Thread: 4th axis and spindle
Yes they come with quadrature encoders, standard 2500.
To stop the motor moving when the power is switched off, which is useful if for instance the motor is running a Z-axis which could drop with no holding torque. The brake is rated for slightly greater than torque than the motor, so it's not much use as a spindle lock unfortunately.
08-11-2012 #2
OK, What about Mach3 control ? Do the drivers come with DIR & Pulse inputs as stepper drives or.... ?
08-11-2012 #3
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
