Ok, last update to the frame unless anyone can spot something really wrong.
I've extended the X-axis rails to 1800mm which will mean a serious re-arrangement in the workshop, an extra support has also been included to up the stiffness. Bracing, in the form of 50x5mm plate, has been added to help prevent the frame from distorting. I think the bracing could be better but it should help once it's bolted down tight. The only other change is to move the long stretcher (at least that's what it would be called in woodwork) to the inside of the leg as I think it looks better that way. The weight comes in a at around 100kg which I can live with - I just won't invite anyone into the workshop :-)
Name:	Wobblycogs CNC v2.1 - Frame 1.png
ID:	7305Click image for larger version.
Name:	Wobblycogs CNC v2.1 - Frame 2.png
