ID:	10215Click image for larger version.
ID:	10216Click image for larger version.
ID:	10217Click image for larger version.
Hello all. I've made some progress lately. The control system is nearly finished (bar some limit & home switch mounting), and tested on The Z Axis which is just about there. The Y is nearly there, just need to mount the stepper which leads me to the frame. I have looked at many frame's and tried to come up with my own. There were three features I was looking for
i) I wanted the frame to be robust enough to support cutting aluminium
ii) I wanted to be extend the rails over one end for over sized jobs (thanks jazz)
iii) Thinking of the over size issue, I wanted the frame to be tall enough that I could mill out the lock on a door.
The machine will be inside so I'm looking for welded frame sides with bolted cross members. I also decided I didnt want the hassle of a moveable bed, frankly I want to get the thing built (this year), so left 110mm of Z travel from the tip of the spindle, I think thats enough for general use? I also decided at this stage to have two rails (in orange) welded to the sides as support for the drop-in welded bed frame (purple). With the exception of the top rails, everything else is 50x50x3. I havent costed it yet, will probabily have to revise on that basis alone but wondered if there was any feedback on the design so far. Thanks.
