Thread: 2D software for newbe
10-11-2012 #31
So if you don't mind me asking Rick what is it you produce commercially now using either vcarve or aspire that people are buying from you.
What sort of machine are you running? Are you running a 3 axis machine or have you apgraded it to something else.
10-11-2012 #32
I started making custom parts for motorcycles. Rear sets, Yokes, Levers, and mounting items for speedos and the like just to mention a few. I dont run a comapny, I just make stuff for people who ask me, and they reimburse my costs...Hmmm.. I have three machines. A Diy 3'X2' gantry mill, a Boxford 260vMC (dead at athe moment).and anSPG 2217-III (a warco type Mill)
Im Currently building a 7'X4' Steel frame Gantry mill..Hopefully with ATC, I have been getting Bits made by other people lately because my main ali machine is dead as i said earlier but also because i lack the time this time of year with work commitments..
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
11-11-2012 #33
Generally, this refers to the toolpaths, and not the actual parts. Because unless your parts are infinitely thin, they're all 3D parts.
2D is typically used on a machine with a manual Z axis. You set the Z axis to a specific location, and the machine only moves the X and Y axis. Since this typically only applies to very old machines, or very specialized machines, the terms 2D and 2.5D generally are referring to the same type of software, and are interchangeable imo.
2.5D toolpaths are the most common. What 2.5D means, is that the machine will move the Z axis, but cutting is predominantly done only in the X and Y axis. Basically, the Z axis is not moving when the X and Y are. There are some minor exceptions. A lot of 2D or 2.5D cam programs can ramp into the cut, some can do helical milling of holes, and they can also do drilling.
2D or 2.5D CAM programs generally work with 2D vector drawings. Some more expensive ones can create these 2.5D toolpaths from 3D solid models.
3D toolpaths generally have all 3 axis (X,Y, and Z) moving at the same time when cutting. They are created from 3D models, either solid or mesh format. Generlly, the cheaper CAM packages use mesh models only, while the more expensive ones support the use of solid models. These more expensive packages are able to detect features of the models, and create more efficient and localized toolpaths.
The cheaper 3d CAM packages that only use meshes usually only do a raster type of toolpath, basically moving back and forth across the surface of the part, stepping over a small amount for each pass.
V Carving would be considered a 3D toolpath, but is a feature sometimes included in 2D cam programs (V-Carve Pro).Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
11-11-2012 #34
what a brilliant post and kind of sums everything up nicely.. thank you
12-11-2012 #35
12-11-2012 #36
12-11-2012 #37
I am sure there will be lots of people who agree with you Jonathan but personally because I don't want to spend lots of time trying to learn new software & from what I could see cut 2D had some very good support & easy to follow tutorials it fitted the bill for me.
Maybe if I were a bit younger then I would have opted for something else like cambam but unfortunately I don't have anywhere near as many grey cells as I use to have so although I am still happy to try & learn new things it's not as easy as it once was.
12-11-2012 #38Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
12-11-2012 #39
Cambam functions like some dawing programs and once get used to where things are in menus find it`s been reasonably intuitive.
Cut2D shows its roots in software for the sign market and it has nicer 3d visualisations ;-)
2d design likely to have been done outside of CAM program and its ease of depth setting , nesting and tabbing ,guess, are bits going to use most.
12-11-2012 #40
NEW MEMBER: Newbe from Norway!
By R-Moore74 in forum New Member IntroductionsReplies: 8Last Post: 13-12-2010, 05:13 PM -
NEW MEMBER: Newbe
By THE PHOENIX in forum New Member IntroductionsReplies: 2Last Post: 03-12-2010, 07:20 PM -
NEW MEMBER: Hi from newbe
By croy in forum New Member IntroductionsReplies: 2Last Post: 28-01-2010, 09:22 PM -
PIC Advice For A Newbe
By Mad Professor in forum Electronic Project BuildingReplies: 20Last Post: 06-12-2009, 10:14 AM -
NEW MEMBER: Newbe
By cncezee in forum New Member IntroductionsReplies: 3Last Post: 29-08-2009, 07:40 AM
