	09-11-2012 #16
I did just type a big response, but just hit the wrong button, so here's just the summary!
Running a full split charge system will not cost you much on terms of fuel.
Even relying on the vehicle to fully charge the Aux batteries from totally flat, and assuming poor engine and alternator efficiency, will only take around a litre of diesel in addition to what you're taking to drive around. If you use the wind/solar to provide a continual charge, then the vehicle will not see that much of an increased load. Even if the batteries add an additional continual 20A load, it's only an additional 100ml of diesel an hour needed.
As for what split charge system to use, I'd personally build one using a large relay (200A range), and an Arduino.
Programme it so it monitors the vehicle battery, when it hits a set voltage, it connects the relay, if the vehicle voltage then drops too much, have it drop-out until the vehicle voltage recovers then add an additional time delay (will stop the relay continually switching in a short time frame, and give the alternator a rest instead of hammering it continually), and repeat until voltages stabilise. You could also programme it so it doesn't charge the Aux if the Aux batteries are above a set voltage.
That way you should get a reliable system, without the issues with conventional relay systems, and without the over-priced 'smart' systems.
Alsom, if you're van is only putting out 13.5V, then it has issues. It should be above 14V. Is it an old D, or a newer CDI?
Advice please! JAF Motion Controller issues!
By Mark Chard in forum Machine Control SoftwareReplies: 0Last Post: 31-01-2014, 05:03 PM -
TinyG CNC Controller in the UK?
By Nimbus in forum Marketplace DiscussionReplies: 0Last Post: 14-06-2013, 06:03 PM -
Which controller and motors? Newbie advice please
By Nealieboyee in forum Motor Drivers & ControllersReplies: 14Last Post: 16-10-2012, 02:56 PM -
UHU Servo Controller
By gbar in forum Stepper & Servo MotorsReplies: 4Last Post: 11-05-2012, 12:12 PM -
Controller Box
By M250cnc in forum Motor Drivers & ControllersReplies: 1Last Post: 21-11-2010, 01:34 AM
