Thread: Vacuum Table Advice
01-11-2012 #9
it's actually 3mm rigid PVC which I machined on the CNC so that each cutout was a snug
Looking at the picture it looks very much like foamex which they may call a rigid PVC but because of the way is is made tends not to be great for sealing. If your using a vacuum cleaner to try & maintain a vacuum then an accumulation of very small leaks can cause you problems. One option would be more suck by using a bigger hoover, more hoovers or something else to pull a vacuum & the other option would be less leaks by sealing it better or reducing the area your sucking from. What sort of condition is the holey rubber mat in ?
There are a couple of threads on the forum about making vacuum tables so they might be worth a read.
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
