Thread: Tiddy CNC.
21-04-2014 #24
So. frustration with the electronics over and frankly the "is that it?" feeling from ProTune in the rear view mirror (apart from the fault codes which were interesting and somewhat revealing) I took a look at the mechanicals again as there was some resistance/binding on the right hand X Axis. I attached the fixed and floating bearings on the frame using the link to the gantry to support the alignment and did the best I could do at the time. The problem is there is no adjustment in the design, mainly becuase it was made using hand tools/small press drill and one or two trips to people with milling machines (for the slot in the front Y Plate, and a small pocket on the inside of the Z Axis).
So I'll need to come up with some plates that allow the fixed and floating bearings on both sides to connect to the frame with some (mainly horizontal) adjustment, its about 1mm out end to end currently. More on that when I get some time..
