401 N50100G1X26.795Y-54.772 N50110G1X29.622Y-53.388 N50120G1X32.803Y-51.384 N50130G1X34.546Y-50.208 N50140G1X36.239Y-48.982 N50150G1X37.882Y-47.705 N50160G1X39.476Y-46.377 N50170G1X41.018Y-45.001 N50180G1X42.509Y-43.576 N50190G1X43.948Y-42.103 N50200G1X45.335Y-40.582 N50210G1X46.670Y-39.014 N50220G1X47.951Y-37.399 N50230G1X49.178Y-35.739 N50240G1X50.350Y-34.033 N50250G1X51.468Y-32.283 N50260G1X52.530Y-30.488 N50270G1X53.536Y-28.650 N50280G1X55.364Y-25.045 N50290G1X56.659Y-21.706 N50300G1X57.161Y-20.298 N50310G1X57.626Y-18.894 N50320G1X58.054Y-17.494 N50330G1X58.446Y-16.095 N50340G1X58.802Y-14.696 N50350G1X59.123Y-13.296 N50360G1X59.409Y-11.893 N50370G1X59.661Y-10.486 N50380G1X59.877Y-9.073 N50390G1X60.060Y-7.652 N50400G1X60.209Y-6.222 N50410G1X60.324Y-4.781 N50420G1X60.406Y-3.328 N50430G1X60.454Y-1.862 N50440G1X60.469Y-0.366 N50450G1X60.466Y3.187 N50460G1X60.250Y5.256 N50470G1X60.027Y7.125 N50480G1X59.756Y8.959 N50490G1X59.433Y10.776 N50500G1X59.059Y12.574 N50510G1X58.635Y14.353 N50520G1X58.161Y16.114 N50530G1X57.636Y17.854 N50540G1X57.061Y19.573 N50550G1X56.437Y21.272 N50560G1X55.764Y22.949 N50570G1X55.042Y24.603 N50580G1X54.270Y26.234 N50590G1X53.451Y27.841 N50600G1X52.582Y29.425 N50610G1X51.665Y30.983 N50620G1X50.697Y32.521 N50630G1X49.811Y33.854 N50640G1X48.945Y35.096 N50650G1X48.083Y36.266 N50660G1X47.205Y37.389 N50670G1X46.292Y38.491 N50680G1X45.321Y39.598 N50690G1X44.273Y40.735 N50700G1X41.138Y43.952 N50710G1X39.472Y45.394 N50720G1X38.273Y46.406 N50730G1X37.081Y47.363 N50740G1X35.877Y48.280 N50750G1X34.655Y49.161 N50760G1X33.410Y50.010 N50770G1X32.134Y50.832 N50780G1X30.823Y51.630 N50790G1X29.457Y52.416 N50800G1X27.266Y53.642 N50810G1X24.830Y54.760 N50820G1X22.708Y55.657 N50830G1X21.646Y56.074 N50840G1X20.581Y56.469 N50850G1X19.514Y56.845 N50860G1X18.443Y57.200 N50870G1X17.367Y57.535 N50880G1X16.285Y57.851 N50890G1X15.196Y58.147 N50900G1X14.099Y58.425 N50910G1X12.994Y58.683 N50920G1X11.879Y58.923 N50930G1X9.616Y59.349 N50940G1X7.791Y59.631 N50950G1X6.379Y59.783 N50960G1X5.598Y59.842 N50970G1X3.705Y59.935 N50980G1X1.273Y60.000 N50990G1X-3.498Y60.094 N51000G1X-6.923Y59.737 N51010G1X-8.299Y59.556 N51020G1X-9.665Y59.347 N51030G1X-11.019Y59.110 N51040G1X-12.362Y58.846 N51050G1X-13.693Y58.554 N51060G1X-15.012Y58.235 N51070G1X-16.319Y57.888 N51080G1X-17.614Y57.514 N51090G1X-18.897Y57.114 N51100G1X-20.167Y56.686 N51110G1X-21.425Y56.231 N51120G1X-22.669Y55.750 N51130G1X-23.900Y55.242 N51140G1X-25.118Y54.708 N51150G1X-26.323Y54.147 N51160G1X-27.513Y53.560 N51170G1X-28.690Y52.947 N51180G1X-29.853Y52.308 N51190G1X-31.002Y51.642 N51200G1X-32.136Y50.951 N51210G1X-33.256Y50.234 N51220G1X-34.361Y49.491 N51230G1X-35.450Y48.722 N51240G1X-36.525Y47.927 N51250G1X-37.584Y47.107 N51260G1X-38.628Y46.262 N51270G1X-39.656Y45.391 N51280G1X-40.667Y44.495 N51290G1X-41.663Y43.573 N51300G1X-42.642Y42.627 N51310G1X-43.614Y41.645 N51320G1X-45.651Y39.543 N51330G1X-46.697Y38.255 N51340G1X-47.896Y36.743 N51350G1X-48.994Y35.285 N51360G1X-50.012Y33.850 N51370G1X-50.965Y32.416 N51380G1X-51.869Y30.961 N51390G1X-52.737Y29.461 N51400G1X-53.585Y27.895 N51410G1X-54.431Y26.226 N51420G1X-56.005Y23.027 N51430G1X-56.787Y20.921 N51440G1X-57.358Y19.307 N51450G1X-57.891Y17.655 N51460G1X-58.387Y15.957 N51470G1X-58.844Y14.229 N51480G1X-59.258Y12.483 N51490G1X-59.626Y10.732 