Thread: 2D software for newbe
That's why it is confusing Rick because the cube you have just said you could cut is 3D so a 3 axis machine can cut 3D shapes BUT it is obviously limited in what 3D objects it can cut so how would you define it, or perhaps you can't.
Anyway moving on from that I have now purchased cut 2D, having watched the tutorials & had a play about with it I can do everything I need to with it for now so don't see the point in paying a lot of extra money for vcarve which doesn't have any features that would be of benefit to me just now.
I have the option to upgrade at a latter date if I need to so it won't be money wasted. Very impressed with just how use friendly it is.
I had downloaded both lazycam & cambam to have a look at & although I hadn't actually spent a lot of time looking at them neither of them seemed to be particularly easy to learn.
10-11-2012 #2
3 axis machines Cut 2.5D Not true 3D although some would argue as tool changes and work piece re-orientation make it seem possible..
Being an Ex-Software engineer i find it difficult to put my name to much software as most of it is bloated with features that i would never use nor would most, but i found the range of software offered by vectric both Concise and easy to learn.
As with you i started with cut 2d, i then migrated to cut 3D then V-carve and finaly i saved enough for Aspire and although it hurt my pocket big time, i found in a very short time i was producing commercial quality products that other people wanted to buy from me, it soon payed for itself, and i didnt know much about the workings of CNC at all, bar what i had gleened from the helpfull people i found on this site, now i spend my time here trying to learn as much as i can and help as many people as i can...
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
12-11-2012 #3
12-11-2012 #4
12-11-2012 #5
Cambam functions like some dawing programs and once get used to where things are in menus find it`s been reasonably intuitive.
Cut2D shows its roots in software for the sign market and it has nicer 3d visualisations ;-)
2d design likely to have been done outside of CAM program and its ease of depth setting , nesting and tabbing ,guess, are bits going to use most.
12-11-2012 #6
12-11-2012 #7
Have to have drawn the part originally in something from MS Paint to Autodesk Inventor or within the CAM program , its a design ;-)
It`s whatever gets the job done with minimal hassle is what always matters hobby or professional use, some people will wear running between programs , some want all the workflow in one program. As long as avoid falling into the trap of thinking spending more on software will act as a magic wand...
12-11-2012 #8
I do some of my design work using a program called Inspire Pro which has not been available to buy for many years & for those that know anything about the sign industry was the predecessor of Flexisign Pro. It cost about £3500 well over 10 years ago so wasn't cheap & at the time free vector programs or programs like corel weren't really geared towards the sign industry or didn't exist. It won't run on anything above a windows 98 platform but it still does everything I need it to so have never seen the need to upgrade it which would obviously cost me money plus over the years the way some things are done has changed soI would also have to learn all the changes.
For photographic type stuff I am still using Adobe CS1 which runs under windows XP pro but like Inspire still does all I need it to.
You can see from that I don't buy software just because it's the latest available lol
I already have a lot of customer artwork that I can easily convert to either a dxf, eps or ai vector file to import into a cam package so yes I could have used something like cambam to create toolpaths for any machining work that came my way. Point is as I have already said is that for me personally cut 2D looked to be the best option in terms of how easy it was to learn & although it is not free it is very reasonably priced for what it does. Doesn't mean that everyone will agree with me or that everyone will find it the easier cam package to learn, some will find cambam just as easy to pickup I'm sure.
NEW MEMBER: Newbe from Norway!
By R-Moore74 in forum New Member IntroductionsReplies: 8Last Post: 13-12-2010, 05:13 PM -
NEW MEMBER: Newbe
By THE PHOENIX in forum New Member IntroductionsReplies: 2Last Post: 03-12-2010, 07:20 PM -
NEW MEMBER: Hi from newbe
By croy in forum New Member IntroductionsReplies: 2Last Post: 28-01-2010, 09:22 PM -
PIC Advice For A Newbe
By Mad Professor in forum Electronic Project BuildingReplies: 20Last Post: 06-12-2009, 10:14 AM -
NEW MEMBER: Newbe
By cncezee in forum New Member IntroductionsReplies: 3Last Post: 29-08-2009, 07:40 AM
