Thread: sliding gantry or sliding Base ?
05-11-2012 #9
With a fixed gantry you can make the gantry as strong as you want without worrying about its mass too much, since it's not moving. Clearly since the rails now need to be bigger it's likely to cost more, so you're using more space and money to get better rigidity which is nothing new. Also the motors now have to move the mass of the bed and whatever you cutting, which could add up to a considerable amount with an aluminium bed. Clearly this means you may have to spend more on the motors, although since the bearing blocks can be spaced out a lot, you should only need one ballscrew so that saves a bit compared to a moving gantry.
It will be significantly cheaper to use steel for the main frame, instead of extrusion. With a fixed gantry you can afford to get some big box section...
rails for sliding tv
By wilfy in forum Rails, Guideways & BearingsReplies: 19Last Post: 23-03-2013, 07:56 PM -
FOR SALE: Sliding head cnc lathes £5k
By jpcnc in forum Items For SaleReplies: 1Last Post: 29-05-2011, 09:00 PM -
Manurhin Kmx sliding heads
By jpcnc in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 14-03-2011, 08:25 AM -
Base design for new router
By cncgreg in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 31-08-2010, 03:35 PM -
New hybrid linear bearing combines rolling and sliding
By igusUK in forum Rails, Guideways & BearingsReplies: 0Last Post: 15-10-2009, 10:00 AM