N51500G1X-59.944Y8.989 N51510G1X-60.206Y7.295 N51520G1X-60.316Y6.241 N51530G1X-60.426Y4.693 N51540G1X-60.519Y2.881 N51550G1X-60.581Y1.028 N51560G1X-60.682Y-3.252 N51570G1X-60.333Y-6.898 N51580G1X-60.158Y-8.346 N51590G1X-59.956Y-9.763 N51600G1X-59.728Y-11.152 N51610G1X-59.473Y-12.516 N51620G1X-59.190Y-13.859 N51630G1X-58.877Y-15.183 N51640G1X-58.535Y-16.492 N51650G1X-58.163Y-17.790 N51660G1X-57.759Y-19.080 N51670G1X-57.322Y-20.365 N51680G1X-56.852Y-21.649 N51690G1X-56.348Y-22.934 N51700G1X-55.808Y-24.224 N51710G1X-55.231Y-25.523 N51720G1X-53.246Y-29.680 N51730G1X-51.448Y-32.631 N51740G1X-50.393Y-34.257 N51750G1X-49.302Y-35.826 N51760G1X-48.168Y-37.350 N51770G1X-46.984Y-38.837 N51780G1X-45.741Y-40.296 N51790G1X-44.433Y-41.738 N51800G1X-43.758Y-42.448 N51810G1X-42.316Y-43.898 N51820G1X-39.952Y-46.212 N51830G1X-40.482Y-46.813 N51840G1X-37.565Y-49.115 N51850G1X-36.604Y-49.837 N51860G1X-35.634Y-50.538 N51870G1X-34.655Y-51.219 N51880G1X-33.669Y-51.878 N51890G1X-32.675Y-52.516 N51900G1X-31.672Y-53.133 N51910G1X-30.661Y-53.729 N51920G1X-29.641Y-54.305 N51930G1X-28.614Y-54.859 N51940G1X-27.578Y-55.393 N51950G1X-26.534Y-55.905 N51960G1X-25.482Y-56.397 N51970G1X-24.421Y-56.868 N51980G1X-23.352Y-57.319 N51990G1X-22.275Y-57.748 N52000G1X-21.189Y-58.157 N52010G1X-20.095Y-58.544 N52020G1X-18.992Y-58.911 N52030G1X-17.881Y-59.258 N52040G1X-16.761Y-59.583 N52050G1X-15.633Y-59.888 N52060G1X-14.496Y-60.172 N52070G1X-13.351Y-60.435 N52080G1X-12.197Y-60.677 N52090G1X-11.035Y-60.898 N52100G1X-9.864Y-61.099 N52110G1X-8.684Y-61.279 N52120G1X-7.496Y-61.438 N52130G1X-6.299Y-61.576 N52140G1X-5.093Y-61.693 N52150G1X-1.275Y-61.973 N52160G1X1.652Y-61.909 N52170G1X2.821Y-61.853 N52180G1X4.115Y-61.759 N52190G1X5.818Y-61.608 N52200G1X7.197Y-61.464 N52210G1X8.561Y-61.290 N52220G1X9.916Y-61.085 N52230G1X11.263Y-60.849 N52240G1X12.603Y-60.582 N52250G1X13.937Y-60.283 N52260G1X15.267Y-59.952 N52270G1X16.591Y-59.589 N52280G1X17.913Y-59.193 N52290G1X19.232Y-58.765 N52300G1X20.549Y-58.304 N52310G1X21.865Y-57.810 N52320G1X23.180Y-57.283 N52330G1X24.497Y-56.722 N52340G1X25.815Y-56.126 N52350G1X27.143Y-55.493 N52360G1X30.012Y-54.088 N52370G1X33.239Y-52.054 N52380G1X35.004Y-50.864 N52390G1X36.719Y-49.622 N52400G1X38.384Y-48.328 N52410G1X39.998Y-46.983 N52420G1X41.561Y-45.589 N52430G1X43.072Y-44.145 N52440G1X44.530Y-42.652 N52450G1X45.936Y-41.110 N52460G1X47.288Y-39.522 N52470G1X48.586Y-37.886 N52480G1X49.829Y-36.203 N52490G1X51.017Y-34.475 N52500G1X52.149Y-32.702 N52510G1X53.225Y-30.884 N52520G1X54.244Y-29.022 N52530G1X56.095Y-25.372 N52540G1X57.410Y-21.983 N52550G1X57.918Y-20.558 N52560G1X58.388Y-19.137 N52570G1X58.822Y-17.719 N52580G1X59.219Y-16.302 N52590G1X59.580Y-14.884 N52600G1X59.905Y-13.466 N52610G1X60.195Y-12.043 N52620G1X60.450Y-10.617 N52630G1X60.670Y-9.184 N52640G1X60.855Y-7.744 N52650G1X61.005Y-6.295 N52660G1X61.122Y-4.835 N52670G1X61.205Y-3.364 N52680G1X61.254Y-1.879 N52690G1X61.269Y-0.370 N52700G1X61.266Y3.229 N52710G1X61.045Y5.345 N52720G1X60.820Y7.231 N52730G1X60.545Y9.088 N52740G1X60.219Y10.927 N52750G1X59.840Y12.748 N52760G1X59.411Y14.550 N52770G1X58.930Y16.333 N52780G1X58.398Y18.096 N52790G1X57.816Y19.838 N52800G1X57.184Y21.559 N52810G1X56.502Y23.258 N52820G1X55.770Y24.934 N52830G1X54.989Y26.587 N52840G1X54.158Y28.216 N52850G1X53.278Y29.820 N52860G1X52.349Y31.399 