Thread: Vacuum Table Advice
I wouldn't have used foam PVC to make the template, I doubt you will be getting a good seal all the way round & I wouldn't be surprised if it were porous enough for air to be sucked through it as well so the hoover will be fighting a losing battle trying to maintain any sort of vacuum. Try making the template out of a bit of rubber sheet rather than the foam.
01-11-2012 #2
Hi Martin,
it's actually 3mm rigid PVC which I machined on the CNC so that each cutout was a snug ( <1mm clearance) fit against the boxes. That sits on 1 mm holey rubber mat.
Hi Peter,
thanks, I thought you meant a piston based pump but best to check. I just need to find one which isn't going to break the bank.Last edited by Minium; 01-11-2012 at 09:30 PM.
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
