Thread: Vacuum Table Advice
31-10-2012 #1
Apologies for so many questions for a first post.
I run a Heiz S-400 which spends a lot of its time making one-off aluminium front panels for specialist electronics equipment.
Today, however, I needed to machine holes into the top of a quantity (40+) of plastic 'project' boxes approximately 3" x 5". My plan was to do 6 at a time by cutting an alignment jig out of 3mm PVC sheet and using my VT4432SEAL vacuum table (powered from a workshop vacuum cleaner) to hold the boxes in place. However, even with a rubber mat, I just wasn't getting enough 'suck' which meant a couple of boxes lifted on the tool with all the problems that causes. I tried double-sided tape as a last resort but the nature of the boxes' surface, a textured finish, meant that getting the tape to stick was a problem. What should have been an easy job turned into a bit of a marathon.
This may become a regular job and so getting a reliable method would be nice.
My first question is 'Do I have the right sort of vacuum table?' Mine has a 1cm x 1cm grid of small holes and a holey rubber mat but I see other designs which use slots and rubber cord to make custom patterns. Looking around Stritzelberger Steuerungstechnik GmbH shows many different designs.
Or is my vacuum cleaner not powerful enough? I see other vacuum generators ranging from affordable side-channel blowers to quite expensive pump models.
Or would I be better off by only doing 3 at a time? Instinct says that I ought to get twice the 'suck' if I do that.
Any help and suggestions will be gratefully received.
Brian.
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