N52870G1X51.369Y32.956 N52880G1X50.473Y34.304 N52890G1X49.595Y35.562 N52900G1X48.720Y36.749 N52910G1X47.829Y37.890 N52920G1X46.901Y39.010 N52930G1X45.916Y40.133 N52940G1X44.855Y41.284 N52950G1X41.686Y44.536 N52960G1X39.992Y46.002 N52970G1X38.782Y47.024 N52980G1X37.574Y47.994 N52990G1X36.353Y48.923 N53000G1X35.114Y49.816 N53010G1X33.852Y50.677 N53020G1X32.559Y51.510 N53030G1X31.231Y52.318 N53040G1X29.852Y53.112 N53050G1X27.630Y54.355 N53060G1X25.154Y55.491 N53070G1X24.080Y55.956 N53080G1X23.006Y56.399 N53090G1X21.931Y56.821 N53100G1X20.853Y57.222 N53110G1X19.773Y57.602 N53120G1X18.688Y57.962 N53130G1X17.598Y58.301 N53140G1X16.502Y58.621 N53150G1X15.399Y58.921 N53160G1X14.288Y59.202 N53170G1X13.169Y59.464 N53180G1X12.040Y59.707 N53190G1X10.901Y59.931 N53200G1X8.589Y60.325 N53210G1X7.190Y60.508 N53220G1X5.647Y60.640 N53230G1X3.736Y60.734 N53240G1X1.291Y60.800 N53250G1X-3.530Y60.894 N53260G1X-7.019Y60.531 N53270G1X-8.412Y60.348 N53280G1X-9.794Y60.137 N53290G1X-11.165Y59.897 N53300G1X-12.525Y59.629 N53310G1X-13.873Y59.334 N53320G1X-15.209Y59.010 N53330G1X-16.533Y58.659 N53340G1X-17.845Y58.281 N53350G1X-19.144Y57.875 N53360G1X-20.431Y57.441 N53370G1X-21.705Y56.981 N53380G1X-22.966Y56.493 N53390G1X-24.213Y55.979 N53400G1X-25.448Y55.437 N53410G1X-26.668Y54.869 N53420G1X-27.875Y54.274 N53430G1X-29.068Y53.652 N53440G1X-30.247Y53.004 N53450G1X-31.411Y52.330 N53460G1X-32.560Y51.629 N53470G1X-33.695Y50.902 N53480G1X-34.814Y50.149 N53490G1X-35.919Y49.370 N53500G1X-37.008Y48.565 N53510G1X-38.081Y47.735 N53520G1X-39.138Y46.878 N53530G1X-40.179Y45.996 N53540G1X-41.204Y45.088 N53550G1X-42.213Y44.155 N53560G1X-43.204Y43.196 N53570G1X-44.186Y42.205 N53580G1X-46.250Y40.075 N53590G1X-47.321Y38.756 N53600G1X-48.529Y37.232 N53610G1X-49.639Y35.757 N53620G1X-50.671Y34.303 N53630G1X-51.638Y32.848 N53640G1X-52.555Y31.372 N53650G1X-53.435Y29.852 N53660G1X-54.293Y28.266 N53670G1X-55.147Y26.583 N53680G1X-56.741Y23.343 N53690G1X-57.539Y21.194 N53700G1X-58.116Y19.563 N53710G1X-58.656Y17.890 N53720G1X-59.158Y16.172 N53730G1X-59.620Y14.424 N53740G1X-60.039Y12.657 N53750G1X-60.411Y10.886 N53760G1X-60.733Y9.122 N53770G1X-60.999Y7.397 N53780G1X-61.113Y6.311 N53790G1X-61.224Y4.742 N53800G1X-61.318Y2.915 N53810G1X-61.381Y1.051 N53820G1X-61.483Y-3.279 N53830G1X-61.128Y-6.987 N53840G1X-60.951Y-8.451 N53850G1X-60.747Y-9.884 N53860G1X-60.516Y-11.290 N53870G1X-60.258Y-12.672 N53880G1X-59.970Y-14.033 N53890G1X-59.654Y-15.376 N53900G1X-59.307Y-16.704 N53910G1X-58.929Y-18.020 N53920G1X-58.519Y-19.328 N53930G1X-58.077Y-20.632 N53940G1X-57.600Y-21.933 N53950G1X-57.089Y-23.235 N53960G1X-56.542Y-24.541 N53970G1X-55.959Y-25.855 N53980G1X-55.334Y-27.187 N53990G1X-53.950Y-30.062 N54000G1X-52.126Y-33.056 N54010G1X-51.057Y-34.702 N54020G1X-49.952Y-36.293 N54030G1X-48.802Y-37.838 N54040G1X-47.601Y-39.345 N54050G1X-46.342Y-40.825 N54060G1X-45.017Y-42.285 N54070G1X-44.331Y-43.005 N54080G1X-42.880Y-44.466 N54090G1X-40.482Y-46.813 N54100G1X-41.012Y-47.413 N54110G1X-38.051Y-49.750 N54120G1X-37.078Y-50.481 N54130G1X-36.096Y-51.191 N54140G1X-35.106Y-51.880 N54150G1X-34.107Y-52.547 N54160G1X-33.100Y-53.193 N54170G1X-32.085Y-53.818 N54180G1X-31.061Y-54.422 N54190G1X-30.028Y-55.005 N54200G1X-28.987Y-55.567 N54210G1X-27.938Y-56.107 N54220G1X-26.880Y-56.627 N54230G1X-25.814Y-57.125 