:) I'm sure you wont regret it. You'll probably want to get these to go with it:
Brand new precision ER20 collet set 12pcs (2mm-13mm) | eBay
05-11-2012 #2
Thanks Jonathon. Please could you post a link to a set of bits/endmills that would be used for Alu with this setup. ?
05-11-2012 #3
Depends on what you're cutting of course, but for general 2.5D machining I use the 6mm single flute cutters. I quite regularly use the same style cutters from 3mm to 8mm. The tool deflection is proportional to the length of the tool to the power 4, so a small increase in the length of the tool can lead to a much higher deflection and thus poorer finish, hence you should always buy the smallest ones you can use, so ideally keep a selection...
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Plug for water cooled Chinese spindle
By John S in forum Generic Chinese SpindlesReplies: 34Last Post: 28-08-2012, 05:56 PM -
Water cooled chinese spindle collets, Advice from owners please
By craigrobbo in forum Generic Chinese SpindlesReplies: 15Last Post: 11-05-2012, 12:08 PM -
FOR SALE: 2.2KW Water Cooled Spindle + Inverter (yes the Chinese one!)
By Bokoshoko in forum Items For SaleReplies: 3Last Post: 06-02-2012, 12:43 PM
