Thread: Vacuum Table Advice
01-11-2012 #2
Sounds as if the seal on each box is variable.
Why not make a dedicated fixture so that each unit has the same cross section of vacuum. Remember that the force from the vacuum is dependant on the area under each unit. Is the vacuum from the cleaner sufficient! Most vacuum pomps are posituve displacement devices!
Just a few thoughts!
peter
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