N54240G1X-24.739Y-57.603 N54250G1X-23.655Y-58.059 N54260G1X-22.564Y-58.494 N54270G1X-21.463Y-58.908 N54280G1X-20.355Y-59.301 N54290G1X-19.237Y-59.673 N54300G1X-18.112Y-60.024 N54310G1X-16.977Y-60.353 N54320G1X-15.834Y-60.662 N54330G1X-14.683Y-60.950 N54340G1X-13.523Y-61.216 N54350G1X-12.354Y-61.461 N54360G1X-11.177Y-61.686 N54370G1X-9.992Y-61.889 N54380G1X-8.798Y-62.071 N54390G1X-7.595Y-62.232 N54400G1X-6.383Y-62.372 N54410G1X-5.163Y-62.490 N54420G1X-1.295Y-62.773 N54430G1X1.681Y-62.708 N54440G1X2.869Y-62.652 N54450G1X4.179Y-62.556 N54460G1X5.895Y-62.404 N54470G1X7.289Y-62.259 N54480G1X8.671Y-62.082 N54490G1X10.044Y-61.875 N54500G1X11.410Y-61.635 N54510G1X12.769Y-61.364 N54520G1X14.121Y-61.061 N54530G1X15.469Y-60.726 N54540G1X16.812Y-60.358 N54550G1X18.151Y-59.957 N54560G1X19.487Y-59.523 N54570G1X20.821Y-59.057 N54580G1X22.154Y-58.556 N54590G1X23.486Y-58.022 N54600G1X24.818Y-57.454 N54610G1X26.152Y-56.852 N54620G1X27.491Y-56.213 N54630G1X30.401Y-54.788 N54640G1X33.675Y-52.725 N54650G1X35.462Y-51.520 N54660G1X37.199Y-50.262 N54670G1X38.886Y-48.951 N54680G1X40.521Y-47.589 N54690G1X42.104Y-46.176 N54700G1X43.634Y-44.713 N54710G1X45.112Y-43.201 N54720G1X46.536Y-41.639 N54730G1X47.906Y-40.030 N54740G1X49.221Y-38.372 N54750G1X50.480Y-36.668 N54760G1X51.684Y-34.917 N54770G1X52.831Y-33.121 N54780G1X53.920Y-31.280 N54790G1X54.952Y-29.394 N54800G1X56.826Y-25.699 N54810G1X58.161Y-22.260 N54820G1X58.674Y-20.818 N54830G1X59.150Y-19.380 N54840G1X59.589Y-17.944 N54850G1X59.992Y-16.509 N54860G1X60.358Y-15.073 N54870G1X60.687Y-13.635 N54880G1X60.981Y-12.194 N54890G1X61.239Y-10.748 N54900G1X61.462Y-9.296 N54910G1X61.649Y-7.837 N54920G1X61.802Y-6.368 N54930G1X61.920Y-4.890 N54940G1X62.004Y-3.400 N54950G1X62.054Y-1.897 N54960G1X62.069Y-0.374 N54970G1X62.066Y3.271 N54980G1X61.840Y5.434 N54990G1X61.613Y7.337 N55000G1X61.335Y9.216 N55010G1X61.004Y11.078 N55020G1X60.621Y12.922 N55030G1X60.186Y14.747 N55040G1X59.699Y16.553 N55050G1X59.161Y18.338 N55060G1X58.572Y20.103 N55070G1X57.931Y21.846 N55080G1X57.240Y23.567 N55090G1X56.498Y25.265 N55100G1X55.707Y26.939 N55110G1X54.865Y28.590 N55120G1X53.973Y30.215 N55130G1X53.032Y31.815 N55140G1X52.041Y33.390 N55150G1X51.134Y34.755 N55160G1X50.245Y36.028 N55170G1X49.357Y37.233 N55180G1X48.452Y38.392 N55190G1X47.510Y39.529 N55200G1X46.511Y40.668 N55210G1X45.438Y41.832 N55220G1X44.267Y43.048 N55230G1X42.235Y45.120 N55240G1X40.512Y46.610 N55250G1X39.291Y47.641 N55260G1X38.066Y48.624 N55270G1X36.829Y49.566 N55280G1X35.574Y50.471 N55290G1X34.294Y51.344 N55300G1X32.984Y52.188 N55310G1X31.638Y53.007 N55320G1X30.247Y53.807 N55330G1X27.994Y55.068 N55340G1X25.478Y56.223 N55350G1X24.392Y56.693 N55360G1X23.305Y57.141 N55370G1X22.217Y57.568 N55380G1X21.126Y57.974 N55390G1X20.031Y58.359 N55400G1X18.932Y58.723 N55410G1X17.829Y59.067 N55420G1X16.719Y59.391 N55430G1X15.602Y59.695 N55440G1X14.478Y59.979 N55450G1X13.345Y60.244 N55460G1X12.202Y60.490 N55470G1X11.049Y60.718 N55480G1X9.885Y60.926 N55490G1X7.998Y61.218 N55500G1X6.515Y61.377 N55510G1X5.697Y61.439 N55520G1X3.766Y61.534 N55530G1X1.310Y61.599 N55540G1X-3.562Y61.695 N55550G1X-7.115Y61.326 N55560G1X-8.525Y61.140 N55570G1X-9.924Y60.926 N55580G1X-11.311Y60.683 N55590G1X-12.688Y60.412 N55600G1X-14.052Y60.113 N55610G1X-15.405Y59.786 N55620G1X-16.746Y59.430 N55630G1X-18.075Y59.047 N55640G1X-19.391Y58.636 