Quote Originally Posted by oscar View Post
For the initial two sets I would get some 25mm square bar for the axles and some 14mm plate. Then take it to a local blacksmith and get him to drill and tap the M12 holes. Then heat and bend the bar to shape. Bending has the benefit of being stronger because you are keeping the grain of the metal intact, rather than cutting through it on a mill. Also you aren't wasting material/money by machining a bigger bit of material down to size and shape.
Then if your happy with how these parts perform they can either make you a batch the same way, or make you a form to go in a press. Whichever is the cheapest option.
I wouldn't personally go down the CNC route on the axle. Only on the plate part when you want a batch of them.
Hope this helps.
Yes, it is a pretty simple design and I had wondered if it was possible to do it manually. It'll just take someone with the right tools, I don't think I know anyone capable of doing it but it won't curt to ask around. If I did print off plans and source some metal, would I expect a blacksmith to get on with the job? Basically the job could be done by:
Axle
Bending the axle
Drill 2 6 mm holes
Drill 2 12mm holes and tap it
Hanger
Cut the outside shape
Drill 25mm (i think) holes part way through
Drill 12 mm holes
Drill 2 6 mm holes
Drill the cone shape thing, it's like a big countersink hole.
