Thread: Tiddy CNC.
    It is more common to set the home for Z at the top, that means all cuts will be -Z. So when you zero your Z at the bed a command to cut would be a -Z move.
    You can tell Mach to home in any direction. ..Clive
    Dont know if this will double post? Thats how its set up Clive. the code looks ok to me too I think, start of Z3 as a positioning move, moves down to Z0.2 still just above bed and then gets to Z-1.0 4th line up from the bottom. so why is the spindle not actually going down but going up?
    The Z as Clive said should be 0 at the Top and go down with negative sign.
    Do you recalculate the toolpath? When set working Z0 i mean.
    Ok Zero at the middle of the air. Then in the mdi window write Z-1 and hit enter. It should go down from there 1mm/ becarefull if in inch cause will go 1 inch down /
    Thanks chaps. I did the MDI -1 and it does come down 1 mm.
    Maybe I'll start again with cambam and see if that helps.
    Try it using the Mach3-CutViewer post processor as you are, then try it with just the Mach3 post processor, see if there's a difference.
    Thanks Eddy, I did change the post processor and reset Cambam to start from scratch. I think its the stock to cut relative to the Z that had me confused.
    I created two tests. For the first I created a simple shape in Cambam than had a depth of 5mm relative to 0 and marked the Z axis depth on a post-it note. I stopped the program when it was at depth and although I didnt measure it accurately I'm OK that it ran a clearance height plus Z and ended up around -5. The camera work on the first video is pretty awful, makes you realise that those who do youtube videos well put some work into it :) should be at https://www.youtube.com/watch?v=ngDW4964BR4
    For the second test I tried manually adjusting the Z and ran the program, It using a hacked Biro and the ink tube slips a little as well as bing not the smoothest line. I found that around 1.05 into the video the pen caught for a few secs, I think its down to replacing the cut down biro with a felt tip now. This video is still not great but has the virtue that I'm not really trying to do too many close-ups. http://youtu.be/iah4JGcsFbI
    For those on thier journey to making a machine, I can say it is very satifying when it starts to move and it does kind of sing a bit during arcs. More videos and stuff in a few weeks when I get another chance to play.
    And for my next problem.. :)
    I'm getting comforatble jogging the machine around now, I'm about to use it to drill some holes through the MDF bed and into the Steel base structure prior to tapping the steel and using a Forstner bit on the MDF to counterbore it so I can firmly fix the bed prior to checking the gantry for good geometry, surfacing etc and.. I cant seem to get the VFD (& Spindle) running and have Mach communicate with the PLCM control board. Interesting enough I did have issues a few weeks ago where I would lose comms to the control cabinet whenever I closed the control box, which was most weird and I bypassed the problem by removing the USB chassis mount and just running the USB cable direct from the PC to the control board through a hole in the box. This all leads me to suspect earthing as a culrpit? Any ideas how I would trace the issue, sorry its a bit vauge, I can post pictures and update the electrical schematic if that would help. Any advice, as always, much appreciated. Thanks.
    Ok well first why are you using USB when the PLCM is capable of using Ethernet.? Ethernet is much much better at handling noise than USB.
    Need some idea or pics of how you have wiring/earths etc because you shouldn't be having PC earth interfering with Control box earth and vise versa. You haven't earhed the PC to control box earth have you.? PC should just use the Earth in the Plug and no external earth to control or machine frame.
    Also have you got a Earth from machine frame to Control Star earth.? If not then do so.
    Can you post your Mach3 XML file (Zip it up) it will be in mach3 folder using same name as the profile your loading from Mach3 loader.
    What VFD is it and does it work normally Ie: ~using buttons on front.?
    What settings have you changed in the VFD and what did you enter.?
    What inputs on the VFD are you connecting to.?
    Quote Originally Posted by TonyD View Post
    And for my next problem.. :)I can post pictures and update the electrical schematic if that would help.
    That's the best idea, also I don't know why you suspect earthing as the problem, I would be thinking it was the chassis mounted USB connector from your description, or that the closed door was exerting undue pressure on the cable thus twisting it somehow in the socket.