N55650G1X-20.695Y58.197 N55660G1X-21.985Y57.730 N55670G1X-23.263Y57.236 N55680G1X-24.527Y56.715 N55690G1X-25.777Y56.166 N55700G1X-27.014Y55.590 N55710G1X-28.237Y54.987 N55720G1X-29.446Y54.358 N55730G1X-30.640Y53.701 N55740G1X-31.819Y53.018 N55750G1X-32.984Y52.308 N55760G1X-34.134Y51.571 N55770G1X-35.268Y50.808 N55780G1X-36.387Y50.019 N55790G1X-37.490Y49.203 N55800G1X-38.578Y48.362 N55810G1X-39.649Y47.494 N55820G1X-40.703Y46.601 N55830G1X-41.741Y45.681 N55840G1X-42.763Y44.736 N55850G1X-43.767Y43.765 N55860G1X-44.757Y42.765 N55870G1X-46.849Y40.606 N55880G1X-47.945Y39.257 N55890G1X-49.162Y37.721 N55900G1X-50.285Y36.229 N55910G1X-51.331Y34.756 N55920G1X-52.311Y33.281 N55930G1X-53.241Y31.784 N55940G1X-54.134Y30.243 N55950G1X-55.002Y28.637 N55960G1X-55.862Y26.941 N55970G1X-57.476Y23.660 N55980G1X-58.291Y21.467 N55990G1X-58.874Y19.820 N56000G1X-59.420Y18.125 N56010G1X-59.929Y16.387 N56020G1X-60.397Y14.618 N56030G1X-60.820Y12.832 N56040G1X-61.196Y11.040 N56050G1X-61.522Y9.255 N56060G1X-61.793Y7.500 N56070G1X-61.910Y6.381 N56080G1X-62.023Y4.791 N56090G1X-62.118Y2.949 N56100G1X-62.181Y1.074 N56110G1X-62.284Y-3.306 N56120G1X-61.923Y-7.075 N56130G1X-61.744Y-8.555 N56140G1X-61.538Y-10.005 N56150G1X-61.304Y-11.429 N56160G1X-61.042Y-12.829 N56170G1X-60.751Y-14.207 N56180G1X-60.430Y-15.569 N56190G1X-60.079Y-16.915 N56200G1X-59.695Y-18.250 N56210G1X-59.280Y-19.577 N56220G1X-58.831Y-20.898 N56230G1X-58.348Y-22.216 N56240G1X-57.830Y-23.535 N56250G1X-57.277Y-24.858 N56260G1X-56.687Y-26.187 N56270G1X-56.056Y-27.530 N56280G1X-54.654Y-30.444 N56290G1X-52.803Y-33.481 N56300G1X-51.721Y-35.148 N56310G1X-50.601Y-36.761 N56320G1X-49.436Y-38.326 N56330G1X-48.219Y-39.854 N56340G1X-46.943Y-41.353 N56350G1X-45.601Y-42.831 N56360G1X-44.905Y-43.563 N56370G1X-43.443Y-45.034 N56380G1X-41.012Y-47.413 N56390G00Z6.000 N56400G00X-41.573Y-42.508 N56410G1Z-2.500F1200.0 N56420G1X-42.833Y-41.222F1800.0 N56430G1X-44.130Y-39.834 N56440G1X-45.383Y-38.436 N56450G1X-46.518Y-37.115 N56460G1X-47.454Y-35.958 N56470G1X-47.851Y-35.430 N56480G1X-48.192Y-34.935 N56490G1X-48.488Y-34.426 N56500G1X-48.594Y-34.170 N56510G2X-48.746Y-33.670I2.399J1.002 N56520G1X-48.761Y-33.598 N56530G2X-48.810Y-33.096I2.551J0.502 N56540G1Y-32.918 N56550G2X-48.540Y-31.766I2.600J0.000 N56560G1X-48.534Y-31.752 N56570G1X-48.920Y-31.763 N56580G2X-51.193Y-30.426I0.000J2.600 N56590G1X-52.049Y-28.885 N56600G1X-52.864Y-27.376 N56610G1X-53.631Y-25.889 N56620G1X-55.269Y-22.198 N56630G1X-56.082Y-20.114 N56640G1X-56.763Y-18.173 N56650G1X-57.038Y-17.308 N56660G1X-57.259Y-16.533 N56670G1X-57.417Y-15.861 N56680G1X-57.483Y-15.464 N56690G1X-57.510Y-15.105 N56700G1Y-14.555 N56710G2X-57.235Y-13.393I2.600J0.000 N56720G1X-56.030Y-10.979 N56730G2X-57.331Y-10.778I-0.265J2.586 N56740G1X-57.359Y-10.765 N56750G2X-58.626Y-9.588I1.036J2.385 N56760G1X-58.664Y-9.514 N56770G2X-58.843Y-9.082I2.303J1.207 N56780G1X-58.956Y-8.721 N56790G1X-59.119Y-8.056 N56800G1X-59.619Y-3.673 N56810G1X-59.609Y1.730 N56820G1X-59.576Y3.089 N56830G1X-59.518Y4.379 N56840G1X-59.431Y5.626 N56850G1X-59.313Y6.856 N56860G1X-59.162Y8.095 N56870G1X-58.977Y9.371 N56880G1X-58.592Y11.598 N56890G1X-58.407Y12.509 N56900G1X-57.992Y14.324 N56910G1X-57.508Y16.170 N56920G1X-56.967Y18.012 N56930G1X-56.374Y19.829 N56940G1X-55.737Y21.600 N56950G1X-55.066Y23.291 