    Hi,here is an update to progress of my LeBlond,circa 1942 send over to Swan Hunters shipyard to help with the war effort ,used in the apprentice training school then rescued from the scrap man when the yard closed:
    -Click image for larger version.
ID:	10321Click image for larger version.
ID:	10322Click image for larger version.
ID:	10323Click image for larger version.
ID:	10324Click image for larger version.
ID:	10325Click image for larger version.
ID:	10326Click image for larger version.
ID:	10327Click image for larger version.
ID:	10328Click image for larger version.
ID:	10329Click image for larger version.
ID:	10330Click image for larger version.
ID:	10331Click image for larger version.
ID:	10332Click image for larger version.
    Thats looking really nice. Well done. G.
    Thank you geoffrey its getting near to cutting time -Regards-Brian
    Looks a nice lump of equipment and well restored. My only concern is the position of that inverter drive - I don't think there are many worse positions you could have put it! The air vents are gonna fill up with swarfe and suds, followed closely by a puff of smoke.
    Hi,Birchy might move it,but having said that l have already made a 3 sided cover top and one side and back so air can get at bottom the one side that is covered is ins clear to let air in same with top,so no water splashing or swarf can get in,and air can get in,its shaped to form ,drilled but tried it on yesterday and l didnt level the inverter when l put it on ,so l need to elongate the holes to allow slight movement,but l still might move it-Thanks for the advice-Brian
    Should be OK if you can put a shroud over it. Might be better to mount the inverter inside somewhere and just have a small control box on the front of the machine with start/stop and speed pot?
    Hi onecut.
    You have done a lovely job going by your photos. Like the grey and red. Did you strip all the old paint off? What paints did you use?
    Have just bought a 10" Regal lathe and about to refurbish it. Not too sure about stripping it apart. There is some wear on the bed and I might have to put up with that I have a manual for the lathe but not any instructions on how to start taken the lathe apart. Would you be able to guide me on this please?
    To have bed, tailstock and saddle re ground is about £2000, a bit too rich for me. Grinding the bed is about £600 Did you have any grinding carried out?
    Hope you don't mind me contacting you for information. c
  1. LeBlond regal 10ins
    By onecut in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 15-01-2017, 04:36 PM
  2. NEW MEMBER: Newbe on the site
    By Phillou in forum New Member Introductions
    Last Post: 14-03-2014, 05:54 PM
  3. Site Layout Changes
    By Ricardoco in forum General Discussion
    Last Post: 31-07-2012, 05:32 PM
  4. NEW MEMBER: New to site
    By roymar2 in forum New Member Introductions
    Last Post: 12-12-2010, 03:38 PM
  5. NEW MEMBER: New to the site
    By sopysnipe01 in forum New Member Introductions
    Last Post: 29-03-2010, 11:41 AM
