Thread: Tiddy CNC.
  1. #32
    The Z as Clive said should be 0 at the Top and go down with negative sign.
    Do you recalculate the toolpath? When set working Z0 i mean.
    Ok Zero at the middle of the air. Then in the mdi window write Z-1 and hit enter. It should go down from there 1mm/ becarefull if in inch cause will go 1 inch down /