N56960G1X-54.358Y24.902 N56970G1X-53.513Y26.724 N56980G2X-51.305Y28.225I2.358J-1.095 N56990G2X-51.586Y29.400I2.319J1.175 N57000G1Y29.665 N57010G2X-51.148Y31.109I2.600J0.000 N57020G1X-49.060Y34.220 N57030G1X-47.889Y35.847 N57040G1X-46.651Y37.453 N57050G1X-45.363Y39.021 N57060G1X-44.037Y40.537 N57070G1X-42.686Y41.983 N57080G1X-41.325Y43.344 N57090G1X-39.965Y44.605 N57100G1X-39.288Y45.194 N57110G1X-38.387Y45.939 N57120G1X-37.976Y46.250 N57130G1X-37.529Y46.541 N57140G1X-37.194Y46.702 N57150G2X-36.638Y46.896I1.127J-2.343 N57160G1X-36.489Y46.929 N57170G2X-35.662Y46.980I0.570J-2.537 N57180G1X-35.533Y46.967 N57190G2X-34.799Y46.784I-0.257J-2.587 N57200G1X-34.465Y46.646 N57210G1X-25.327Y40.844 N57220G1X-16.407Y35.137 N57230G1X-10.107Y56.355 N57240G2X-7.615Y58.213I2.492J-0.742 N57250G1X10.160Y58.217 N57260G2X12.487Y56.778I0.000J-2.600 N57270G1X15.720Y50.299 N57280G2X13.333Y46.539I-2.326J-1.161 N57290G1X13.025Y46.546 N57300G1X10.327Y46.954 N57310G1X9.562Y47.031 N57320G1X9.022Y47.068 N57330G1X11.502Y41.729 N57340G1X15.274Y34.015 N57350G1X34.815Y46.500 N57360G2X37.444Y46.602I1.401J-2.190 N57370G1X38.039Y46.283 N57380G2X38.608Y45.870I-1.228J-2.292 N57390G1X41.854Y42.750 N57400G1X42.758Y41.836 N57410G1X43.645Y40.906 N57420G1X44.508Y39.967 N57430G1X45.341Y39.029 N57440G1X46.136Y38.097 N57450G1X46.887Y37.179 N57460G1X48.541Y35.025 N57470G1X51.290Y30.882 N57480G2X51.412Y28.211I-2.166J-1.438 N57490G2X52.894Y27.458I-0.375J-2.573 N57500G1X53.175Y27.171 N57510G2X53.702Y26.388I-1.857J-1.819 N57520G1X54.715Y24.056 N57530G1X55.413Y22.385 N57540G1X56.060Y20.690 N57550G1X56.652Y18.984 N57560G1X57.190Y17.263 N57570G1X57.674Y15.522 N57580G1X58.107Y13.758 N57590G1X58.489Y11.966 N57600G1X58.819Y10.159 N57610G1X59.295Y7.328 N57620G1X59.527Y3.804 N57630G1X59.628Y1.958 N57640G1X59.662Y0.262 N57650G1X59.627Y-1.439 N57660G1X59.526Y-3.300 N57670G1X59.301Y-6.728 N57680G2X59.145Y-7.459I-2.594J0.170 N57690G1X58.857Y-8.238 N57700G2X56.129Y-9.920I-2.438J0.902 N57710G1X57.129Y-11.938 N57720G1X57.350Y-12.441 N57730G1X57.557Y-13.008 N57740G1X57.656Y-13.484 N57750G2X57.710Y-13.985I-2.546J-0.527 N57760G1X57.715Y-14.506 N57770G1X57.607Y-15.210 N57780G1X57.440Y-15.876 N57790G1X56.966Y-17.410 N57800G1X56.431Y-19.010 N57810G1X55.834Y-20.651 N57820G1X55.194Y-22.291 N57830G1X54.524Y-23.896 N57840G1X53.840Y-25.432 N57850G1X53.155Y-26.867 N57860G1X52.486Y-28.159 N57870G1X51.820Y-29.317 N57880G1X51.473Y-29.867 N57890G1X51.314Y-30.074 N57900G2X50.891Y-30.511I-2.065J1.580 N57910G1X50.824Y-30.565 N57920G2X49.104Y-31.148I-1.642J2.016 N57930G1X48.733Y-31.118 N57940G1X48.844Y-31.424 N57950G1X48.935Y-31.780 N57960G2X49.011Y-32.265I-2.519J-0.645 N57970G1X49.024Y-32.464 N57980G2X48.978Y-33.136I-2.595J-0.161 N57990G1X48.940Y-33.322 N58000G2X48.761Y-33.879I-2.549J0.512 N58010G1X48.591Y-34.257 N58020G1X48.084Y-35.037 N58030G1X45.981Y-37.722 N58040G1X44.527Y-39.405 N58050G1X43.005Y-41.053 N58060G1X41.488Y-42.589 N58070G1X40.758Y-43.288 N58080G1X38.808Y-45.034 N58090G2X36.160Y-45.519I-1.725J1.945 N58100G1X36.170Y-45.826 N58110G2X35.016Y-48.077I-2.598J-0.089 N58120G1X33.011Y-49.417 N58130G1X32.006Y-50.067 N58140G1X30.902Y-50.744 N58150G1X29.739Y-51.424 N58160G1X28.542Y-52.095 N58170G1X27.336Y-52.744 N58180G1X26.146Y-53.355 N58190G1X24.995Y-53.915 N58200G1X23.927Y-54.403 N58210G1X21.882Y-55.298 N58220G1X17.524Y-56.743 