Thread: Tiddy CNC.
21-09-2014 #34
Ok first let me just clear up something because it becomes confusing for others reading this.! You don't have a SS this relates to a particular Brand name of Motion control card called the Smooth stepper shortened to SS or ESS for the ethernet version.
You have PLCM E3 which is still a motion control card but not to be confused with the SS.
Now what breakout board do you have because the PLCM E3 doesn't have spindle speed control directly so for this you'll need either external spindle speed control board or a breakout board with one built into it.
If you haven't set up the parameters in the VFD then don't go trying to make it start else you'll possibly do it some damage if the parameters are set wrong.
After setting intial parameters like Voltage, amps etc then if you want to control it thru G-code and the control software then you'll need to set more parameters in VFD so can be controlled from an external source. Also along with this you'll need to set outputs and spindle settings etc in Mach3.
Do a search on the forum and you'll find the settings and parmeters to change.
