Thread: Vacuum Table Advice
01-11-2012 #4
hello mucker. when i used the sabre router, the vacum bed had less holes in it, probably spaced at 40mm centres. it wasnt just holes, if i can explain. you had 4mm holes through into the sacrifial bed into the vacum, with a 20mmmm hole in the sacrificial bed. looking at it from the side it was "t" shaped. the small hole gives suction, then the bigger recess gives more, resulting in a better hold. Thats as clear as mud i know but difficult to explain. I think you have to many holes there, less is best i feel.
regards alex.
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