N58230G1X16.286Y-57.116 N58240G1X15.053Y-57.457 N58250G1X13.814Y-57.769 N58260G1X12.554Y-58.054 N58270G1X11.262Y-58.318 N58280G1X9.924Y-58.562 N58290G1X5.929Y-59.193 N58300G1X-4.259Y-59.313 N58310G1X-5.529Y-59.139 N58320G1X-9.124Y-58.737 N58330G1X-12.840Y-57.988 N58340G1X-14.703Y-57.546 N58350G1X-15.655Y-57.294 N58360G1X-17.538Y-56.747 N58370G1X-19.428Y-56.134 N58380G1X-21.293Y-55.466 N58390G1X-23.105Y-54.752 N58400G1X-24.874Y-53.988 N58410G1X-26.537Y-53.196 N58420G1X-28.305Y-52.311 N58430G1X-30.681Y-50.881 N58440G1X-32.590Y-49.699 N58450G1X-34.002Y-48.768 N58460G1X-34.941Y-48.094 N58470G2X-36.024Y-45.961I1.517J2.112 N58480G2X-36.558Y-46.016I-0.534J2.545 N58490G1X-36.768 N58500G2X-38.517Y-45.340I0.000J2.600 N58510G1X-40.964Y-43.101 N58520G1X-41.573Y-42.508 N58530G00Z6.000 N58540G00X-49.408Y-34.280 N58550G1Z-2.500F1200.0 N58560G1X-49.546Y-33.753F1800.0 N58570G2X-49.610Y-33.096I3.336J0.657 N58580G1X-49.583Y-32.497 N58590G2X-50.977Y-31.869I0.664J3.335 N58600G1X-50.253Y-33.016 N58610G1X-49.408Y-34.280 N58620G00Z6.000 N58630G00X-47.635Y-29.201 N58640G1Z-2.500F1200.0 N58650G1X-47.647Y-29.261F1800.0 N58660G2X-47.793Y-29.617I-0.981J0.194 N58670G1X-47.825Y-29.667 N58680G2X-48.091Y-29.939I-0.835J0.550 N58690G1X-48.139Y-29.972 N58700G2X-48.505Y-30.129I-0.570J0.822 N58710G1X-48.665Y-30.163 N58720G1X-48.920 N58730G2X-49.794Y-29.648I0.000J1.000 N58740G1X-50.646Y-28.116 N58750G1X-51.449Y-26.629 N58760G1X-52.188Y-25.197 N58770G1X-53.794Y-21.576 N58780G1X-54.581Y-19.558 N58790G1X-55.243Y-17.673 N58800G1X-55.506Y-16.846 N58810G1X-55.710Y-16.130 N58820G1X-55.847Y-15.547 N58830G1X-55.892Y-15.274 N58840G1X-55.910Y-15.045 N58850G1Y-14.555 N58860G2X-55.804Y-14.108I1.000J0.000 N58870G1X-39.503Y18.517 N58880G2X-38.096Y18.928I0.895J-0.447 N58890G1X-36.897Y18.211 N58900G1X-28.286Y12.880 N58910G1X-27.897Y12.507 N58920G2X-27.690Y11.349I-0.693J-0.721 N58930G1X-29.909Y6.771 N58940G1X-39.435Y-12.483 N58950G1X-47.619Y-29.091 N58960G1X-47.635Y-29.201 N58970G1X-46.850Y-29.356 N58980G1X-46.862Y-29.417 N58990G2X-47.124Y-30.057I-1.766J0.350 N59000G1X-47.157Y-30.107 N59010G2X-47.635Y-30.596I-1.504J0.990 N59020G1X-47.683Y-30.629 N59030G2X-48.341Y-30.912I-1.026J1.479 N59040G1X-48.582Y-30.963 N59050G1X-48.920 N59060G2X-50.493Y-30.037I0.000J1.800 N59070G1X-51.347Y-28.500 N59080G1X-52.156Y-27.003 N59090G1X-52.910Y-25.543 N59100G1X-54.531Y-21.887 N59110G1X-55.332Y-19.836 N59120G1X-56.003Y-17.923 N59130G1X-56.272Y-17.077 N59140G1X-56.485Y-16.331 N59150G1X-56.632Y-15.704 N59160G1X-56.687Y-15.369 N59170G1X-56.710Y-15.075 N59180G1Y-14.555 N59190G2X-56.520Y-13.750I1.800J0.000 N59200G1X-40.219Y18.874 N59210G2X-37.685Y19.614I1.610J-0.805 N59220G1X-36.481Y18.895 N59230G1X-27.955Y13.616 N59240G1X-27.655Y13.384 N59250G1X-27.343Y13.084 N59260G2X-26.970Y11.001I-1.247J-1.298 N59270G1X-29.191Y6.419 N59280G1X-38.717Y-12.837 N59290G1X-46.850Y-29.356 N59300G00Z6.000 N59310G00X-58.290Y-14.189 N59320G1Z-2.500F1200.0 N59330G2X-57.951Y-13.035I3.380J-0.366F1800.0 N59340G1X-57.260Y-11.653 N59350G1X-57.677Y-11.499 N59360G2X-59.036Y-10.429I1.355J3.118 N59370G1X-58.688Y-12.360 N59380G1X-58.290Y-14.189 N59390G00Z6.000 N59400S9000M03 (Profile 1) () N59430G00X0.000Y76.000Z6.000 N59440G1Z-0.917F1200.0 N59450G2X76.000Y0.000I0.000J-76.000F1800.0 N59460G2X0.000Y-76.000I-76.000J0.000 N59470G2X-76.000Y0.000I0.000J76.000 N59480G2X0.000Y76.000I76.000J0.000 N59490G1Z-1.833F1200.0 N59500G2X76.000Y0.000I0.000J-76.000F1800.0 N59510G2X0.000Y-76.000I-76.000J0.000 N59520G2X-76.000Y0.000I0.000J76.000 N59530G2X0.000Y76.000I76.000J0.000 N59540G1Z-2.750F1200.0 N59550G2X76.000Y0.000I0.000J-76.000F1800.0 N59560G2X0.000Y-76.000I-76.000J0.000 N59570G2X-76.000Y0.000I0.000J76.000 N59580G2X0.000Y76.000I76.000J0.000 N59590G1Z-3.667F1200.0 N59600G2X76.000Y0.000I0.000J-76.000F1800.0 N59610G2X0.000Y-76.000I-76.000J0.000 N59620G2X-76.000Y0.000I0.000J76.000 N59630G2X0.000Y76.000I76.000J0.000 N59640G1Z-4.583F1200.0 N59650G2X76.000Y0.000I0.000J-76.000F1800.0 N59660G2X0.000Y-76.000I-76.000J0.000 N59670G2X-76.000Y0.000I0.000J76.000 N59680G2X0.000Y76.000I76.000J0.000 N59690G1Z-5.500F1200.0 N59700G2X76.000Y0.000I0.000J-76.000F1800.0 N59710G2X0.000Y-76.000I-76.000J0.000 N59720G2X-76.000Y0.000I0.000J76.000 N59730G2X0.000Y76.000I76.000J0.000 N59740G00Z6.000 N59750G00Z20.000 N59760G00X0.000Y0.000 N59770M09 N59780M30 %
26-10-2012 #2
I would definitely try lowering your feed rates and trying it at that. I've looked at your other posts and am guessing your running tb6560 at 24v? Having a bit of past experience with a similar kind of setup, your feed rates look too high for that amount of power.
26-10-2012 #3
Have you checked for any backlash on the machine?
26-10-2012 #4
I will try lowering the rates, the last run I did at 25mm/s would it need to be much slower, how about 15mm/s?
I've not checked for backlash simply because I'm not entirely sure what it is, but would backlash cause this type of fault? The machine seems to run much better than before(I have changed the BOB and some optocouplers) and the Z axis fault it had before hand has also gone, but now I have this.
I'll get there in the end. :)
26-10-2012 #5
Sorry mate ignore me. I was just thinking aloud.
Out of interest how far out of the spindle is your cutter? Just wondering if your getting a lot of cutter deflection.
26-10-2012 #6
I think I have fixed it. I dry ran above the bed and the X was +10mm at the end(exactly 10mm) so I ran it again and it was +10mm exact. So in mach I tried slowing the feed rate by 20% and it ended up +20mm by the end.
Then I checked the motor tuning and increased the velocity from 1200 to 1500(My logic was that the max motor velocity wasn't fast enough to match the feed speed, this was a complete guess and I could be completely wrong). Then I changed the step and dir pulse from 14:5 to 10:3. I have no idea why it was at 14:5 as I have never set it there.
It now returns to the same spot perfectly so I will try another run tonight and see if it cuts properly :)
Thanks for the help.
Phil
clunks / missing steps - DM856 and single pulse operation
By dsc in forum Motor Drivers & ControllersReplies: 37Last Post: 09-12-2013, 02:22 PM -
Possibly the greatest dubbing ever in a cnc video!
By Shinobiwan in forum General DiscussionReplies: 12Last Post: 24-07-2013, 05:34 PM -
Z acting Strange
By m.marino in forum Machine DiscussionReplies: 2Last Post: 06-03-2012, 09:30 PM -
Missing Steps + Stalling X-axis
By danielbriggs in forum Linear & Rotary MotionReplies: 5Last Post: 02-09-2010, 02:59 PM -
a strange question
By Dan Brown in forum Programmers CornerReplies: 15Last Post: 21-12-2009, 01:00 PM
